Old 12-17-2012, 03:57 PM   #57
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by 2forme View Post
Do you have a dyno showing safe AFR?
I remember reading (in a lot of places) that it is only in WOT instances where unsafe AFR's actually present themselves. Furthermore, according to multiple tuners/sellers/engineers/experts/hobbiests/moms, etc who have posted here, it is only "unsafe" when running at WOT consistently for long period of time. An example of this? Non stop tunes to prove unsafe AFRs.....
Old 12-17-2012, 04:03 PM   #58
2forme
Yea, running unsafe AFRs at high load is what worries me. It doesn't take a lot to hit high load cells in the fuel map (doesn't need to be WOT either).... so depending on your driving style, it might happen more often than not. And if you're buying an intake, chances are you are going to be more prone to drive aggressively.
I've seen what a motor with hot spots in the cylinders can do. Not fun. No one likes dumping money into a car if they don't have to.
The Following User Says Thank You to 2forme For This Useful Post:
Mikepage (12-17-2012)
Old 12-17-2012, 04:40 PM   #59
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
true true
Old 12-17-2012, 08:53 PM   #60
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
Originally Posted by jpit View Post
Diconnecting the ground terminal is the recommended procedure. Disconnecting does reset the ecu somewhat. However Toyota had said that once the ecu has seen a few hundred miles most of its learning has been accomplished and resetting it doesn't do all that much.
Yes it does it resets fuel trims. And once you do that it will take about 50-100 miles to relearn them
WiKKiD is offline   Reply With Quote
Old 12-17-2012, 10:01 PM   #61
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Originally Posted by L3P47 View Post
I'm looking at getting the Injen intake for my FR-S. What kind of adjustments without an aftermarket exhaust do you recommend?
You could try to adjust the throttle body if it runs lean but I think you will be fine ounce the car's ECU reset is done. Thats just unhooking the battery and hooking it back up after you install it.
Old 12-17-2012, 10:35 PM   #62
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Adjust it in what way? It's drive by wire there's no adjustment on it. Even if there was it wouldn't do anything but slow the car down.
If you want the benefits of a intake get a tune for it. You should be fine with a intake on a stock tune just disconnect the negative terminal for about 15 mins minimum. And once you connect it back start your car and let it idle for 5 mins without touching the throttle. After that it will learn fuel trims as you drive. If its over the threshold for fuel trims you will get a cel. It's normally -10% To +10 before it throws a code.
Only gain you will get from a intake is a louder intake. No hp or trq. The power all intakes showed on a stock car were in the margin of error on a dyno meaning the gain was so little that they could not prove it was from the intake or from other differences like air temp or less humid air. Or waiting a little longer between dyno.
Sent from my iPad using Tapatalk HD
The Following User Says Thank You to WiKKiD For This Useful Post:
Old 12-18-2012, 12:58 AM   #63
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I have a Perrin CAI on order as of this weekend. They are shipping in the next 2 to 3 weeks I think. I will write a full review after I receive it as well as Dyno's after I get my Re-Tune. I have high hopes that it will perform better than the Airaid Intake that I had.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 12-18-2012, 01:29 AM   #64
jpit
Drives: Subaru BRZ
This was Toyota's explanation for the rough idle issue:
The two automakers diverge on the remedy, however. After 100 miles of learning the powertrain and the driver's driving style, AN reports that the ECU's mapping is pretty much baked in. If engine operation exceeds the established parameters, at low revs the engine succumbs to uneven idling and stalling as the ECU tries to recalibrate to a new range of tolerances. Toyota has said that if the issue is suffered by a car with less than 100 miles, the ECU should be reflashed, but that cars with more than 100 miles should have their ECUs replaced. Subaru, though, has said that the ECU doesn't need to be replaced no matter the mileage – a reflash is all that's required. It appears that some owners who have had the reflash have suffered the problem again.
jpit is offline   Reply With Quote
Old 12-18-2012, 02:28 AM   #65
Accurate Race Shop
Drives: Scion FR-S
I don't know much about fuel injection all my hobbies have had carburetors and my thinking was to adjust the throttle cable to get rid of the lean condition that the injen causes in some cases. Mine was fine after I disconnected and reconnected the battery. It felt a little better to me and I trust all the dyno runs that it puts out a gain I think it would be a big risk for a false advertising lawsuit if it didn't. I do not know anything about how a dyno runs work besides they tell you torque and HP I have only had them done when selling a car and I dropped it off and came back to pick it up with the results.
Sent from my SGH-T989 using Tapatalk 2
Old 10-07-2013, 11:13 PM   #66
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by mashal View Post
Afe intake hasn't caused any cel with the fa20club tune
-AKA
He said no tune
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 10-08-2013, 12:43 AM   #67
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
lol post over a year old re born...
Old 10-08-2013, 01:04 AM   #68
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
AEM has been great for me nearly 1 year and no CEL or ECU tune. The MAF tune included is eliminating the CEL.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
The Following User Says Thank You to m.wood0213 For This Useful Post:
sosick (10-09-2013)
Old 10-08-2013, 11:18 AM   #69
frs10
Drives: tezla
lol waiting to get my hands on the TRD CAI
frs10 is offline   Reply With Quote
Old 10-08-2013, 11:41 AM   #70
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
There was just a recent review about different intakes done by Dsport:
http://www.ft86club.com/forums/showthread.php?t=35125
I was pretty dead set on just getting a K&N drop in filter anyway, since I eventually plan on going FI. The Dsport review solidified my choice, and I purchased a K&N Air Filter online yesterday while ordering some Motul Gear 300. Can't wait to install it this weekend!
Hanni_0176 is offline   Reply With Quote
Best intake? Maps316 Engine, Exhaust, Transmission 34 05-12-2014 04:15 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
Looking for HKS Intake Spartan65 Engine, Exhaust, Transmission 2 09-12-2012 11:40 PM
