Old 12-18-2013, 01:17 PM   #1
qqzj
Drives: MDX, Camry
How to light up the buttons when driving in the night?
When I drive in the night, all the buttons have no backlight. So I literally cannot see any of them. For example, when I arrive my home and need to press the button on the rear view mirror to open garage door, I have to try several times to hit the right button. This is also true for all the other buttons. I believe all my other cars by default will have backlight for, at least, some important buttons. Is there anyway to solve this problem? Thanks in advance.
qqzj is offline   Reply With Quote
Old 12-18-2013, 01:21 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I find it hard to believe that all your console buttons are not lighting up. Are you just referring to the buttons on the homelink mirror?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 12-18-2013, 01:24 PM   #3
qqzj
Drives: MDX, Camry
I am serious. The odometer button, the display button, the audio/gps button, none of them light up in the dark. I set my headlight to auto.
Old 12-18-2013, 01:35 PM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
Did you at least try to turn your headlights on manually instead to see if that helps?
And make sure this furthest left dial by the trunk button area is turned up to maximum. This is the dial for the interior gauges and buttons lights.
Name:  Screen Shot 2013-12-18 at 10.34.07 AM.png
The Following 3 Users Say Thank You to kALMIGHTY For This Useful Post:
M-17 (12-18-2013), mav1178 (12-18-2013), strat61caster (12-18-2013)
Old 12-18-2013, 01:37 PM   #5
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Gonna sound crazy to you but nothing happens when you turn on your headlights?
Do your headlights even come on?
Get that checked ASAP. Usually the headlight switch has three settings, OFF, daytime lights and headlights ON (or something to that effect). Stage 2 and 3 should turn on your backlighting.
Is this on BRZ?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 12-18-2013, 01:53 PM   #6
qqzj
Drives: MDX, Camry
Thanks for your guys help. I went downstairs and checked again. But it is day time, so I might be wrong. Will double check again.
It seems that the button on the mirror for garage door never lights up.
I turned the dial to 'headlight' it seems that I got some backlight. But I can swear I cannot get any backlight when driving in the night under 'Auto'. But let me double check again tonight to make sure.
Is this on BRZ?
Old 12-18-2013, 02:17 PM   #7
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Please tell us that you have tried using the "Illumination Brightness Control" dial. This is located on the lower left area of the instrument panel and next to the "headlight Beam Leveler" dial. See KALMIGHTY's post # 4.
It is described on page 10 of your 2013 BRZ Quick Reference Guide panphlet that should have come with the purchase of the vehicle.
Let us know if this works. Be sure your light switch is ON. This is for your INSTRUMENT PANEL BACKLIGHTING.
LET US KNOW...
BRZfan is offline   Reply With Quote
Old 12-18-2013, 02:39 PM   #8
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Those buttons do not light up on mine either....I think it is the way they are...
ntron1 is offline   Reply With Quote
Old 12-18-2013, 02:56 PM   #9
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Correct, that's how it is.
tanner is offline   Reply With Quote
Old 12-18-2013, 03:10 PM   #10
BRZfan
BRZfan's Avatar
Hmmmm.... no answer yet. Does the original poster read the posts??? The poster still hasn't qualified if he/she is talking about JUST the 'mirror' illumination or the instrument panel illumination or both.
Old 12-18-2013, 05:30 PM   #11
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Homelink mirror garage door button is easy to find by muscle memory. Just program the first button on the left. Simple. (1st world problems for sure)
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 12-18-2013, 06:27 PM   #12
Chee-Hu
Chee-Hu's Avatar
must be the OP's first car.
Chee-Hu is offline   Reply With Quote
Old 12-18-2013, 06:37 PM   #13
qqzj
Drives: MDX, Camry
Sorry, just came back from lunch. From all the responses, I believe the home link buttons simply do not have back light.
For the instrument brightness control nob, I always set it to the middle. So I guess it is not a concern ever.
What I need to compare is whether it makes any difference whether I set the head light to 'auto' or 'on'. My suspicion is that that 'auto' is not smart enough. When I played in day time today, with, it on 'on', I saw some back light I never saw before. Will report back tonight. Thanks for the help.
LET US KNOW...
Old 12-18-2013, 07:39 PM   #14
BRAWL
Drives: Toyota 86 GTS Velocity Orange
With AUTO on, it will only backlight dials (also dim the head unit) when the headlights come on (low light conditions) otherwise just your parking lights/DRL's stay on. I would personally prefer auto to turn on all the instrument lights but NOT dim the head unit when in day light
BRAWL is offline   Reply With Quote
ABS and TRAC Light came on last night Sargy Issues | Warranty | Recalls / TSB 33 10-27-2015 05:33 AM
Light the Night at Anaheim Stadium PSJohnDoe Southern California 0 09-28-2013 03:06 AM
diy request: install a driving camera by tapping power from the interior map light. shaoster DIY (Do-It-Yourself) Guides 6 01-24-2013 03:02 PM
Back of BRZ LED Driving Light Picture JRitt Cosmetic Modification (Interior/Exterior/Lighting) 6 06-08-2012 09:51 AM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 07:15 PM
