#113 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
Even im pushed to learn more, and i haven't been this active on a forum since 02-04 when i had a s14 i was trying to build.
#114 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#115 | |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
#116 |
Drives: 2012 WRX Sedan
The curve looks similar to this
![]() (I know there are some big differences between the engines though...) Yet the TQ on the BRZ engine doesn't seem to drop off, which makes me think there's some room up top. |
#117 |
Kuruma Otaku
So some of the exhaust energy can be transferred to other cylinders to assist in scavenging.
Because titanium. |
#118 | |
Drives: '06 AM V8V Coupe
As a general disclaimer, everything I say is based on empirical evidence I have seen and extrapolated using basic mechanics/thermo, I have no actual experience with this stuff, but hopefully that'll change someday soon. And SUB, 2010 would be the last time I was in a physics class, but not the last time I was in high school.
#119 | |
GL 86!
Drives: Maybe FR-S... maybe not
What engines really really hate is lugging. This is where the engine is very low on RPM and fuel delivery is high under load. The engine is trying to increase engine rpm to an acceptable level so there is actually power and or avoid stalling. You find that after ignition the forces on the piston are extremely high because it's [the piston] not moving at the speed the engine is designed to run at. The 2ZZ makes a particular knocking noise when it's lugged, some but not all engines do. In addition it's harder on engine and drivetrain components on (lets say) a SUV with a trailer heading up a steeply (20%) graded hill highway on a high cruising gear. If the engine does manage (by some miracle) to keep a stable low rpm then you may face cooling issues with a long enough hill because the water-pump isn't going to be rotating at an acceptable rate to provide the quantity of coolant that will needed to be circulated (same with the automatic transmission fluid). So in this circumstance it's actually advisable to drop down a gear or two and make some noise because it will cause less wear on the drivetrain. Most people are too scared of destroying their engines to do this, instead the auto tranny will overheat and possibly pop... their loss. In addition you have something designed like the 2ZZ that makes it's maximum 131 lb-ft torque at 6700rpm (127@4400 is stated), it's "not happy" below 4000rpm (especially at WOT) under load. It's funny because it's an NA engine which means it responds instantly but is lazy in the low rpm range. |
#120 |
I hear this "lugging" thing a lot, but I can't decide whether it actually makes sense or not. The friction in an engine doesn't start going up until well below idle speed, and at higher speeds the components are definitely under a lot of stress. Efficiency does go down near 1000-1500rpm typically but I think this is probably because the burning charge has too much time to cool down. The only thing I can see is that the rods are under max compression for a longer period of time but I don't think this is much of an issue especially for naturally aspirated engines.
old greg do you mind sharing your wisdom? :P |
#121 |
That Guy
Drives: 2013 asphalt FRS MT
It has more to do with oil delivery to the journal bearings. As engine speed lowers it's harder for the hot oil to develop a hydrodynamic wedge. This leads to metal on metal contact which as Im sure you know is bad. There are some things that can be done to extend the low rpm performance of the bearing but all to my knowledge negatively effect the high rpm performance, in one case even causing the bearing to pump oil against the oil pump.
#122 | |
The headers/exhaust don't get rid of the dip. |
#123 | |
GL 86!
I've never seen a document on any engine lug tests. So this will interest me. |
#124 |
Drives: '23 BRZ
At low engine speeds, the hydrodynamic wedge that supports the conrod bearings isn't as strong. Consider the film strength of the oil in the bearing gap with no relative motion. Weak. Applying full torque is a bad idea at low engine rpm...
At high rpm when inertial loads dominate, the high speed gives a MUCH stronger hydrodynamic wedge to support the conrod. |
#125 |
How relevant is this? If BMW feels safe giving their engines full boost at like 1200 rpm or something then it's probably safe to say these effects only exist around 1000 or below right?
I guess it makes sense that the oil would get squished out of the bearings more easily at low speeds, thanks for the info. Didn't think of that. |
#126 | |
GL 86!
Obviously this depends on many factors of the engine during lugging (including the engine itself). RPM conversely affects both oil pressure and forces on the bearings and respective journals. I would be interested to see at what rpm and parameters the hydrodynamic film breaks down, throw in some different oils, different temperatures... |
| 2013 Porsche Boxer is revealed early | DIG1992 | Other Vehicles & General Automotive Discussions | 62 | 09-05-2012 12:26 PM |
| Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
| Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 05-02-2011 03:30 AM |
| Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
| More proof of FT-86 Boxer engine appears in logo | Hachiroku | Engine, Exhaust, Transmission | 33 | 01-03-2011 01:47 AM |
