Old 12-01-2013, 09:45 PM   #15
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by 6-Shift View Post
Would it be possible to do a Viper style (operated from a smartphone) style with our cars?
Yes, you could do the viper smart start on a M/T FRS .
Just make sure you hook up Neutral Safety green/black wire for (M/T) Its located at the ECM behind glove box. Its a white 31 pin plug, pin 16.
Its one of two wires you will need to tap into on the inside passenger side of the car. The second right side wire is for the passanger side door trigger.
You will also need an automotive relay to bypass the clutch switch. You use the relay so the car thinks your pressing down on the clutch during the remote start process.
milkesfrs is offline   Reply With Quote
Old 12-10-2013, 07:11 AM   #16
luv85
Drives: Grey GT
where did you get the wiring diagram from? I'm considering this kit..!
luv85 is offline   Reply With Quote
Old 12-11-2013, 03:02 AM   #17
luv85
Drives: Grey GT
[ame="http://www.amazon.com/Autopage-ADSALCA-Immobilizer-Bypass-Doorlock/dp/B001983S0Q/ref=sr_1_1?s=electronics&ie=UTF8&qid=1386745065&sr =1-1&keywords=idatalink"]Amazon.com: Autopage ADSALCA ADS Immobilizer Bypass and Doorlock: Electronics[/ame]
Can I use this instead of getting 2 of them?
Old 12-11-2013, 10:43 AM   #18
RojerLockless
RojerLockless's Avatar
Drives: Raven Fr-s
My goodness. Prop's to you but I think I would ruin my car just looking at all those wires rofl.
RojerLockless is offline   Reply With Quote
The Following User Says Thank You to RojerLockless For This Useful Post:
milkesfrs (12-11-2013)
Old 12-11-2013, 09:05 PM   #19
milkesfrs
milkesfrs's Avatar
Drives: hot lava
I found the wiring diagram here on the forum.
http://www.ft86club.com/forums/showt...t=remote+start
Old 12-11-2013, 09:12 PM   #20
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Old 12-11-2013, 09:15 PM   #21
milkesfrs
milkesfrs's Avatar
Drives: hot lava
You would need 2 of these
http://www.idatalink.com/product/product/product_id/1.
No way around it . I tried. You would flash one for the door locks the other one would be for the immobilizer.
If you don't use the 2 bypasses you will get a network error CEL or the unit you use wont work right.
The Following User Says Thank You to milkesfrs For This Useful Post:
luv85 (12-12-2013)
Old 12-12-2013, 08:04 AM   #22
luv85
Drives: Grey GT
@milkesfrs
Thanks for the info, Guess I'll just have to order 2 of them, bit pricey..
In Australian model, we have to press clutch to start the car, I dont know about US.
So did you do clutch bypass as well for the remote start?
Also think it might help if you could roughly tell me in which order you installed them..? eg, start button then immobiliser then....... etc
Thanks heaps, just want to organise as much as info I can before I order and install it.
EDIT: Cant seem to find installation guide on idatalink on their website, which guide did you use?
Old 12-14-2013, 03:53 PM   #23
milkesfrs
milkesfrs's Avatar
Drives: hot lava
@milkesfrs
Yes, I did the clutch bypass with a automotive relay.
Wiring for the clutch bypass :
Terminal ----> Where the wire goes
86 ------> constant 12v = battery
85 ------> ground wire from remote start while its engaged. On Advance Keys System this wire is usually reffered to as the status output wire or ground when running.
30 ------> one of the two clutch switch wires
87 ------> the other clutch switch wire
I ordered both units as a package . You have to install the smart key system with one of the idatalink units 1st. Than the push to start system with the other idatalink.
Here is the guides to install the idatalink units for the FRS / BRZ. The first file is for the door locks and the other file is for the immobilizer bypass
Old 12-14-2013, 03:55 PM   #24
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Here is some pics of the completed install. This system is very nice !
YamahaR86 (12-21-2013)
Old 12-23-2013, 09:55 PM   #25
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Got a question for you sir!
I've installed a regular remote start on a Scion FR-S. I've used only 1 Idatalink bypass and well everything work fine!
The only thing that still bug me it's the door lock. I try to control them via the door lock switch harness but the module don't seem to pulse right for the BCM.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 01-07-2014, 09:48 AM   #26
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Thank you for this write-up! I plan on tackling this in a month or so. I'm sure I'll hit you up for questions once I get closer.
kmbkk is offline   Reply With Quote
Old 01-11-2014, 11:35 PM   #27
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Advanced Keys Push to Start Install in progress For the FRS.
I'll be picking one up since a vendor gave me a better price than online for it.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-12-2014, 02:00 AM   #28
Brianbajnauth
Drives: Scion frs firestorm
I want to install a viper alarm/remote starter. Do I need 2 bypass modules ( key transponders) like you stated for your install? Thank you
Brianbajnauth is offline   Reply With Quote
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 07:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 03:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
