Old 11-05-2013, 03:01 AM   #85
pmccut
Drives: Blue Subarus
Originally Posted by cf6mech View Post
OEM Rod bearings ! ....that's what everyone who truly have pushed this motor 20 psi and up (Crawford ) have had failed. Including me.....guys at 15 to 20 are on borrowed time , how much time is anyone's guess. There is differences of opinions of why OEM isn't holding though. On my second build I'm not taking any chances and running ACL race rod bearings.
Interested to hear more about your issues. I'm at 15-16 on 91, going to bump it up to 20+ with E85 (gt28) once this tank is up.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 11-08-2013, 11:25 AM   #86
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We added the short block to our site
http://fullblownmotorsports.com/fbm-...lt-short-block
FullBlown is offline   Reply With Quote
The Following 4 Users Say Thank You to FullBlown For This Useful Post:
Alhammadi (11-08-2013), Dipstik-sportech (11-08-2013), mack4477 (11-08-2013), tech4pdx (11-08-2013)
Old 11-08-2013, 06:44 PM   #87
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Full Blown Built Short Block
Can race bearings be optionally added to that offering? Also, is an upgraded crank a requirement for a 400whp twin screw setup (I'm going to the Sprintex S5-335 when released)? Are there oiling issues with stock crank under boost? This car will be mostly street driven with occasional track days.
tech4pdx is offline   Reply With Quote
Old 11-09-2013, 11:44 AM   #88
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The OEM crank looks to be holding up very well. An upgraded crank is not necessary.
Race bearings will be added once they are available.
The Following User Says Thank You to FullBlown For This Useful Post:
tech4pdx (11-09-2013)
Old 11-10-2013, 05:58 AM   #89
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by Dipstik-sportech View Post
Yes this^^^. I mean what says the acl race bearings will even be any better? If it's an oiling issue then they'll burn up as well.
.....Race bearings have extra oil clearances at the detriment of NVH,....that's the point.
cf6mech is offline   Reply With Quote
Old 11-10-2013, 06:03 AM   #90
cf6mech
Proceed with caution, if your stock on fuel system, 20PSI is going to be hard to do, safely.
Old 11-10-2013, 06:12 AM   #91
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I'd be surprised if ACL offer any off the shelf FA20 bearings in the RACE series, as ACL are closing their doors next year.
They haven't been able to secure a buyer for the company now it's in receivership:
http://www.abc.net.au/news/2013-07-3...s-lost/4853524
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
Sportsguy83 (11-10-2013)
Old 11-10-2013, 07:39 AM   #92
tech4pdx
Make love
tech4pdx's Avatar
@JP Sad news indeed..
Old 11-10-2013, 08:40 AM   #93
Dipstik-sportech
Dipstik-sportech's Avatar
So they're made slightly larger diameter that stock for more crank to bearing clearance? Y not just polish or turn the crank down to achieve the same result?
Old 12-17-2013, 12:43 PM   #94
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We received more Arias/FBM Custom pistons in stock with upgraded wrist pins. You can see in the photo of the standard duty pin versus our upgraded pin.
Our pistons are designed to handle 30+ psi of boost with larger rings, skirts as well as other advantages over most off the shelf piston.
The Following 2 Users Say Thank You to FullBlown For This Useful Post:
Dipstik-sportech (12-17-2013), WHITE (01-20-2014)
Old 01-20-2014, 01:28 PM   #95
FullBlown
FullBlown's Avatar
Drives: Scion FRS
You know the season is around the corner when there are motors to be built. We have built many FA20 motors and looking forward to doing more this coming season.
Dipstik-sportech (01-20-2014), mack4477 (01-21-2014), SkAsphalt (01-20-2014), WHITE (01-20-2014)
Old 01-21-2014, 06:59 AM   #96
Dipstik-sportech
Do you just lock him in that room and say he can't come out till he's built a certain number of short blocks?!
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
DriftEightSix (01-21-2014)
Old 01-21-2014, 07:56 AM   #97
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Haha, that room is the warmest part of the whole shop. I don't think he minds being in there.
Our engine building room is climate controlled to make sure all clearances are checked at room temp.
crook (01-25-2014), Dipstik-sportech (03-07-2014), Hawaiian (03-10-2014), Nomed Alucard (01-21-2014)
Old 03-07-2014, 10:09 PM   #98
sofargone561
Drives: frs
I am liking the work FBM is putting in on these motors so far.
Will you be doing anything with the Darton sleeves?
I will be waiting until more head parts come out for the car and possibly a stroker kit before I build the motor.
sofargone561 is offline   Reply With Quote
The Following User Says Thank You to sofargone561 For This Useful Post:
FullBlown (03-10-2014)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
