Old 11-09-2013, 05:48 PM   #1
subyboy
Drives: 13' swp brz limited
help what tires should i run
ok guys so heres the deal im getting some wheels for free they are 17x9 in the front and 17x10 in the rear only problem the wheels r 5x114 so i will need to run a spacer. so heres the problem i was wondering what tires i would need to run currently for the rears i was thinking 225/50/17 since it will stretch but i was wondering it i would clear. also to note i am stock height but will be lowering the car on either eibach pro sport kit or h and r race springs please any help would be greatly appreciated thanks
subyboy is offline   Reply With Quote
Old 11-09-2013, 06:13 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
50 sidewall is disgusting. Monster truck status.
If you want a stretch, I would do 215/45 up front and 235/40 rear. You could do a 225/45 up front but that's tall. That's about the same as a 255/40 which is a lot of meat and your front sidewalls would be noticeably larger than the rears.
If you want something with a little less stretch, you could do something like a 235/40 up front and a 245 or 255/40 in the rear.
Old 11-09-2013, 07:21 PM   #3
subyboy
well the only reason why i bought a 50 was because i wanted it to stretch but have a little more meat than usual i guess ill try to find a shorter profile
Old 11-15-2013, 05:56 PM   #4
subyboy
so just bumping this still looking for some advice im thinking about looking for a 245/40 for the rear since ive seen an 11" wheel run it with spacers the fronts im looking at either 215/40 or 225/40
Old 11-15-2013, 06:06 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What offset are the wheels you want? Also, you will need camber bolts and possibly coilovers. And may need other suspension parts to get a 10 with a spacer to fit.
The hub conversion may be cheaper than the other parts put together. Something to look into. My $0.02
Old 11-17-2013, 03:38 PM   #6
subyboy
Hey just to answer some questions u asked the wheels r really high offset they were meant for an nsx fitment in the 90s when wheels were made for the correct fitment haha but yea I am going tobbuy coilovers eventually just for now Im looking at springs
Expensive light Rims+Expensive light Tires or Suspension+Cheaper Rims+Cheaper Tires? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-09-2013 06:57 PM
TIRES, TIRES, TIRES! @ Pure Automotive Performance Pure Automotive Wheels and Tires 1 02-04-2013 02:32 PM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
