CANADA Canada
Old 10-11-2013, 03:29 PM   #15
VirUzxZ
Drives: Black on Black on Black
i have said f1 styled brake light and i agree with SkullWorks & Onefitz with the visibility thing. i use engine breaks a fair bit so i don't tend to use the breaks unless i HAVE to stop so it's not as bad as one might think.
I also have "dark tint" white led side markers that are hella bright. I've looked into the whole legality thing in ontario (specifically Markham) and have found nothing about them both. i've had both installed for @ least 5-6 months and have received no tickets directly for said items (i have been pulled over for other things tho... speeding 12 over.....) The only thing i saw was in regards to the colors you have on at any given time. like blue, red, green stuff like that.
i also have front switch backs installed aswell type 2 to be exact and haven't had any issue with them either... from a legal standpoint at least.
VirUzxZ is offline   Reply With Quote
Old 10-11-2013, 03:53 PM   #16
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I wouldn't say that unless you've actually had that vetted by a lawyer and proven in court.
Also, why do you use engine braking? That's very bad for anyone following you because:
1- They have to physically see your car slowing down to brake which means you add time to their reaction time already.
2- Engines are made to make your car go not stop
Just use your brakes?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 10-11-2013, 04:20 PM   #17
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I had the chance a few years back to do Mosport in a friends 911 with an instructor an was give a proper scolding for down shifting and using the engine to slow down. As he put it "it's cheaper to replace brake pads that rebuilding a motor that was damaged doing what it wasn't meant to do" Ever since I'm hard on the brakes and use the motor only to accelerate.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 10-11-2013, 04:37 PM   #18
onefitz
Drives: 13 GBS BRZ
So I'm going to assume both of you are putting the car in neutral every time you let off the gas and apply the brakes right? Because leaving it in gear is engine braking too.
onefitz is offline   Reply With Quote
Old 10-11-2013, 04:49 PM   #19
Frost
Frost's Avatar
Braking means my right foot goes on the brakes. My brakes squeeze the rotors and the result is in a loss of speed (RPM of the engine correspondingly drops) and when RPMs drop enough for the gear down speeds, I downshift whilst staying on the brakes.
This order means I use the brakes to slow down the car wheel speed and engine speed and not gearing to force the engine into high revs and slow down. This doesn't give anyone behind you an indication you are slowing down until you actually do.
Also, a constantly flashing light in the back is highly distracting for street driving. I don't like this.
Old 10-11-2013, 04:54 PM   #20
onefitz
Drives: 13 GBS BRZ
You can still rev match your down shifts and use the engine to slow the car while just barely pressing the brake pedal to have the brake lights come on. If you do it right you're not causing anymore wear and tear on the car and you're saving your brakes.
Engine braking isn't some crazy thing that's going to completely ruin your car if you do it unless you do it really wrong.
Old 10-11-2013, 04:59 PM   #21
Frost
Frost's Avatar
I rev match but not all the time for normal driving as I don't need to be raring to go hot hot hot the moment I let off the brakes.
Brake lights are very important and I find it very irresponsible when a fellow manual transmission driver relies solely on engine braking to slow down and gives less chance for the guy behind to realize what is going on.
To install a flashing red in the back in lieu of using one's brakes? Come on.
I didn't say that you should never use engine braking but keep the racing stuff to the racing areas. Drive your car as it was meant to on the street and do the track stuff on the track.
EDIT: The opposite is also true, people who ride the brakes for no reason are also being irresponsible as now no one can truly tell if you are going to brake or just crying wolf.
Old 10-11-2013, 05:10 PM   #22
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
EDM cars have flashing break lights installed standard because it has been proven to reduce accidents.
But hey, flashing lights scare the hell out of American's so the public was confused when Mercedes tried selling it here on their cars. (if it does not sell in America, they do not bother with it in Canada, exception, Yaris)
Old 10-11-2013, 05:29 PM   #23
Frost
Frost's Avatar
Link plz?
Old 10-11-2013, 05:40 PM   #24
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Link plz?
Here you go
Old 10-11-2013, 11:03 PM   #25
wparsons
wparsons's Avatar
You do realize that like 90% of drivers will hit their brakes when they see brake lights, whether they need to or not? Hitting the brakes when you could simply coast (in or out of gear) and not put yourself in danger just causes more of a back up with the traffic behind you.
Watch how people behave in traffic, they're total lemmings. Give the car in front of you a tiny bit more space and stay off your brakes and you'll use less gas, less wear on brake parts and if everyone can manage to do this, traffic will move faster.
These flashing brake lights don't constantly flash, they're normally off, but when you put on your brakes they flash a few times then go solid.
flickr
Old 10-12-2013, 09:07 AM   #26
wbradley
Sarcastic SOB
wbradley's Avatar
I have found that brakes last much longer for me on manual transmission vehicles. Never needed any clutch work or engine related work caused by this. I will always downshift when gradually decelerating by force of habit. Rarely, I dropped down from 6th to 3rd accidently and engaged the clutch immediately upon realization. When driving aggressively on a deserted road I always drop to 2nd going into a turn then hit the hammer at the apex. Lots fun with the nannies switched off. Don't try this at home kiddies LOL.
Old 10-12-2013, 11:31 PM   #27
Frost
Frost's Avatar
Ok, finally I get to what on earth you guys are talking about.
First off, the flashing red light on the F1 cars is NOT the brake light - it has NOTHING to do with the brakes at all:
All cars must have a red light on the rear of the car in a specific location defined by the FIA regulations. The driver must be able to switch this light on at any time. This is usually done in poor weather conditions in order to make the car more visible to following drivers.
SOURCE: http://www.formula1.com/inside_f1/ru...ulations/8706/
This is why I was so annoyed and confused by the OP's post of "flashing 4th brake light".
As for the Benz report on a flashing brake lights WHEN pressed full tilt (ie: an emergency slam of the brakes), that I wholeheartedly go for. I've been saying for years that I absolutely hate how I can't tell if someone is riding their brakes OR actually braking. In the case of a 100% slam on the brakes situation, flashing brake lights would be EXTREMELY USEFUL.
Now that this is all clear - NO ALWAYS flashing brake lights please.
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
Will Demon Eyes affect light temperature output? (also the legality) boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2013 05:37 PM
Flashing Security Light in Dash? ravenMTgirl Electronics | Audio | NAV | Infotainment 8 11-21-2012 03:25 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Light flashing under trail braking. CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-16-2012 04:10 PM
