Old 11-30-2013, 02:47 PM   #155
Ethan
Drives: Subaru BRZ
Originally Posted by mit_peid View Post
Is leaking a common phenomenon with this kit and install? I am highly interested in buying it with the inter-cooler, but I'm thinking about having someone else [who knows what they're doing] install and tune it. I was thinking about going out-of-state (FT86speedfactory) to get the kit to save on tax and shipping (and it seems like they may give an additional 2%). Want to pull the trigger in the next six months as I check on these forums daily to check up on your guys' experience with the kit. Hopefully they're get their CARB-approval sometime in the next 6 months too.
I've had no leaking problems (knocking on wood). SC installed in August and FA20 club's version of intercooler installed a couple of weeks ago. I have had no need to refill the fluid reservoir, either. I had a shop install the intercooler and they had several issues with the kit-- incorrect sized fittings and cheap hoses. However, the FA20 version has a bigger fluid reservoir and larger heat exchanger. The fluid reservoir also has a bigger opening to allow you to put ice cubes in it when at the track for extra cooling.
Ethan is offline   Reply With Quote
Old 11-30-2013, 11:08 PM   #156
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Some great info to share.
I drove from Durban on the coast to Johannesburg, 600km, which is 1753m above sea level, air very thin.
I went to a supercharger specialist to resolve the leak issue, as we could not establish where the leak was coming from, after removing the back and sealing the L connectors.
The mechanic used Carb Spray and smoke, which identified the leak coming from the two inlet pipe into the cooler lamina.
Removed the kit and found the technician who installed pinched the boost O rings on the small aluminum pipe which seals the boost and the coolant. Major leak.
We ran some logs and @Delicious Tuning tune a map for the altitude and sent through.
Part of my visit was to attend a Toyota, Mazda charity Dyno day, which I was challenged to take the new Sprintex SC Delicious Tuned against the Vortech Visconti Tuned
To ensure equal comparison we fitted exact mods, so both cars had
Header, overpipe, full 3" performance pipe, AFE air filters.
Being my first visit to Johannesburg the night before the event, I went to the same dyno the Vortech had previously run and did 2 pulls.
I got 197hp and the Vortech had got 215hp, we plotted the graphs on top of each other and it looked as we have all seen where the Sprinted pulls from low down and the Vortech take over from 5500 rpm and get higher power top end.
Next day I met up with the Vortech car, we filled our cars with 91OCT and put 2 cans of Torco octane booster, to further ensure both cars identically matched. We drove 20km to the event.
Now this was an absolute eye opener for everyone present.
I ran first, 4 gear 2000rpm to 7400 rpm
251hp 277Nm
The Vortech ran direct after me
245hp 255Nm
We did 3 pulls on each car which further showed a interesting statistic
I got 245hp on my first run and got stronger each pull, with highest being run 3
The Vortech got highest on run1 and lost power each run after.
The Sprintex Intercooled kit out performed the Vortech in every way
To rub salt in the vorthech driver wounds, we did 0 to 100 off the line runs, 2 runs I beat the Vortech by a full cars length.
I'm awaiting dyno graphs plotting both cars on the same graph.
I want to say a huge thanks to Bill @Delicious Tuning for helping me sort out the leaks and sending updated tune at early hours of the morning.
I look forward going back home and fine tuning the car on the coast.
Ryan86 is offline   Reply With Quote
The Following 9 Users Say Thank You to Ryan86 For This Useful Post:
calispec (12-01-2013), Calum (12-01-2013), cantholdanymore (12-01-2013), Freeman (12-01-2013), Lawnik (12-01-2013), normancw (12-01-2013), TemeCal (12-01-2013), whataboutbob (12-03-2013), xjohnx (12-01-2013)
Old 11-30-2013, 11:58 PM   #157
xjohnx
Grip>Slip
xjohnx's Avatar
this can't be. i saw on the youtubes that the innovate is crap and vortech is king! how could the youtubes be wrong!?
Old 12-01-2013, 12:01 AM   #158
DriftEm
DriftEm's Avatar
@Ryan86, I'm glad you figured it out and thanks for sharing, I'm having mine installed on Monday and will let the technician know to pay attention to the o-rings.
DriftEm is offline   Reply With Quote
Old 12-01-2013, 12:17 AM   #159
Ryan86
Road Warrior
Ryan86's Avatar
I have 300 witnesses and the dyno to prove it.
I've watched all the videos and posts aswell, however, how many have had each car identically set up on the same dyno run straight after each other.
This test could not have been more accurate.
Ryan86 Believe or not
Oh and I have not seen the test done comparing Intercooler vs Intercooler kit....
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
shaunsweeney (01-13-2014), xjohnx (12-01-2013)
Old 12-01-2013, 12:26 AM   #160
Ryan86
Road Warrior
Ryan86's Avatar
Great stuff, make sure you do all the little things I've explained through my findings before you install, once on its a Biatch to sort out.
Something else we did while I had the kit off.
At the back of the charger on the right if you standing looking at the back of the charger is a small screw, this is for boost connection. I fitted an 4mm screw in with pipe about 30 cm long, so I can read boost on a dyno or even run into the car for a boost gauge. Sprintex pointed this out to me, as I could not read boost via the ECU due to using the stock map sensor which only goes to .1 bar 3 psi.
Worth considering.
Good luck with your install.
The Following User Says Thank You to Ryan86 For This Useful Post:
DriftEm (12-01-2013)
Old 12-01-2013, 09:19 AM   #161
xjohnx
Grip>Slip
xjohnx's Avatar
Just to be clear, i was being sarcastic and didnt' doubt you for a second
Old 12-01-2013, 09:21 AM   #162
xjohnx
Grip>Slip
xjohnx's Avatar
Worth considering.
What? never knew about this. I've been in the process of modifying my MAP/IAT sensor plate to install a hose barb fitting for a boost source. I'll have to take a look at this when i have the blower off to install the IC.
Old 12-01-2013, 10:55 AM   #163
Ryan86
Road Warrior
Ryan86's Avatar
Haha, got me.
Old 12-01-2013, 11:01 AM   #164
Ryan86
Road Warrior
Ryan86's Avatar
Something else to ensure is to use Ethylene glycol coolant in your intercooler.
And do yourself a favour, take off your IAT and see what difference in performance you get. I removed and ran dyno got almost 10whp more gains.
Now I have not got facts on the IAT, but my temps are lower without the IAT and car pulls stronger. Need to investigate this a bit more.
I also have found the blue gates belt tighter than the belt supplied, got less drag, IMO.
Old 12-01-2013, 11:21 AM   #165
xjohnx
Grip>Slip
xjohnx's Avatar
I don't actually have the IAT sensor connected at the moment, still using the one off the MAF on my current tune.
I went to install a new blue gates belt a couple weeks ago and couldn't get it stretched around the pulley and it was too cold out for me to spend more than 5 minutes on so I ended up switching to the black one, which definitely went on a lot more easily.
Ryan86 (12-01-2013)
Old 12-01-2013, 12:40 PM   #166
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have your IAT compensation tables been adjusted correctly? I wouldn't advise disconnecting the IAT sensor. Where is yours, MAF or MAP? TBH the MAF sensor temperature won't be accurate for the air temperature entering the engine anyway.
.: Stealth 86 :.
Kodename 47 DJ:
mad_sb (12-03-2013)
Old 12-01-2013, 07:26 PM   #167
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
@Ryan86 Great numbers and congrats on beating the vortech.
Just curious, are you running any cooling mods? Oil cooler or upgraded rad
Lawnik is offline   Reply With Quote
Old 12-01-2013, 08:27 PM   #168
xxscaxx
Drives: 2013 SWP BRZ
I don't know of this fitting either and I just had the back of the charger off.
xxscaxx is offline   Reply With Quote
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 08:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 10:13 AM
