Old 08-24-2012, 10:21 PM   #1
Ericfrs
New Member
Ericfrs's Avatar
Drives: 6AT Ultramarine FR-S
Exclamation No more broken Side Markers !
Hi everyone,
While I was retrofitting and blacking out head lights yesterday, I found a way to take off the front bumper without taking off or damaging the side markers.
Here's how:
1. Remove 1 plastic pop rivet behind the side marker and 3 under it in the wheel liner.
2. Now pull away the wheel well liner to reveal the side marker assembly.
3. Make your way to the top of the side maker and locate the end of the plastic pop rivet.
5. Find something flat, like a big flat tip screw driver, and put it on top of the rivet' end.
6. Squeeze down hard until you here it pop out (Only the core of the rivet will pop out, the rivet it self will stay in the hole as the side marker is in the way).
7. Last, remove bumper by pulling the bumper down, it should pop right off.
To re-install the the bumper, you'll need to take off the rivet by removing the side marker, as installing the front bumper with the rivet sitting in there makes it almost impossible to line up the bumper. However, it is much easier to get the side markers off when the bumper's off and you can actually see it!
Big thanks to DarrenDriven and civicdrivr as the Retrofit and black out turned out to be great!!
Ericfrs is offline   Reply With Quote
The Following 2 Users Say Thank You to Ericfrs For This Useful Post:
civicdrivr (08-25-2012), DHitHim (05-10-2016)
broken, bumper, install, remove, side markers
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 128 02-27-2019 07:25 PM
Swapping for clear side markers ayau DIY (Do-It-Yourself) Guides 62 06-01-2016 01:49 AM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 10:56 PM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 4 08-24-2012 09:44 PM
FR-S / BRZ side markers interchangeable? Slant Cosmetic Modification (Interior/Exterior/Lighting) 2 06-30-2012 07:26 PM
