Old 04-07-2013, 07:27 PM   #15
xwd
Yeah plenty of Impreza owners have snapped those studs. Unless you have a low-torque torque wrench, usually something that low isn't very accurate on one which goes up to like 150 lb-ft.
Old 04-08-2013, 12:16 AM   #16
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Originally Posted by jesperswe View Post
Happend to me today also, i broke off a stud but not to the crossmember, but for the strut itself. I will have to remove the whole strut and knock that stud out and insert a new one.
As for now i'm driving around carfully with just 2 out of 3 bolts attached to the strut
And of course you cannot buy the stud alone @TOYOTA. You have to buy the whole topmount
I'd probably buy the whole topmount, I gotta say. I don't like crashing cars much due to changing suspension geometry.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 04-08-2013, 01:09 PM   #17
jesperswe
Drives: GT86
Yeah and these shocks are all subaru it seems. weak ass studs. And a new topmount one costs about 155$ over here in Sweden.
My old mitsubishi evo top studs are almost twice the size
Anyways there's plenty of room underneath so i can probably replace the stud without even removing the whole shock assembly. Anyone got a tip for getting the old broken stud out? I tried hammering away but it did not move an inch....
jesperswe is offline   Reply With Quote
Old 04-10-2013, 02:38 PM   #18
jesperswe
Drives: GT86
God damn that stud is hard to get out!
Looks like i'll have to remove the whole top mount and get it pressed out instead.
Old 07-19-2013, 01:02 AM   #19
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Is ur problem solved?I had the same problem today..
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-19-2013, 09:21 AM   #20
wparsons
wparsons's Avatar
It's already been said, but people keep mentioning the top mount so it's worth repeating...
That's not one of the top mount studs, it's one of the studs for the factory strut brace. Doesn't matter what you do with the top mount, that stud will still be missing.
If you can't get a new one in by press fit, find a shop that can weld in a new stud for you. Shouldn't cost too much.
flickr
Old 07-19-2013, 01:51 PM   #21
Figo
Figo's Avatar
Since it is the brace stud, I think I do not have to get a new one right? It may not be a serious issue.
Old 07-19-2013, 02:20 PM   #22
wparsons
wparsons's Avatar
I would want to fix it if it were my car, but I seriously doubt you'll see anything happen as a result of leaving it as is.
flickr
Old 10-18-2013, 08:12 PM   #23
frs10
Drives: tezla
hate to grave dig but this happened to me today while installing my grimmspeed strut bar... can anyone advise?
frs10 is offline   Reply With Quote
Old 10-19-2013, 08:15 AM   #24
frs10
Drives: tezla
@cobrabyte
what did you finally end up doing to fix this?
Old 10-24-2013, 01:47 PM   #25
frs10
Drives: tezla
is OP still an active member?
has anyone tried this approach to see if it works?
Old 07-02-2014, 05:37 PM   #26
Odd
Odd's Avatar
Drives: DGM BRZ
broke one of the strut brace bolts (circled in red, not my photo) - thats what i get for being a noob
Let me know if anyone solutioned around it, otherwise maybe just weld another is the solution.
Odd is offline   Reply With Quote
Old 07-02-2014, 11:13 PM   #27
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Did you use a torque wrench when you installed it? I believe it's supposed to be 12 ft/lbs only.
Fizz is offline   Reply With Quote
Old 12-22-2014, 05:37 PM   #28
Skinc.
Drives: 2013 BRZ Limited
well, looks like im a member of this club as well. I managed to break the same bolt as just about everyone else in this thread (second one on oem strut brace where it connects to teh firewall).
Been physically ill since it happened. I am at a loss as to how you can fix this as the backing to the bolt appears to be welded to the firewall.
it seems like every thread ive found with this issue never has a resolution...
My question is who HAS fixed tihs and what did you do?
If you havent fixed how has the remaining bolt held up? What kind of driving have you been doing?
Ive already talked to my mechanic and he says its fixable (how is beyond my skills and resources).
Skinc. is offline   Reply With Quote
broken, hotchkis, repair, stud, suspension
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 09:20 PM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
First brz broken into...sigh zex CANADA 74 08-04-2012 06:17 PM
