Drives: WRB BRZ
side skirt installation causing rust?
I couldn't find much information on this issue, but for those who drilled into the metal part of the car for side skirt installation, will there be rusting issues a couple years down the road?
#2 |
Drives: 2013 BRZ Premium Dark Gray Metallic
I just put a generous amount of grease on the screws and bolts.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#3 |
Drives: WRB BRZ
but with regular car washes grease will eventually be washed away in a year or two and that place is hard to reapply without taking off the side skirt which makes the drilled part vulnerable to rust.
i really want to install side skirts but i live in Toronto where there's a lot of salt in the winter. i'm wondering for those who drilled, is rusting a real concern or no? |
#4 |
Then use automotive grade silicone.
#5 |
Drives: Subaru BRZ Limited
Lithium white grease.
#6 |
Drives: RX-7 / BRZ
Drill hole, Grab a Qtip and dip it in some rust-prevention paint and swirl around the hole, Let dry 10-18min and install.
You want to got the extra mile do the above then use Transtar Amber Rust Proofing and it's 36" 360* spray flexible undercoating wand. Stuff the want into the holes and coat the piss out of the inside. Let it drip for the next 2 hours. Clean off the outside with some acetone and then install. Remember the rockers aren't sealed from the factory. The pinch weld is spot welded and there are holes to allow drainage and stuff to enter. So should you paint the areas where you drilled the holes you're not compromising it's ability to withstand rust anymore than OEM did. These cars will be rust buckets in a few years anyway. Just peel the wheel liner from the back of the front fender and in front of the tire on the rear wheel well and look what has already accumulated. |
#7 | |
Drives: 2013 Asphalt FR-S/2003 Honda Accord
did you end up install ur sideskirt? If so what kind of silicone / grease did u use to protect rust? Thanks |
| Side skirt dent/scrape | Tr1huynh | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 04-19-2014 04:20 PM |
| Chargedspeed Side skirt questions. | grostoine | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-15-2013 01:05 AM |
| FS: TRD Side skirt | gvan1998 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 05-20-2013 11:09 PM |
| WTB: TRD SIDE Skirt. | Filipino Royale | Exterior Parts (Aero, Lighting, Etc.) | 0 | 04-05-2013 06:59 PM |
