Old 08-24-2012, 11:38 PM   #1
Ericfrs
New Member
Ericfrs's Avatar
Drives: 6AT Ultramarine FR-S
Taking off bumper without damaging side markers
Hi everyone,
While I was retrofitting and blacking out head lights yesterday, I found a way to take off the front bumper without taking off or damaging the side markers.
Here's how:
1. Remove 1 plastic pop rivet behind the side marker and 3 under it in the wheel liner.
2. Now pull away the wheel well liner to reveal the side marker assembly.
3. Make your way to the top of the side maker and locate the end of the plastic pop rivet.
5. Find something flat, like a big flat tip screw driver, and put it on top of the rivet' end.
6. Squeeze down hard until you here it pop out (Only the core of the rivet will pop out, the rivet it self will stay in the hole as the side marker is in the way).
7. Last, remove bumper by pulling the bumper down, it should pop right off.
To re-install the the bumper, you'll need to take off the rivet by removing the side marker, as installing the front bumper with the rivet sitting in there makes it almost impossible to line up the bumper. However, it is much easier to get the side markers off when the bumper's off and you can actually see it!
Big thanks to DarrenDriven and civicdrivr as the Retrofit and black out turned out to be great!!
Ericfrs is offline   Reply With Quote
The Following 4 Users Say Thank You to Ericfrs For This Useful Post:
Choco (01-21-2015), Nitro22 (08-25-2012), normancw (02-10-2014), whataboutbob (12-16-2012)
Old 08-26-2012, 04:01 AM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 12-16-2012, 11:20 AM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
I followed this method and bumper os very hard to pull down , any tips ?
-AKA
mashal is offline   Reply With Quote
Old 09-30-2013, 03:21 AM   #4
notout86
Drives: GTS 86 auto
Our car is an Australian Toyota GTS86 and does not have the pop rivet. Instead it has an upward pointing stud moulded into the bumper plastic near the indicator light (arrowed in photo below). The stud in turn locates up into a hole in the body metal. CORRECTION Nov.2013... our car SHOULD have had the pop rivet but it was missing. The upward-pointing stud mentioned is an additional locating feature i.e. not "instead" of the pop rivet.
Cover your bodywork paint. Via the wheel arch you can lever the stud down with a covered screwdriver to release it and pull the bumper away with the light intact.
In the photo the stud is arrowed. The light is only shown unclipped so you can see that pesky clip. I have now managed to bust that clip while struggling to refit grrrr
http://*************/forum/f26/bumpe...909/#post46333
Old 09-30-2013, 03:39 AM   #5
notout86
Drives: GTS 86 auto
[IMG]http://*************/forum/f26/bumper-removal-3909/#post46333[/IMG]
The arrow points to the stud. The hole to the right takes the pop rivet
The Following User Says Thank You to notout86 For This Useful Post:
normancw (04-04-2014)
Old 10-01-2013, 11:36 PM   #6
notout86
Drives: GTS 86 auto
more useful photos with tips that I hope will be helpful
Old 10-20-2013, 11:10 AM   #7
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I took my bumper off last night(fitting HKS Intake and Fenders).
Here's a little tip. There is a metal bracket that I believe is actually designed to lever the brass clip to be pushed forwards so the side markers can be removed easily. Stick a small flat head screwdriver in like so and lever it away from you to depress the brass tab while gently pulling the side marker outwards.
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Old 06-17-2017, 10:05 PM   #8
sandy s
Drives: 86 gt
Thank You That worked great.
sandy s is offline   Reply With Quote
broken, bumper, install, remove, side markers
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 128 02-27-2019 08:25 PM
Swapping for clear side markers ayau DIY (Do-It-Yourself) Guides 62 06-01-2016 02:49 AM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 11:56 PM
No more broken Side Markers ! Ericfrs Scion FR-S / Toyota 86 GT86 General Forum 0 08-24-2012 11:21 PM
FR-S / BRZ side markers interchangeable? Slant Cosmetic Modification (Interior/Exterior/Lighting) 2 06-30-2012 08:26 PM
