Old 10-21-2013, 10:30 PM   #15
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
last time I seen you I think you were running 225s on stock rims. and I agree for those the pressures are to low. we have one event left in November 9th and tenth come down for the weekend it will be fun.
also I know you think the surface jacked your alignment last time but in 3 years of using this site I never had that issue.
if you come down on Friday I can give you a tour of volition. you would have fun.
Originally Posted by Dezoris View Post
Maybe you are right I just feel like those side walls are not stiff enough for those pressures. Guess its an excuse to hook up again for more autox to test!
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-22-2013, 02:25 AM   #16
Dezoris
Dezoris's Avatar
I am on 235s now not much different really. I know your pavement was very bumpy most guys run a softer setup?
Old 10-22-2013, 11:12 AM   #17
Wepeel
Drives: '13 BRZ Ltd
Cool video.
Lot of movement of the swaybar/chassis bushing, especially considering the small-ish range of motion of the swaybar to begin with.
Also interesting that the subframe doesn't move that much laterally, it seems to be mostly vertical. I installed subframe bushing inserts on my GR STI and it seemed to really make the rear end more responsive and predictable.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Racecomp Engineering (10-22-2013)
Old 10-22-2013, 11:17 AM   #18
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
DAT CROSSMEMBER FLEX
i'm almost willing to get dumped into STX just to outfit the car with all the possible bushings, holy crackerjack.
Old 10-22-2013, 07:44 PM   #19
mike156
Drives: EVO
Interesting video and interesting to see your pressure/camber settings. A soft tire and stiff suspension seems kind of basackwards to me though as the tire is largely undamped. Just from experience, take a well damped car with high spring rates and through soft tires on it and it will be bouncy as hell.
I can't tell if there is actual subframe flex or if it's just the large amount of bushing flex causing it to look like subframe flex. There are definitely a couple spots where it looks like more then just bushing flex though.
mike156 is offline   Reply With Quote
Old 10-22-2013, 09:23 PM   #20
feldy
feldy's Avatar
Who else makes bushings for the rear other then whiteline? After they screwed everyone with the com-c's top hats I don't want to give them anymore money. They didn't even test them other then seeing if they mounted up. I can idmagine it was the same with the bushings considering how fast they got them out. I just don't trust them.
Old 10-22-2013, 09:31 PM   #21
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
Powerflex has a whole line up of inserts and bushings @ powerflexusa dot com. Note that some products overlap (inserts and complete bushing replacement).
Edit: I think Energy Suspension also just finished their bushing package for the 86's according to their Sept. 30th Facebook entry.
KKaWing is offline   Reply With Quote
Old 10-23-2013, 02:31 PM   #22
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Wow, tons of slop everywhere! You've convinced me to get some inserts for the rear
Books is offline   Reply With Quote
Old 10-23-2013, 03:11 PM   #23
feldy
feldy's Avatar
Ha thats not even the point of the video. Just showing what the RCE springs/Konis look like when at work.
Old 10-23-2013, 03:16 PM   #24
feldy
feldy's Avatar
Actually the opposite. I was having issues with the car wanting to step out on me when hitting the bumps and becoming unsettled in the rear with a softer setup.
As soon as I went to a stiffer setup the car was much more stable. Everything is just damped better. Rebound is better ect.
I don't know if its a combo of the stiffer springs all around or the shocks helping. Since I never had them on with out each other cant really say.
Old 10-24-2013, 02:07 AM   #25
Dezoris
Dezoris's Avatar
I felt like on the stock suspension it was borderline too stiff for that pavement there. I mean the was hopping over all the pavement irregularities. Namely closer to the big hanger. I would be running almost full soft if I did it again.
Old 10-24-2013, 06:09 PM   #26
Turbo Den
Drives: FRS, IS300, 911sc
-2.5 camber up front
-1.9 camber rear
toe a little out in the front a little in on the rear.
with what mod you got -2.5 camber up front?
and it has stock subframe bushing or whiteline? thanks.
Turbo Den is offline   Reply With Quote
Old 10-24-2013, 09:50 PM   #27
feldy
feldy's Avatar
Whiteline camber bolts for now. Had the same when I was on aftermarket tophats.
I run the tire so close to the spring perch to get that much camber most people would be un comfortable with it. If the bolt slipped there could be issues. I can only fit my credit card and drivers lisence in between the rim and spring perch.
That's with my 245/40 rs3s on the rpf1 17x9 +35 rims. If I had the 45s I'd be screwed.
The Following User Says Thank You to feldy For This Useful Post:
Turbo Den (10-25-2013)
Old 10-31-2013, 12:38 PM   #28
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
That's the Perrin Hangers and perrin catback. @PERRIN_Chris These do like to shake a lot huh
That looks pretty normal, it'd move a lot more with the factory bushings! Looks like the hanger isn't straight up and down though, but it could be the angle of the camera.
PERRIN_Chris is offline   Reply With Quote
DIY: Cutting OEM struts (front) for Koni Yellow inserts mit_peid DIY (Do-It-Yourself) Guides 25 06-20-2014 01:16 PM
Review: RCE Yellow Springs and KONI shocks Grimlock Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 03-27-2014 11:58 AM
F/S: Koni Yellow struts and H&R Supersport springs $650!! MountainManFR-S Brakes, Suspension, Chassis 4 07-02-2013 08:06 PM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 01:10 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
