Old 09-24-2013, 05:20 PM   #1
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
blackened DRLs
Howdy y'all, today I tinted the DRLs on my '13 BRZ. My goal was to match as close as possible the tint on the smoked side markers. My final result was much darker, but I actually think it looks nice and blends in when the DRLs are off. So, with that said, onward with the pics and the DIY!
Tools needed:
10mm socket & 1/2" ratchet
flat head screw driver to pry off push latches
phillips bit for screw latches
2000 grit wet sand paper
blue painters tape
gloss clear coat spray paint
VHT Nite-Shades
wax
micro fiber applicator pads
microfiber cloth
dishwasher detergent
rubbing alcohol or paint thinner (I used rubbing alcohol)
So first thing I needed to do was to remove the DRLs from the front cover, which unfortunately means removing the front cover. To do this, I followed steps 1-9 from @DarrenDriven's DIY on blacking out the FR-S headlights @ http://www.ft86club.com/forums/showthread.php?t=8788
Once the cover is off, each DRL is attached to the cover via two nut/washers tightened on studs. You can see these studs on the DRLs pictured below.
Once the DRLs are detached, the fun begins.
Step 1: In order for paint to adhere to the DRLs it was necessary to rough up the DRLs with a light sanding. Using a little detergent on the wet sand paper, I sanded the DRLs until they were cloudy. *Clean with the rubbing alcohol or paint thinner to ensure surface is clean prior to painting!*
Step 2: Then I masked off the parts I was not interested in painting with painters tape; to exercise an overabundance of caution I also covered with painters tape the plugs and foglight bulb assembly that are attached to the DRLs and not detachable.
Step 3: I went to a well ventilated area with no wind, in my case my empty garage with the door up, and applied one coat of VHT Night-Shades. Maybe I was too heavy handed or else Night-Shades are dark as all get out, but one coat made the DRLs look black, not smoked. As it turns out, I actually like the look of them blacked out instead of smoked.
Step 4: I should have waited an hour and then done a light sanding before adding clear coat, but I didn't. I applied four coats of Rustoleum Ultra Cover Gloss Clear. Then I let them sit for an hour. Below is a picture after this step.
Step 5:*Before polishing, make sure to do a light sanding with little to no pressure with the 2000 grit wet sand paper until the entire surface is cloudy!* I applied a LIBERAL amount of polish on the applicator and went to town on those DRLs. After buffing out the polish they had a nice shine to them, if when you attempt this (at your own risk), if your DRLs are still cloudy after polishing, then just repeat this step until they have a nice shine.
Step 6: Reattach everything is reverse order to how you detached everything in the beginning.
And for SnG's here is a pic of C'thulhu running around naked.Name:  IMG_0174_resize.JPG
9/26/13 Edit: I forgot to mention a couple small, but crucial steps to make sure your DRL's come out smooth and shiny!
Turkish is offline   Reply With Quote
The Following 2 Users Say Thank You to Turkish For This Useful Post:
kalamitykode (07-26-2014), yberther (09-25-2013)
Old 09-24-2013, 08:30 PM   #2
Turkish
Serial Cone Killer
Turkish's Avatar
My final thoughts are:
1) I should have built with blocks a better holder for the DRLs while I was painting, the coats were not very even.
2) I think I also have a trigger finger that is about as heavy as my right foot, the coats seemed awfully thick.
3) I am glad I did this on my DRLs before attempting my tails. I would punch myself if the tails had noticeable imperfections.
Old 09-24-2013, 09:30 PM   #3
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
How do they look when they are on? I like how it looks in your pictures.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Turkish (09-26-2013)
Old 09-25-2013, 09:47 AM   #4
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Looks cool. I'm also curious about how the DRLs look when lit up.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
Old 09-25-2013, 10:40 AM   #5
Turkish
Serial Cone Killer
Turkish's Avatar
They look like they've lost about 10-20% brightness.
Sent from my SCH-I535 using Tapatalk 4
For those who hear him call...
... his name is...
C'THULHU
Old 09-25-2013, 01:35 PM   #6
yberther
yberther's Avatar
Drives: '13 SWP Limited
Wow this looks awesome. Good work man. I'll definitely be doing this!
yberther is offline   Reply With Quote
The Following User Says Thank You to yberther For This Useful Post:
Old 09-25-2013, 01:46 PM   #7
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
They look like they output a good amount of light after being blackout. nice work.
kakarot1657 is offline   Reply With Quote
The Following User Says Thank You to kakarot1657 For This Useful Post:
Old 09-26-2013, 12:47 AM   #8
Turkish
Serial Cone Killer
Turkish's Avatar
It looks nice from a distance, but don't look too closely. I guess that is the down side to knowing where you could have done better. Thanks for the compliments!
... his name is...
C'THULHU
Old 09-26-2013, 12:51 AM   #9
ericmpena
ericmpena's Avatar
Looks great! I've always felt the DRL's were a little too bright anyways.
Old 09-26-2013, 01:41 AM   #10
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Ia! ia! cthulhu fhtagn!
Grymm86 is offline   Reply With Quote
The Following User Says Thank You to Grymm86 For This Useful Post:
Old 09-26-2013, 02:20 AM   #11
Turkish
Serial Cone Killer
Turkish's Avatar
FYI, I forgot part of step 5, please see the red text before attempting this on your own! LOL and I just found another step I missed. All edits will be highlighted in red so you can see what I updated
Old 09-26-2013, 02:28 AM   #12
Turkish
Serial Cone Killer
Turkish's Avatar
So I was curious if it would adversely affect the performance of the car to remove those two abnormal looking growths off the intake tube and just plug them? I presume they just act to silence the car?
Old 09-26-2013, 05:57 AM   #13
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
The snorkel? Most just remove it... I don't think it hurts it. I could be wrong, but most aftermarket intakes dont connect back into that. They will restrict airflow a bit. Just my $0.02
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 09-26-2013, 08:12 PM   #14
Turkish
Serial Cone Killer
Turkish's Avatar
I am planning to install the TRD intake which afaik connects to the oem snorkel. So that would be my reasoning for modding that.
Good LED DRLS? Flako Cosmetic Modification (Interior/Exterior/Lighting) 52 04-28-2013 04:05 PM
Toyota 86 DRLs 86drift Australia Classifieds 8 04-09-2013 12:46 AM
LED DRLs on A/T?? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 16 03-21-2013 07:47 AM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 06:05 AM
LED DRLs bulbs! seven Exterior Parts (Aero, Lighting, Etc.) 0 11-05-2012 02:34 PM
