Old 09-28-2013, 07:01 PM   #1
SPCorBUST
SPCorBUST's Avatar
Any experience with calculating these gains?
Engine:
Perrin crank pulley
Clutch:
Undecided, lightweight street clutch and flywheel
Driveshaft:
DSS or PST carbon fiber driveshaft
Fuel:
e85 and 91 tunes, likely with OpenTablet
Exhaust:
Borla UEL (sound profile, not max HP)
Perrin overpipe
Perrin catted front pipe
Invidia N1 exhaust
Wheels: (maybe)
Anybody have an idea what this shopping list might net me as far as HP goes? My overall goal is for the car to be more of what it already is... Just increasing how quickly it revs and allowing it to breathe easier... Overall, a more "peppy" car.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 09-28-2013, 07:25 PM   #2
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Header?
Search and read up on it
EvilBeaverFace is offline   Reply With Quote
Old 09-28-2013, 07:40 PM   #3
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Headers over pipe and a tune will give you a solid 20whp. And cost less than your list.
Light weight battery and the aluminium ds would be good if shedding weight is a primary goal.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-29-2013, 12:34 AM   #4
SPCorBUST
SPCorBUST's Avatar
Originally Posted by EvilBeaverFace View Post
Header?
ah, forgot to include. going Borla UEL for the sound profile, just forgot to include. already done plenty of reading on options there
The Following User Says Thank You to SPCorBUST For This Useful Post:
EvilBeaverFace (09-29-2013)
Old 09-29-2013, 12:36 AM   #5
SPCorBUST
SPCorBUST's Avatar
Those items (besides header, which I just added because I forgot it) are part of the list already.
Carbon DS > Aluminum as far as weight goes, debating on the weight savings for the battery. i'm less concerned about overall weight loss, more about shedding weight in the rotational mass.
Old 09-29-2013, 08:08 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
The Driveshaft Shop driveshaft is lighter and cheaper than the PST. I'll definitely be going Driveshaft Shop once the time comes, unless someone can outdo them between now and then.
I've researched pretty deep into brakes, and the AP Sprint kit seems to be the best bang for the buck as far as weight and effectiveness are concerned. You can go a bit lighter than the Sprint kit, but you'll be hard pressed to have better functioning brakes if you go lighter, from what I've learned. They'll set you back ~$2,100, but it's a lot of unsprung rotating weight, and up front which is best for getting that 50/50 front/rear balance.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
SPCorBUST (09-29-2013)
Old 09-29-2013, 08:14 AM   #7
Anthony
Weight Nazi
Anthony's Avatar
Oh, and for batteries, the two best that I know of would be:
4.96lbs - Shorai LFX36L3-BS12 - ~$350
3.90lbs - Super B 10P - ~$750
I'm actually considering dropping the $750 for that battery one day. Yeah, that's silly-expensive, but apparently it fully charges within 5 minutes of driving and lasts a really long time. Could actually be cheaper in the long run if it really does last as long as it's supposed to. And 3.9 pounds for a battery...
Old 09-29-2013, 10:16 AM   #8
cslntuee
Drives: Subaru BRZ Limited
Is there any balance issue when we use lighter batteries?
Thanks.
cslntuee is offline   Reply With Quote
Old 09-29-2013, 10:54 AM   #9
StormTrooper
Never mind I didn't read the post lol
GR86 MT premium
The Following User Says Thank You to StormTrooper For This Useful Post:
Anthony (09-30-2013)
Old 09-29-2013, 11:22 AM   #10
Anthony
Weight Nazi
Anthony's Avatar
Thanks.
Are you talking about the balance of the whole car? Such as front:back and driver's:passenger's sides? If so, it does effect the balance, but in a good way. Most of the weight is in the front of the car, so that's where the priority for weight reduction is.
cslntuee (09-29-2013)
Old 09-29-2013, 03:33 PM   #11
suaveflooder
It sounds like you already pretty much know your answer. You will probably get about 20-30 horse overall to the wheels, but with the rotational mass being much lower, the car is going to clime the RPM range MUCH quicker.
This is the rout I'm going as well. It may not be a horsepower beast, but it'll still be quick
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
Old 09-29-2013, 06:23 PM   #12
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
PST Carbon Driveshaft - 13.9 lbs - $1100
DSS Carbon Driveshaft - 12.2 lbs $1000
DSS Aluminum Driveshaft - 13.2 lbs - $438
Axle Exchange Aluminum Driveshaft - 12.? lbs - $425
How is Carbon DS > Aluminum? Explain that one to me.
An extra $600 - $700 to save potentially 1 extra pound of ratational mass does not seem "better" to me. And the only reason I say potentially saving 1 pound is if you were only looking at the DSS. You could potentially save approximately 1 pound of rotational mass AND save $675 if your two options were PST and Axle Exchange.
Just food for thought.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
Old 09-29-2013, 06:51 PM   #13
cslntuee
How about the noise level of driveshaft between carbon fiber and Aluminum?
Thanks.
Old 09-29-2013, 06:56 PM   #14
Dustin
Twin Screw You
Dustin's Avatar
How about the noise level of drive shaft between carbon fiber and Aluminum?
Thanks.
Exhaust:
Perrin overpipe
Invidia N1 exhaust
I doubt with these mods anyone would be worried about the noise level of adding a driveshaft.
TheseColorsDontRun (09-29-2013)
TRD CAI and Exhaust HP Gains tennisfreak Engine, Exhaust, Transmission 51 11-08-2016 08:30 PM
ECU HP gains? ender2664 Engine, Exhaust, Transmission 45 03-31-2013 03:33 PM
Torque gains, what does the job? JoeBoxer Engine, Exhaust, Transmission 21 10-01-2012 05:46 AM
Biggest gains yomchi1989 AUSTRALIA 5 09-28-2012 07:31 PM
Exhaust HP Gains FoolCyclist Engine, Exhaust, Transmission 79 06-22-2012 12:47 AM
