Old 09-01-2013, 03:09 AM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
DIY: Front Brake Pad and Brake Rotor Replacement
20130831-DBA4650_HawkHPPlus_FrontJob-001 by VictorN07, on Flickr
With my recent commitment to track and do HPDE events more, I decided I needed more upgrades in the braking department. Frankly it is one of the areas I have been neglecting.
What I have already
ATE Super Racing Blue DOT4 Brake Fluid
Stoptech stainless steel lines in the front and rear
SpeedBleeders
What we will install today
Hawk Performance HP Plus Brake Pads
DBA 4000 T3 Slotted Rotors
Turns out I have plenty of life left in the OEM pads and rotor. Dust boots look good still. I will hang on to the OEM pads and swap them in if the Hawk HP Plus pads don't work so well on the street. I hear they have to get up to temp to be effective. Also, fuck seized rotors.
Purpose
The purpose of upgrading pads and rotors in the stock braking system isn't to get more stopping power. It is to be able to stop consistently for longer. The Hawk HP Plus pads won't fade as fast as the OEM pads, and the slots in the rotors aid with cooling.
It is definitely not as good as BBK such as the AP Sprint Essex Kits, but every bit helps. The plus side is that this is much cheaper, and you can figure out if drop in parts is enough for you.
I've been told, good pads and fluids is great for the beginner. From there, stainless lines would be the next logical step, then getting better rotors. BBKs are required for the truly hardcore, such as endurance racers.
Fun Story
@firestormriot has purchased a Nikon J1 camera. He ended up taking all the photos using his J1 and the kit 10-30mm lens. I did my usual post processing magic.
It was fun showing him how to use his camera and tips to take interesting pictures. He picked it up very quickly! I love sharing my passions with people. Thanks man for taking the pics while I got dirty.
I also wanted to see if a inexpensive, small senor camera with non-pro glass can make good pictures. In my opinion @firestormriot and his J1 did admirably. You can see the results below.
Thanks!
Thank you @Chris@Phastek for securing the goods for me. Thanks to Dave Staba at DD Performance Research for the life saving tip that will be explained later on. Thanks to @firestormriot for the garage space and extra set of hands.
Wanted to acknowledge @PMok for writing the initial guide for pads. I hope to expand on this. You can find his guide here http://www.ft86club.com/forums/showthread.php?t=24614
F1point4 is offline   Reply With Quote
The Following 6 Users Say Thank You to F1point4 For This Useful Post:
amram (03-27-2014), kodyo (12-20-2014), PMok (09-01-2013), Strife26 (08-23-2018), twodollarcuts (05-18-2021), Young_makaveli (09-01-2013)
Old 09-01-2013, 03:10 AM   #2
F1point4
Photo Specialist
F1point4's Avatar
Let's Go!!!
Pictures taken with a Nikon J1 with the kit 10-30mm and edited in lightrom!!!! Not my usual Olympus Pro gear here. I like the result!
Once again I do not take responsibility for any damage done to you or your vehicle. Note that this is work on a critical safety system on your car. Customize, maintain, and upgrade at your own risk. Be safe.
Loosen the wheel lugnuts while on the ground
Jack up the car (http://www.ft86club.com/forums/showthread.php?t=10111)
Remove the wheels
Part Numbers
20130831-DBA4650_HawkHPPlus_FrontJob-002 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-003 by VictorN07, on Flickr
Service Manual Diagrams
20130831-DBA4650_HawkHPPlus_FrontJob-004 by VictorN07, on Flickr
[img]http://farm8.staticflickr.com/7390/9640126939_57c***44ce_c.jpg[/img]
20130831-DBA4650_HawkHPPlus_FrontJob-005 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-006 by VictorN07, on Flickr
Brakes are stock, mostly, heh
20130831-DBA4650_HawkHPPlus_FrontJob-007 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-008 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-009 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-010 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-011 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-012 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-013 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-014 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-015 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-016 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-017 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-018 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-019 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-020 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-021 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-022 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-023 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-024 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-025 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-026 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-027 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-028 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-029 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-030 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-031 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-032 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-033 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-034 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-035 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-036 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-037 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-038 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-039 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-040 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-041 by VictorN07, on Flickr
You can go shimless. You may or may not get extra noise. Track days may also burn off all the grease
20130831-DBA4650_HawkHPPlus_FrontJob-042 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-043 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-044 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-045 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-046 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-047 by VictorN07, on Flickr
20130831-DBA4650_HawkHPPlus_FrontJob-048 by VictorN07, on Flickr
The Following 33 Users Say Thank You to F1point4 For This Useful Post:
amram (03-27-2014), BabaYaga (12-21-2014), Bcarlos (03-27-2014), Black Tire (12-21-2014), BRZBlack (04-02-2021), CkOne (10-22-2020), clayrush (03-30-2014), DarkSunrise (09-17-2013), dp1 (04-01-2015), dphan (09-08-2013), elbles (06-08-2014), fstlane (09-01-2013), grst1 (03-21-2021), hyper4mance (09-17-2013), illicitstylz (07-25-2015), JetSetKuro (03-24-2021), JimmyMac (09-01-2013), Keenercarguy (01-27-2016), kevaughan (04-27-2024), kodyo (12-17-2014), Mchilese (07-27-2017), mike_ekim1024 (12-07-2013), NorCal_Guy (03-30-2014), radon55 (08-21-2019), RehabJeff86 (09-20-2013), RL_BRZ (09-06-2018), shiumai (09-01-2013), stevo_12v (05-14-2015), suaveflooder (09-01-2013), Tiago (03-27-2014), tian105 (05-01-2019), willypongtb (03-27-2014), Young_makaveli (09-01-2013)
Old 09-01-2013, 03:10 AM   #3
F1point4
Photo Specialist
F1point4's Avatar
Here are example bed in instructions. If you don't bed in your brakes they may not work as well as they could. Here are the ones that come with the hawk pad.
Bed-In Instructions
After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
DO NOT DRAG BRAKES!
Allow 15 minutes for brake system to cool down.
After step 4 your new pads are ready for use.
Dragging brakes apparently means, don't ride the brakes. I think your brakes can glaze over from all the high heat. Instead, stop with purpose when doing this procedure.
Old 09-01-2013, 03:59 AM   #4
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Nice write up! Did you happen to weigh the new rotors vs. stock?
JimmyMac is offline   Reply With Quote
Old 09-01-2013, 04:39 AM   #5
PMok
Codename: Stitch
PMok's Avatar
great photos and writeup! a few alternative tools/tips:
- in place of the bungee cord, I have used a spare jackstand with a sufficiently wide top surface (or put a board/plate on top) to support a caliper so that it doesn't hang from the brake lines while changing disc rotors. Really you can put it on anything that reaches high enough so it can rest on it without stretching the line.
- if you don't have a brake piston compression tool, a basic c-clamp in combination with your old brake pad will work to compress the piston.
The Following 3 Users Say Thank You to PMok For This Useful Post:
amram (03-27-2014), F1point4 (09-01-2013), Keenercarguy (01-27-2016)
Old 09-01-2013, 05:05 AM   #6
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Very nice write up
Useful information here
Thank you
Young_makaveli is offline   Reply With Quote
The Following User Says Thank You to Young_makaveli For This Useful Post:
Old 09-01-2013, 10:41 AM   #7
F1point4
Photo Specialist
F1point4's Avatar
Unfortunately I did not weigh them. By feel both are heavy hahhaha
Old 09-01-2013, 10:59 AM   #8
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Thanks for sharing....
RL_BRZ is offline   Reply With Quote
Old 09-01-2013, 11:55 AM   #9
jimmy4thenguyen
Drives: Whiteout FRS
This is amazing. Wow
jimmy4thenguyen is offline   Reply With Quote
Old 09-17-2013, 10:28 AM   #10
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If I'm just replacing the rotors on a new-ish car (with appox 1500 easy driving miles), do u think I can skip sliding the calipers up? Can I just jump straight to removing the bracket bolts and move the whole brake assembly out of the way?
Fizz is offline   Reply With Quote
Old 09-17-2013, 12:31 PM   #11
F1point4
Photo Specialist
F1point4's Avatar
You can do that, but you may still need to compress the caliper pistons to accommodate the extra thickness of the rotor.
The Following User Says Thank You to F1point4 For This Useful Post:
Fizz (09-17-2013)
Old 09-17-2013, 12:34 PM   #12
OrbitalEllipses
Drives: Attitude
Oh god HP+...
Old 09-17-2013, 01:27 PM   #13
F1point4
Photo Specialist
F1point4's Avatar
Oh god HP+...
What's wrong with HP+ pads?
Old 09-17-2013, 01:40 PM   #14
OrbitalEllipses
Drives: Attitude
One of the crappiest pads I've ever used. The dust, the noise, etc. weren't that good a trade off for the brakes I got in return. Ferodos and Carbotechs worked way better.
brake pad, brake rotor, diy
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 03:39 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 08:15 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
