Old 09-28-2013, 08:15 PM   #57
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by regal View Post
... This car is Subaru's first DI, the highest C.R. street Subaru boxer sold, the stock tune is uh different.
This is exactly my point... given the high CR, new engine etc etc why would they intentionally defeat the IAM system.. if your IAM worked it way down to .2 why in the heck would subaru / toyota think it is a good idea to reset that to .7 since .7 puts you back on the low det timing map and gives you more advance? That is a recipe for warranty engine replacements.....
Maybe they did drop the ball and design it to reset to the initial value every time you restart but that just seems rather silly doesn't it? Considering others have already verified their IAM does not reset.. seems like there is some information we are missing.
The group of cars you mentioned checking, were they ecuteked or un-touched ecu?
FWIW, i transferred my tune to ZA1JA01C this am and the IAM changes (and fine learning table) stuck around between 4 different drive cycles today while i was running errands. The first shutdown saw about 2 hours before the restart. Will test some more tomorrow and into the week.
And @regal.. sorry if i came off like a d!ck in my reply to your post about your findings.
Old 09-29-2013, 09:01 AM   #58
mad_sb
ok well, this AM when i started the car the IAM reset as did the fine correction table. I need to check next time and see if the long term trims reset when this happens as well...
The mystery continues
Old 09-29-2013, 11:05 AM   #59
regal
Drives: Scion FR-S/Toyota Yaris
No sweat I'm wrong about 20% of the time any way . Car's at the dealer will try to get some data when she returns.
Thanks
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-29-2013, 01:33 PM   #60
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Yes, that's exactly why i want it to work. I'm about to drive across the country and don't want to be staring at my laptop for 2,200 miles worrying about it unlearning the knock correction it just learned eveytime i stop for a pee lol.
Which way are you headed you should stop up and see me in Illinois.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-29-2013, 02:45 PM   #61
mad_sb
West Coast, Irvine most likely depends if the company i'm talking too wants me bad enough lol
Old 09-29-2013, 03:23 PM   #62
feldy
feldy's Avatar
Good luck man.
Old 09-30-2013, 01:52 PM   #63
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This is wrong, and not how subaru's long term knock control (IAM system) has worked in the past. IAM is supposed to persist unless the ecu is reset. As others have shown, on some 86's IAM is persistent, on others it is not. Hence this thread. We are just trying to figure out why it persists on some cars and not on others.
I agree this is something that needs to be hammered out. I am running EcuTek, and my IAM persists until I reflash the ECU with a new ROM, so let me know if there is anything I can do to help figure this out.
Old 09-30-2013, 02:00 PM   #64
mad_sb
Could it be something as stupidly simple as scion / toyota vs subaru?
No Rest:
@King Tut is BRZ
@xjohnx is BRZ
Reset:
@mad_sb is FRS
@feldy is FRS
@regal is FRS
@moto-mike made the comment about the push button start cars seem to keep the IAM... are all BRZ's push button? Are any Toyota's push button?
Old 09-30-2013, 02:09 PM   #65
xjohnx
Grip>Slip
xjohnx's Avatar
all BRZ limiteds are push button, all premiums are turn key.
all scions are turn key, except for the 10 series.
Old 09-30-2013, 02:14 PM   #66
ft_sjo
Drives: GT86
No Rest:
@King Tut is BRZ
@xjohnx is BRZ
Reset:
@mad_sb is FRS
@feldy is FRS
@regal is FRS
The EUDM GT86 is push-button. As you know, mine resets the IAM on start.
Old 09-30-2013, 02:17 PM   #67
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. I have a limited push button.
Old 09-30-2013, 02:20 PM   #68
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I could see this. If it isn't ROM specific, then it could be something in the difference in the wiring in the car. I know when I was posting about where to find a good tach signal I was surprised to find that some of the twins don't have the same certification ECU box under the dash.
Old 09-30-2013, 02:45 PM   #69
mad_sb
Yes, thinking it may be subaru vs toyota rather than push button vs turn key. Perhapse there is an options bit that enables persistent IAM that is not set on toyota ecu's or roms. Although Shiv said the car he has been testing with does keep the IAM and it is a scion running a scion rom so that kinda blows my theory.....
Old 10-01-2013, 03:31 AM   #70
fooyc
fooyc's Avatar
Drives: GT86-JDM
my is a GT86 JDM w push start. don't hv the logger yet... but like to check it out soon.
fooyc is offline   Reply With Quote
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 10:47 AM
Tein Street Advance 99c NR 86drift Australia Classifieds 0 05-23-2013 05:06 AM
Help NEEDED ASAP, Thanks in advance! FR_Soldier_77 Other Vehicles & General Automotive Discussions 9 03-20-2013 10:10 AM
YR-Advance ANREX Cosmetic Modification (Interior/Exterior/Lighting) 11 10-31-2012 09:08 AM
