Old 10-18-2013, 08:19 PM   #1
frs10
Drives: tezla
strut brace bolt snapped
frs10 is offline   Reply With Quote
Old 10-18-2013, 09:18 PM   #2
Burrcold
Drives: Subaru BRZ Limited
I'll say it again...another??
Old 10-18-2013, 09:31 PM   #3
frs10
Drives: tezla
Originally Posted by ae86stunt View Post
Drill it out with an easy out. Amazon.com: 8 piece Easy Out Screw Bolt Extractor Set: Home Improvement
Take whats left of the bolt/tread match it up at lowes/ home depot. Get Grade 10 steel if you can. Grade 8 will do fine tho.
ok
Old 10-18-2013, 10:33 PM   #4
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
How old is your current torque wrench? Might be time for an alignment.
Old 10-18-2013, 10:34 PM   #5
frs10
Drives: tezla
wow
Old 10-18-2013, 10:57 PM   #6
dem00n
dem00n's Avatar
Drives: Scion FRS
Originally Posted by frs10 View Post
lol i just bought it 20 mins before i did this...
Don't tell me you bought one of those cheapo ones at Autozone.
Old 10-18-2013, 11:07 PM   #7
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
THIS. drill that fucker out and then hit it with a tap/die
dori. is offline   Reply With Quote
Old 10-18-2013, 11:12 PM   #8
Yellow13
Yellow13's Avatar
Drives: 2013 6MT Asphalt FR-S
Also, I am sure this goes without saying but just like with any situation where you are using a wretch, ESPECIALLY a torque wrench, you did apply some down pressure (with your hand) at the fulcrum of the wrench to ensure it was stable while turning, right? You didnt just set it on there and try to crank it down to pressure, both hands on the end of the wrench handle?
I have seen so many people break bolts because they think they can just set the socket and twist ...
Honestly, from the picture, bolt looks sheared off like there was way too much torque. What torque wrench did you buy?
Yellow13 is offline   Reply With Quote
Old 10-19-2013, 08:07 AM   #9
frs10
Drives: tezla
thanks
Old 10-19-2013, 09:03 AM   #10
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
So in that case, what's a good torque wrench to buy around the 50-100 range?
Enraged21 is offline   Reply With Quote
Old 10-19-2013, 09:15 AM   #11
raytrix
Drives: Series 10 FR-S
You did what this guy did too.
http://www.ft86club.com/forums/showthread.php?t=26254
You got to remember that these studs are tiny 1/4" studs pretty much and you can technically snap them by hand even without a torque wrench. It should of just been hand tight with a 1/4" or 3/8" driver.
raytrix is offline   Reply With Quote
Old 10-19-2013, 10:04 AM   #12
Trac Toy
Trac Toy's Avatar
This...^^^
Torque wrenches are for heads and crank mains and truly important stuff. Otherwise you should be able to tighten things up by hand. I mean you just took it off by hand. You know how tight it was.
Also 12 ft/lbs is pretty light, you probably missed the click as soon as you started.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 10-19-2013, 10:31 AM   #13
86dreams
Drives: many different
^^this
86dreams is offline   Reply With Quote
Old 10-19-2013, 10:33 AM   #14
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
This happens to every Suby Newby. These studs are only torqued to about 8.5 lb ft. Meaning just past hand tight. Same goes for the strut tops.
I'd recommend mods make this a sticky. At least for a year or two.
Beyer Subaru is offline   Reply With Quote
BRZ/FR-S Strut Tower Brace - Any Interest? GrimmSpeed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1224 05-10-2015 07:40 PM
Question about strut brace russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-04-2013 10:35 AM
My Strut Brace Mod... Andrew666 AUSTRALIA 4 03-04-2013 11:38 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
Which Rear Strut Brace? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 11:01 AM
