#421 |
Drives: '13 Raven FR-S, MT
Just confirming that removing the fresh air snorkel will make a difference, yes?
.ck Sent from my HTC One using Tapatalk |
#422 |
Drives: slow
#423 | |
Drives: 2013 FRS
Shiv |
#424 |
Drives: 2003 Camry Blue | 2013 FR-S White
time to take the snorkel off of my TRD intake and see what I can get!
#425 | |
Drives:
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#426 |
Drives: 2013 FRS
#427 |
Drives: FR-S 10 #103 AT
In other words, nothing anyone can actually feel NA but an indication that it might benefit a FI installation.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#428 |
Drives: 2013 FRS
All these little 2-3hp gains do add up into something you can feel. For FI application, I'd probably nix the hold stock airbox completely since it will probably be a restriction at those much higher airflow levels. But that remains to be tested.
#429 |
The Mechanic
Drives: Civic Turbo,FR-S
shiv, i edited my snorkal months ago by cutting it back to a 2.5 in opening and putting in a v stack, wouldnt i see the same gains but have the air accelerated in by a smooth entrance like this??
#430 |
Turning is for Nerds
Drives: 35 characters is not enough
#431 | |
Senior Addict
Drives: 86 GT
#432 | |
F Z1LLA
Drives: Lexus IS-F Series 2
This is how I removed mine... The only difference is I found it easier to pull mine out from the drivers side verses the passengers side as done in the DIY http://www.ft86club.com/forums/showthread.php?t=15376
2URGSE |
#433 | |
Drives: BRZ Limited
#434 | |
Drives: 2013 Scion FR-S 10 Series MT
When I removed the stock air filter and replaced it, I could visually see and feel (by touch) a notable difference in texture, which I assumed would make a big difference in air restriction/flow. I also do feel a difference in throttle response (not necessarily hp or tq) in the 3k-5k power band, particularly between going from light/partial throttle to full throttle, and my butt dyno can feel a decent increase in pull above 5k rpm. I can definitely see how removing the snorkel would increase the air flow, but the question I have is... wouldn't this increase the ambient temps some? It looks like the snorkel bends around to try and pull in air from further away from the engine bay, whereas without it, the entrance is much closer to the engine bay. Again, I'm just curious. Removing the snorkel seems pretty simple, and I may end up doing that in the next couple of days, for science... |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
