Old 10-27-2013, 10:50 PM   #85
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Will it make the same difference as a complete oil cooler? Or if we still wanna track our cars should just go down the oil cooler root?
Old 10-28-2013, 02:40 AM   #86
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
We need more people like CARNZ ^^^^^^^^^^^^
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 10-28-2013, 02:42 AM   #87
ft_sjo
Drives: GT86
Originally Posted by CARNZ View Post
Just read thru this thread. I have had the same idea to adapt the FXT oil cooler onto my FA20.
Tomorrow at work(I work at a Subie dealer), i'll see if i can bring in one of our in-stock FXTs and look over the coolant line routing to see what all we need to make this happen.
I'll lift up both the BRZ and FXT to try to do some comparisons.
If you do, please take a considerable amount of detailed photos and share here.
Old 10-28-2013, 04:05 AM   #88
Kostamojen
Basically the same difference, with none of the drawbacks of air-oil coolers. Might not cool as much at higher speeds/temps, but the oil temps just need regulating more than anything else with this car, not super-cooling unless you are running FI and constant track days.
As mentioned before, not only the BRZ STI concept, but other stock models that both Toyota and Subaru have run at track events or test drive events have had the OEM Subaru oil coolers installed.
I took a lot of photos, but theres not much to see unless you can order all the parts and have them sitting on a counter to take photos of off the car.
Old 10-28-2013, 04:53 AM   #89
PantsDants
Drives: Scion FR-S A/T, Whiteout
So I haven't investigated this myself very thoroughly, so correct me if I'm off-base here, but is there a specific reason why you can't route the coolant the same way the Cusco kit does?
Oh, looks like it's because the Cusco routing won't function as an oil warmer because coolant won't flow until the thermostat opens. Carry on.
PantsDants is offline   Reply With Quote
Old 10-29-2013, 08:11 AM   #90
CARNZ
CHECK ENGINE
Drives: 2004 STi
Talked to sales after work yesterday, they sold the last FXT over the weekend. As soon as another one gets in I will be looking it over.
The BRZ and FXT upper oil pan housings are different. On the BRZ you can see where a block off plug is installed in place of the oil cooler nipple. According to the parts catalog you cannot buy that nipple separately from the upper oil pan assembly, so a little more research is needed once I can compare the two side-by-side.
It definitely is do-able, though.
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 10-29-2013, 08:14 AM   #91
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Originally Posted by wootwoot View Post
This has been discussed several times. The consensus seems to be that it is an oil warmer more than an oil cooler. That is, it helps the oil get to operating temperature in cold climates. The exchanger is so small that it wouldn't cool the oil very effectively, even for a daily driver.
I must be the only person in the world who needs this. I can't get my oil to operating temp to have fun before I get to work. Yes my drive is short......
SubaSteve is offline   Reply With Quote
Old 10-29-2013, 11:11 AM   #92
Kostamojen
I ordered that plug yesterday so I can get the thread measurements and start looking for a nippled version of that plug in the aftermarket. I also put together a small parts lost to start with but I'm still not certain how to route all the coolant lines.
Old 10-29-2013, 01:50 PM   #93
CARNZ
CHECK ENGINE
Drives: 2004 STi
Cool, hopefully you find something easily.
I am looking over the coolant flow charts to see where we can get a source of pre-thermostat flow to feed the cooler if a fitting cannot be sourced.
edit:
I went ahead and ordered the oil cooler and it's parts along with a plug myself so I can measure it and try to source something locally.
Once the cooler and pieces come in I will get working on what we need to do.
parts list:
092315002 x4 - Hose Clamp
11021AA190 - Plug, Cylinder Block
14050AA970 - Pipe Complete, Water
21311AA170 - Oil Cooler Complete
21317AA070 - Connector, Oil Cooler
21328AA220 - Pipe, Oil Cooler
807609061 x2 - Hose 9x16x52x52
807611221 - Hose 11x18x47x47
808206010 x4 - Bolt 6x12x12
99078AB330 - Hose, Water
805918010 x4 - Hose Clamp
Old 10-30-2013, 08:49 PM   #94
Kostamojen
Alright, this is what I found for the coolant plug fitting.
Its a 14mm 1.5 thread pitch plug. I have an adapter from that to NPT to a 1/2" hose.
(The plug is on the left)
Old 10-30-2013, 08:58 PM   #95
Kostamojen
edit:
parts list:
This is my parts list so far, I haven't ordered anything yet.
14050AA990 is the heater pipe on the Forester that has a secondary nipple for the oil cooler. I probably wont be buying it though because its expensive (like $60) and might not even fit correctly...
I didn't list any bolts or clamps yet.
Old 10-30-2013, 11:03 PM   #96
CARNZ
CHECK ENGINE
Drives: 2004 STi
I figured what the hell on the water pipe, if it looks like it won't come close to fitting i won't remove it from the bag and will have my parts manager return it.
I spoke with her when I placed the order and she told me anything I don't need that I haven't opened she can put on a return to subaru.
If everything goes to plan I should have the oil cooler on tomorrow evening.
Old 10-30-2013, 11:25 PM   #97
s2d4
s2d4's Avatar
Well, if you come up with an OEM parts list. I am happy to order through your work due to the efforts made.
Others may be the same, so your manager should be all good either ways.
Old 10-31-2013, 12:14 AM   #98
Kostamojen
Found another fitting that might work:
The Following 2 Users Say Thank You to Kostamojen For This Useful Post:
CARNZ (10-31-2013), s2d4 (10-31-2013)
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 07:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 08:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 04:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 10:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 09:45 PM
