Old 12-17-2013, 11:31 AM   #2759
AVOturboworld
The crossover pipe is definitely the most complex piece in the entire system, barring the exhaust manifold.
Old 12-19-2013, 10:21 PM   #2760
AVOturboworld
Some more updates and more photos from the stage 3 testing.
We hooked up the boost controller and got a bit more torque, we got a bit more power going.
power is at the engine. The uncorrected torque figure works out to about 365ft/lbs
Now, this is a nice boost curve, well, plateau
Some pictures of the 3-inch exhaust
Testing will probably get held up a bit by the holidays, but we'll have more data in early January.
Old 12-19-2013, 11:04 PM   #2761
Pete156
I like to eat!
Can you say TORQUE?
Pete156 is offline   Reply With Quote
Old 01-08-2014, 09:05 AM   #2762
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Any updates on the stage 3?
TRD_07 is offline   Reply With Quote
Old 01-08-2014, 11:23 AM   #2763
AVOturboworld
I'll be heading over to Japan myself from today, so I should be able to get some more updates while I'm there, and finalize some details.
Old 01-08-2014, 02:59 PM   #2764
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by subatoy View Post
is this the first used AVO kit for sale?
http://www.ft86club.com/forums/showthread.php?t=55243
sorry for the random post its just that they are hard to find. I guess people love em.
That's the third. First was mine, @killerkid08 is selling his and noincname is third.
Old 01-09-2014, 11:53 PM   #2765
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
Keen to know when pricing will be revealed. Any plans for "upgrade pricing" for us early adopters.
RAN94A is offline   Reply With Quote
Old 01-11-2014, 08:54 PM   #2766
AVOturboworld
Got a couple hours free to cruise through the Tokyo Auto Salon 2014 - have photos going up in facebook as I get time, will put them up to our server later.
Here is the galleries on facebook:
https://www.facebook.com/media/set/?...9614524&type=1
Old 01-11-2014, 11:40 PM   #2767
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
@AVOturboworldwould this wga work with your turbo? The s3 turbo from the srt4 world is a tdo5 as well:
http://www.agpturbo.com/srt-4-stage-...-actuator-kit/
shaunsweeney is offline   Reply With Quote
Old 01-20-2014, 12:34 PM   #2768
AVOturboworld
Sorry about the delay, got back from Japan last Friday, and honestly was just wore out. Getting back into the swing of things today (since it's a holiday, and quiet...).
In regards to the above actuator, I cannot say because we haven't fitted one. And to be honest, we have no need - we've got actuator upgrades at 8, 12, and 15psi. All of them are adjustable for an additional 1~3 psi, so that would basically cover any range of boost you can run on this engine. Our upgraded actuators are also cheaper than the above, and they will fit.
But if you are planning to run higher boost levels, you are probably better situated by fitting an 8psi (or 12psi for high boost setups) and then getting a boost solenoid plumbed in and run off of ecutek. It'll cost a bit more in tune setup, but if you are planning to run more than 8psi then you should already be budgeting out for additional tuning and hardware.
Old 01-20-2014, 01:28 PM   #2769
AVOturboworld
I've updated the original post on the front with current info, updated dyno charts, information on the upcoming Stage 3, and fixed minor details that have changed over time.
Old 01-20-2014, 02:41 PM   #2770
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Sorry, this is an odd comment/question, but are you using Permatex UltraCopper in conjunction with the actual gaskets? I've read the pros and cons of doing this, I was just wondering what the reasoning was
protpibe is offline   Reply With Quote
Old 01-20-2014, 02:50 PM   #2771
AVOturboworld
We do use that, or something similar, quite often. For us the reasoning is simple, it does help with sealing it up.
Old 01-28-2014, 04:29 PM   #2772
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
@AVOturboworld , i was just wonder is there any way to order the turbo kit with the polished look instead of the stock oem black color?
sweetfrs is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
