Old 12-01-2013, 04:17 PM   #1
jonbonazza
Rubber smell sometimes on cold start
Anyone else notice a strong rubber smell when starting the car in the morning in cold weather? It happens as soon as I start the car and before I even begin to move. After a minute or 2 of driving, it goes away completely.
Any ideas?
I should note that the only mods I have are an Invidia fp, Invidia N1 catback, an AEM intake and a stage 2 FA20Club tune.
jonbonazza is offline   Reply With Quote
Old 12-01-2013, 04:43 PM   #2
Any ideas?
No rubber smell here.
However, I always have an idea (most of which don't work); you might check the serpentine belt tension when it's cold .... before you crank er up. Maybe the tensioner pulley sticks a bit when it's cold ....
jonbonazza (12-01-2013)
Old 12-01-2013, 04:56 PM   #3
jonbonazza
Well, honestly, it wasn't like that from the factory and it didnt start happening until I installed my exhaust and tune (did at about the same time, so not sure exactly when it happened). I can't imagine either of those having anything to do with this, though so I am at a loss.
Old 12-02-2013, 06:09 PM   #4
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
I have the same smell! Only when air is on. Not so much rubber as plastic? Mix of the two? I can't figure it out. Had my exhaust on for a couple months now and been fine in other cold-weather. Just today.
grgonium is offline   Reply With Quote
Old 12-02-2013, 07:38 PM   #5
jonbonazza
Hmm... I never really paid attention to if the air was on when it happened...
Sent from my Nexus 4 using Tapatalk
Old 12-02-2013, 07:39 PM   #6
grgonium
grgonium's Avatar
Called a Toyota tech. Said it might be transmission fluid leaking on the exhaust
Old 12-02-2013, 07:40 PM   #7
jonbonazza
Well, mine definitely doesnt smell like tranny fluid and there are no drips, so that's not the case for me.
Old 12-04-2013, 03:51 PM   #8
Razz
Razz's Avatar
Drives: Fast
Some new exhaust will smell for awhile until they are broken in. They are covered in a light oil to revent corrosion.
Also, look for plastic on they system, you may have run over a plastic bag and it's melting.
Razz is offline   Reply With Quote
Old 12-04-2013, 05:34 PM   #9
andrew20195
Drives: 2013 Subaru BRZ
Normally good points, but in either case the smell would be more apparent when the vehicle is warmed up rather than on cold start.
I would lean more towards the tensioner/belt theory. Is there any belt squeal, even just a brief chirp, when the car is started?
andrew20195 is offline   Reply With Quote
Old 12-04-2013, 06:32 PM   #10
jonbonazza
Its def not the exhaust oils. I had that for a while, but its gone now. There is 0 squeak or squeel on startup
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Burnt Rubber smell Fizzle Issues | Warranty | Recalls / TSB 22 01-06-2013 10:10 PM
Anyone else smell rubber? pinoyplaya BRZ First-Gen (2012+) — General Topics 15 09-24-2012 04:40 AM
