go_a_way1
Old 12-05-2013, 12:10 AM   #2829
jpit
Drives: Subaru BRZ
How do I tell which controller I have?
jpit is offline   Reply With Quote
Old 12-05-2013, 12:14 AM   #2830
fenton
The 5kw is about 50 percent bigger. Its more square looking. It has more expensive electronics in it and different programming to handle the additional load. I believe DR is also more sensitive... I actually had to turn mine down initially.
It will look like this:
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 12-05-2013, 12:33 AM   #2831
jpit
Drives: Subaru BRZ
I must have the older controller. Has one heat sink and a fan.
Old 12-05-2013, 12:42 AM   #2832
no chrome
She said member
Drives: fr-s firestorm
Count me in when it releases! Already have header, tune, and just did E85 swap today!
In reading over the last few days...
● someone said launch control and flat foot shift would cause problems, another pedal switch in series at top of clutch pedal will fix that, maybe we could tap into the original clutch switch?
● if batteries are mounted in trunk, how heavy gauge wire is needed for the 24v battery? Can both battery packs (12v and 24v) use common chassis ground?
● I believe the control box would be best placed in front of the radiator as high as possible
no chrome is offline   Reply With Quote
Old 12-05-2013, 12:44 AM   #2833
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Did someone on here say they had an odyssey battery with the system?
Installed Mods:
Old 12-05-2013, 01:14 AM   #2834
jpit
Drives: Subaru BRZ
I have an Odyssey PC 925 battery for the starter.
Old 12-05-2013, 09:15 AM   #2835
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The system does not have (or need) a BOV. But with launch control and flat foot shifting you'd have the compressor spinning at 100% with the throttle plate slamming open and closed.
To reduce voltage drop, you want the boost batteries as close as possible to the controller and compressor. Additionally, when you look at the weight of 1/0 cables (about 10 pounds), you would add a lot of weight to the car...which would have a more negative effect then the minimal improvement that you'd achieve with weight distribution. All of the batteries use chassis ground.
This has been discussed and I believe Rob supports the idea of this location. The down-side is that you have to remove the bumper cover to gain access. If you're comfortable doing that you should be good to go.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
Robftss (12-06-2013)
Old 12-05-2013, 09:33 AM   #2836
no chrome
She said member
With a second switch (in series with WOT switch) mounted at top of clutch pedal travel, it would deactivate compressor as soon as you press the clutch.
Old 12-05-2013, 10:04 AM   #2837
Gary in NJ
Gary in NJ's Avatar
I don't see a down-side to this approach.
Old 12-05-2013, 12:34 PM   #2838
no chrome
She said member
10 pounds of 1/0 wire is not what we were hoping to here.
lesser of 2 evils:
add ~15 lbs to the already heavy front end
OR drop ~25 lbs from the heavy front end and add ~50 lbs to the light rear end
Old 12-05-2013, 12:58 PM   #2839
Sojhinn
Sojhinn's Avatar
How do you like it? On the cold starts for e85 its already starting to take 2 starts before the car rumbles to life. Little worried about the little battery if I have to do 5 starts in a row. What was the cost?
Installed Mods:
Old 12-05-2013, 01:02 PM   #2840
bfrank1972
Drives: 2013 FR-S Argento
lesser of 2 evils:
Yet another great aspect to this rig - the overall setup is so simple, you can probably customize it how you like (though I'm sure at that point whatever warranty Rob provides may well be null and void).
Old 12-05-2013, 01:19 PM   #2841
Gary in NJ
Gary in NJ's Avatar
Alternately Rob suggests this battery.
http://www.atbatt.com/ps-12350.asp
This is also a Power-Sonic 12V SLA battery with NB terminals but this one is a 35ah battery vs. the 21ah of the PSH-12180FR. While I don't really need the extra starting power, I do have concerns with parasite losses while parking the car at an airport for a weak.
This battery fits a little better with the boost batteries (closer in size) and is half the price of the Odyssey PC 925 and has about the same output.
Sojhinn (12-05-2013)
Old 12-05-2013, 01:20 PM   #2842
Sojhinn
Sojhinn's Avatar
Thanks for the heads up.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
