Old 11-07-2013, 04:08 PM   #85
Chee-Hu
Chee-Hu's Avatar
Originally Posted by Sportington View Post
The shop manager is indicating that Scion (Scion rep was there today) has yet another TSB revision in the works - due in 2 weeks or so. Part is being revised yet again, as there have been failures with the TSB version 2 (Oct 17th, 2013) part.
That's awesome!
Chee-Hu is offline   Reply With Quote
Old 11-07-2013, 06:23 PM   #86
FR-S Matt
No failure here. So far, working perfect.
Old 11-07-2013, 08:15 PM   #87
AznBRZer
Drives: 16 CBS WRX Limited
AznBRZer is offline   Reply With Quote
The Following 2 Users Say Thank You to AznBRZer For This Useful Post:
mwjcyber (11-07-2013), SubiePig (11-14-2013)
Old 11-08-2013, 05:50 PM   #88
TeamZleep
Drives: 2013 FRS/2011 TDI
UPDATE
Ok. So A week has gone by. 1400 miles of steady miles put on the car. (drove from Orlando-Miami-Orlando-Tampa-Orlando, rest of the miles have been here and there at work going from site to site)
NO CRICKETS. It's like they packed their bags and left. I'm so content right now... I can't even explain. I have no idea about this next part number... But I have the most up to date installed and needless to say... I'm happy.
When I pull up to a security gate, I don't feel like I paid 24k for a hooptie anymore.
TeamZleep is offline   Reply With Quote
Old 11-14-2013, 01:36 AM   #89
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
YMMV but Shell gas works for me before that I was pumping 76. Out in CA we only get 91oct so it's hard to fund 93 or anything more. I don't know what is different about Shell gas but it works and others here have also confirmed this works for them. One third tank now and no more chirping, it stopped almost immediately after filling with Shell.
garfull is offline   Reply With Quote
Old 11-14-2013, 03:07 AM   #90
86Sam
86Sam's Avatar
Drives: white out 86
Originally Posted by garfull View Post
Don't know why this isn't more common information but pumping Shell gas works. Out in CA we only get 91oct so it's hard to fund 93 or anything more. I don't know what is different about Shell gas but it works and others have confirmed this as well. One third tank now and no more chirping, it stopped almost immediately after filling with Shell.
I'll go ahead and confirm that it doesn't work. I've own an FRS since June 2012 and a huge fan of Shell gas before owning one. I've pump over 20k miles of premium gas from shell 93 oct and I've had loud chirp since 1.5k miles. Chirp still here all day eer day
86Sam is offline   Reply With Quote
Old 11-14-2013, 03:38 AM   #91
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
In SA the highest rated Octane fuel available is 95 Octane (RON I think) and even this is of questionable quality and can vary drastically between stations at times. I also had the noisy crickets. Recently I tried some Liqui Moly Octane Plus for a run we did to see if I can experience what the car would feel like with the proper fuel. Noisy crickets are gone and for this last tank I only used a 1/4 bottle and have run the previous tank down to about 6 litres. Car was a lot smoother through the revs and quieter at idle.
Not sure if it's a fix but it helped me a bit.
I'm on about 26000km (approx 16230 miles) and this is my everyday runner with no real mods at all.
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx2/2527.jpg/$file/2527.jpg
Vic_RSA is offline   Reply With Quote
Old 11-14-2013, 05:20 AM   #92
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
94 oct petro canada fuel contains 10-15% ethanol, shell 91 contains 0% ethanol i went from petro to shell after i noticed the crickets @ 500 kms, ever since then i have yet to hear them again. My ODO is currently @ 7500kms, dont know how a fuel pump swap out would fix this issue is there a more technical read up on this ?
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 11-14-2013, 08:53 AM   #93
mainstream
mainstream's Avatar
You need to check out this thread:
http://www.ft86club.com/forums/showthread.php?t=9836
Also there is a new TSB covering the chirping for most 2013-2014 models
mainstream is offline   Reply With Quote
The Following User Says Thank You to mainstream For This Useful Post:
SciOnDrifTtSlIdeR (11-14-2013)
Old 11-14-2013, 03:41 PM   #94
garfull
garfull's Avatar
Works for me and a bunch of other owners over here. Updated to YMMV. Perhaps its regional. Just throwing it out there because I only heard it though meeting other members who have switched.
Old 11-14-2013, 03:51 PM   #95
forzajuve
Drives: Ultramarine 86 - 6MT
Toyota wouldn't check in to my claim of the chirps because I have the Perrin Inlet Tube installed. They said if I brought it back in with the stock set up they would check it out.
forzajuve is offline   Reply With Quote
Old 11-14-2013, 03:52 PM   #96
forzajuve
Any update on whether or not this is offered to Scion owners?
Old 11-14-2013, 03:53 PM   #97
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Time for a new dealer my friend. You're current dealers an a$$.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 11-14-2013, 04:09 PM   #98
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm in your region, when I had the chirps Shell was louder than other brands, but I only tried it twice and it could be chalked up to the phases of the moon. At this point I go for the most convenient/cheapest station and my chirps disappeared completely around 10k miles, going on 16k without a peep. Original pump, 12/12 build.
ineedyourdiddly
Cricket Type Noise From Inside buddy32 Issues | Warranty | Recalls / TSB 5 03-27-2014 02:25 PM
Took my car to the dealership concerning the cricket noise. Ludacrits Issues | Warranty | Recalls / TSB 6 10-14-2013 04:18 AM
Chirping/Cricket Fix Out? deeranged Issues | Warranty | Recalls / TSB 15 10-02-2013 06:43 PM
Cricket TSB [deleted] Southern California 25 06-05-2013 07:01 PM
New trans, window, and cricket fix! foney_email Issues | Warranty | Recalls / TSB 11 03-14-2013 06:35 PM
