Old 11-27-2013, 09:29 AM   #15
infinite012
Drives: 13 DGM BRZ Ltd
You likely have a short with one of the plethora of electrical mods you have done.
Get rid of the HID kit first. See what happens.
Get rid of something else next. See what happens.
Rinse and repeat until your car is back to stock, then sell it.
infinite012 is offline   Reply With Quote
Old 11-27-2013, 10:00 AM   #16
Rico415
Rico415's Avatar
Drives: 13FR-S
Originally Posted by ScionFR-S View Post
so what battery should i go with? I'm not trying to spend 200 on a battery lol and is it easy to install? i have HIDs Spyder Tails, Fogs , LED side markers and signals and DRLs and reverse light
All them mods and you are worried about $200 for a good battery...
Seriously ......
Depending on how much extra load you added to this system you may need a bigger alternator to keep everything working as intended if driving along is draining the battery because of the extra load you could be fooked....
Rico415 is offline   Reply With Quote
The Following User Says Thank You to Rico415 For This Useful Post:
JDM FRS (11-28-2013)
Old 11-27-2013, 11:51 AM   #17
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I've seen quite a few threads where people are having electrical problems after pimping out their lights. Maybe it's a sign?
Old 11-27-2013, 05:36 PM   #18
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
yeah but my question is this why does the car work when i take the battery terminal off and put it back on, or why does the steering wheel shake sometimes when I'm going slow and turning ? i tested the alternator and it works bc i undid the terminal as the car was on
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 11-27-2013, 06:10 PM   #19
Foobar
SLO NO MO
Foobar's Avatar
That's not going to be an accurate test as your car's electrical draw at idle is going to be different while you're driving around with various electronics on.
Easiest thing to do is to get the battery and alternator tested. If those are good, then you've got an electrical problem elsewhere and now you're going to have to play the take one piece out at a time until you find the problem game.
Old 11-27-2013, 08:02 PM   #20
ScionFR-S
ScionFR-S's Avatar
Okay and should a regular mechanic be able to test this ? Weird as my car was done today and had no problems
Old 11-28-2013, 02:01 AM   #21
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Go to autozone or orielly and pull the battery in the parking lot. They can test it in store.
Sent from my HTC One using Tapatalk
JDM FRS is offline   Reply With Quote
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 10:35 PM
Damn odor wont go away Yruyur Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 05-05-2015 11:41 PM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 09:57 PM
Front bumper wont come off! help! mashal Cosmetic Modification (Interior/Exterior/Lighting) 14 12-17-2012 03:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
