Old 09-17-2013, 07:34 PM   #1
Foobar
SLO NO MO
Foobar's Avatar
Pressing Brake Turns off Clock/Dims Navi
Looks like I have a wiring issue somewhere. Anyone ever encounter this?
I press the brakes and the clock shuts off and the navigation map goes into night mode. I let up and it goes back to normal.
With headlights on, everything works normally.
Grounding problem somewhere?
Sent from my Nexus 4 using Tapatalk 4
Old 09-18-2013, 11:25 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Do you have OEM taillights?
Old 09-18-2013, 06:20 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
Tom's
Oh and it seems to be intermittent. I just checked this morning and it worked fine.
Old 09-18-2013, 06:36 PM   #4
Mikem53
Drives: FR-S 6MT
Ghosts.. It's the only logical explanation.
Mikem53 is offline   Reply With Quote
Old 09-18-2013, 06:40 PM   #5
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
That, or the dragons again.
Double check the connections on any aftermarket lighting. I don't know much about Tom's, but if it requires re-wiring that would probably be the first suspect. It's an off-chance, but LEDs also give off RF radiation that can interfere with electronics. Cars designed for them have fewer problems, but for instance, when I put aftermarket LED bulbs in my Outback they started causing radio interference (especially in the morning). I don't know if the stock lights are RF shielded (like speakers), but there's a good chance aftermarket ones aren't. Although I don't have any problem with my Valentis.
DoomsdayJesus is offline   Reply With Quote
The Following User Says Thank You to DoomsdayJesus For This Useful Post:
infinite012 (09-19-2013)
Old 09-18-2013, 07:24 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Checked everything out - looks like the Tom's tails were fine, it's my Phastek rear fog/fourth brake light that is dead, and for whatever reason, that dying caused weird things to happen elsewhere. Not sure if the bulb is toast or if something else is, but taking the bulb out of the Phastek socket made everything work like normal again.
Bulb doesn't looked burned out, it's a Sylvania 3157K which goes for about a buck, so I'll pick one up and see if that solves the problem.
Old 09-18-2013, 07:41 PM   #7
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Sometimes being an early adopter isn't so much fun.
Google brz wiring and click first link,
Page 148 onwards
The part where you say everything works with headlights on concerns me
Get rid of the rear fog lamp and toms and revert to oe and tell us what happens
Have you disconnect battery and retried?
448hpsti is offline   Reply With Quote
Old 09-18-2013, 07:44 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
something is touching ground from physical contact when you press the brake.
I could walk you through the steps to try and narrow down the source (I did this with many pinball machine malfunctions), but you have a warranty!!
Old 09-18-2013, 07:49 PM   #9
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Have you checked brake (the call it 'stop' ) lamp fuse? Or whatever you tapped phastek gizmo into?
Old 09-18-2013, 09:15 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
The bulb out might indicate overvoltage. If the next one blows quick theres a hot wire touching the positive wire the lamp.
If the bulb never works there's a dead short.
Take it to the dealer you have a warranty. Remove all electrical mods including the tails first. The isuse might disappear.
Old 09-18-2013, 09:24 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
Replaced the fourth brake / rear fog light bulb and now everything works as expected. I'll keep an eye on it to see if there's an underlying problem.
Thanks for all the suggestions guys!
Old 09-18-2013, 10:40 PM   #12
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
You needs a diode somewhere I suspect
Old 09-19-2013, 10:48 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I knew you had aftermarket taillight mods and that they were causing the issues. I can tell you the only time I have ever seen this issue and it did the exact same thing was when I bought a 1995 Acura Integra from a guy. On the drive home the dash lights would only light up when I hit the brakes. The idiot had placed the dual filament bulb in the single filament bulb housing and the single filament bulb in the dual filament bulb housing in the taillights. I figured it out once I got home. Once something that is supposed to be grounded isn't, the voltage can travel back up the wire till it finds something that is grounded.
Old 09-19-2013, 11:28 AM   #14
Foobar
SLO NO MO
Foobar's Avatar
Yeah, I've seen stuff like that too, but in this case, I've had these lights in place for months and the issue just started happening this week. The bulb is definitely dead. Does it sound right that a dead bulb would cause grounding or other wiring issues?
DIY-- How to bypass your NAVI without moving out your NAVI (Canadian BRZ only) 8987846 DIY (Do-It-Yourself) Guides 77 04-29-2015 02:45 PM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 09:24 PM
Bypassing your NAVI without moving out your NAVI 8987846 CANADA 0 12-24-2012 03:20 AM
CLOCK QUESTION poudre BRZ First-Gen (2012+) — General Topics 16 07-02-2012 03:20 PM
Details: Interior dims, glass, light bulbs Ryephile Scion FR-S / Toyota 86 GT86 General Forum 17 03-01-2012 11:28 AM
