#43 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
^^^that was my thought. It's actually pretty fun to play with for a little DD setup.
#44 |
Drives: 2009 Toytoa Tacoma 4x4 Dbl Cab LB
The more I think about this the more my mind starts turning. The simulations you can run on stock parts vs new aftermarket parts before buying them. You could buy all the right parts the first time out, rather then wasteing money on parts the you find out later didnt work or sent you backwards.
2013 SWP BRZ Limited(on order)
2012 Vw Jetta Sportwagen TDI 6mt Navi and Pano 2009 Toyota Tacoma 4x4 Double Cab Long Bed 1994 Honda Civic HB TurboCharged Track Car ![]() |
#45 | |
Drives: 03 Blue WRX Wagon, 06 Blue STI (T2)
WEEELLLLLL they did mention that the car has electric power steering.... I think we're catching on to something Eh, Eh???!! *nudges with elbow* |
#46 |
Softparker
Drives: 2002 Mazda Miata
You mean you guys haven't installed the 240hp firmware yet?
#47 | ||
Drives: 23 BRZ
![]() Quote:
http://gps-laptimer.de/Home.html The iPhones sensors are quick and accurate enough to give lap times accurate to 0.1 sec. I don't know if the app takes advantage of the phone's accelerometers though. I'm finding it hard to not hold my breath for the exciting possibilities. In the world of powerful smartphones, apps, and social networking we all have a good idea of the technical possibilities. Hopefully this aspect of the car is also designed by passion, and not by committee. |
#48 |
Rocket Surgeon
Drives: PSM GGA OMG
I was talking about the onboard nav system at that point.
#49 |
Drives: '15 BRZ, '19 GTI
Just to make it clear, all these parameters they are talking about are already transmitted on the CANbus, today, in the cars you are all driving (provided they are newish, of course). What they are doing is telling us what it all means. CAN messages are very obscure.
Just by looking at a message you can't tell what the data means, there aren't any parameter names attached in the message. Each CAN message does have a 'specific parameter number' (SPN) attached to it, which is transmitted on the bus, and Toyata knows what it all means. It looks like Toyota is going to tell us what SPNs correspond with specific parameters (at least the ones they want to tell us, there are thousands of SPNs). There are already SAE standards for this stuff. There are standard SPNs allocated for specific parameters. Things like throttle position and engine speed will have already been standardised. If you had a copy of the standard (they aren't free though), you could already make a GTR-esque gauge cluster. You could already record the data and look at it on your computer. You could already send that data to your friends. Toyota is just making it easier (and cheaper) for normal (read 'not engineers') people to do the above mentioned things. This may create a niche market for gauge clusters, dataloggers, and other as-yet unthought-of applications. You most likely won't be able to reprogram anything over CAN. Giving that kind of control out would be a nightmare for the lawyers and the engineers. As a side note for everyone fearing big brother's black box: just about everything you fear the black box could do is technically possible. Some data recording is already done today, though for the manufacturers' benefit. If this is something that keeps you up at night, we have elected representatives for a reason; use them. Worrying and complaining on the internet won't change anything. Disclaimer: I work with J1939, my preferred flavor of CANbus. Not used in cars, but in off-highway and construction equipment. |
#50 | |||
![]() the nightmare that would cause with idiots popping engines and the EPA/CARB/Euro screaming bloody murder ![]() Quote:
Dare I guess you work for Cummins? |
#51 |
Big Green Tractors
#52 |
That was going to be my next guess
![]() <--consulting at Volvo/Mack |
#53 |
Glorious BRZ Master Race
Drives: Subaru Libird
^Do you guys have an idea of the mechanism that would sync up and remap your position on a real life track to a virtual reproduction of the track (aka GT5)? I would think GPS antennas but can't believe that for some reason and is there even a standard for that?
#54 | |
As for something off the shelf to work...nope, never looked into it. |
#55 |
hashiryu
Drives: Mk4 Supra
Probably could be a way to map local tracks into R-Factor...........
| Tags |
| brz can bus, fr-s can bus, frs canbus, gt86 can bus, scion fr-s can bus, scion frs can bus, subaru brz can bus, toyota 86 can bus |
| New Product Releases from Cusco for the 86 and BR-Z. | toxicdrift | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 02-02-2012 02:27 PM |
| Toyota Releases FT-86 World Report iPhone App | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 10-31-2011 08:36 PM |
| The Future of Cars | serialk11r | Engine, Exhaust, Transmission | 118 | 09-01-2011 11:54 PM |
