#421 |
Drives: 1966 Mustang, 2013 FR-S
Does anyone know the PID settings for monitoring steering wheel angle?
| The Following User Says Thank You to Rosticles For This Useful Post: | BRZ21 (11-05-2013) |
#422 | |
Drives: 2013 Whiteout FR-S
| The Following User Says Thank You to kanundrum For This Useful Post: | IceFyre13th (10-09-2013) |
#423 | |
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
check out my build thread here
![]() Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
#424 | |
I got this working eventually. Changed the last entry of the PID from 7E0 to Auto, and it works now. Now I just need to figure out how I'm going to mount my Nexus 7. |
#425 | |
Drives: 13 Asphalt FRS AT
Sent from my Nexus 7 using Tapatalk 2
#426 |
Drives: FR-S Firestorm 6MT
Great info in this thread.
I've been using Torque along with the Knock Detector plugin. Quite interesting to see the knock corrections through the rev range. Mostly within the torque dip area and then above 6K. |
#427 |
Drives: 2013 GBS BRZ Limited
Has anyone found the PIDs to see the tire pressures?
Now that it is getting cold, my TPMS is going off all the time, and I want to be able to see my tire pressures. |
#428 |
Thanks
How can I take this PID for oil temp and have it display in F not C? Is it possible?
Alsso, when I put the custom PID it doesn't let me set -40 as minimum, it only allows 0. OBD2 Mode and PID: 2101 Minimum Value: -40 Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high) Scale factor: x1 Unit type: C Equation: AC-40 (no space between A and C; "AC" is the location within the response) OBD Header: 7E0 (Auto also works, but seems to take longer) |
#429 | |
I believe you can set that in settings.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#430 |
Thanks
#431 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
It's possible to put the display on the stock headunit. It is convoluted...but I did it: http://www.ft86club.com/forums/showthread.php?t=49633
I'll post up a better video soon. |
#432 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Does anyone know if Torque works with a Tactrix Openport 2.0?
- AdrianG |
#433 |
Drives: slow
I'm finding the Knock detector plugin to be a bit lacking. No logging for instance.
Has anyone been able to determine a PID for measuring knock correction? |
#434 |
Drives: Subaru BRZ with Delicious Innovate
I would really like a way to monitor knock real time. Has anyone found the PID for knock correction yet? I am willing to do any leg work necessary. I have EcuTek and all sorts of testing equipment I just don't have the experience with PID's.
| The Following User Says Thank You to calispec For This Useful Post: | fstlane (11-05-2013) |
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
