Drives: GT86
Greeting. if some Experter help me out we well be much appreciate it to him.
my car running only afew miles. I have FBM Turbo kit and now im having one issues belong to Randomly thrown same Code P0441 all time. I send my car to the shop who installed the kit we inspectd some hoses looks like everything hoocked up correctly even we we check it the gas cap we couldn't find any more then a small leak in turbo oil feed line and already fixed with new gasket and selant silicon. eveytime I clear the code with Ecutek it com randomly during crusing in afew days later asame code. keepin the dashbored with check engine and TRC Lights on!!
#2 |
do you have the ecutek boost control that uses the evap solenoid hookup? that's an evaporative emissions code.
#3 |
Drives: GT86
#4 |
Drives: GT86
#5 |
Drives: Pile of junk
if you have mbc that came with fbm kit then you dont have the mbcs that hooks to the evap system to control boost through ecutek
unless they switched. last i heard LJ was using a reg old mbc for boost |
#6 |
Drives: GT86
#7 |
Drives: Scion FR-S
I had the same code after installing my FBM turbo. It went away on its own...
#8 |
I Love custom Turbo kits
Drives: Limited BRZ
I have the same issue with P0451. It happened after I disconnected the EVAP sensor to try the ECUtek boost control. the only way I got rid of it was by telling my tuner to disable it.
No other way around it so far...
#9 |
Drives: 2013 Raven FR-S
There is no check valve on the evap system, right? And the evap system is set to open at higher loads (I think) to allow the engine to suck the fumes in. But if the valve open under boost it's possible that the turbo is pressurizing the evap system.
Just my guess. Aaron |
| The Following User Says Thank You to ATSAaron For This Useful Post: | stugray (11-09-2015) |
#10 | ||
Drives: 2013 Asphalt FR-S
See here for the fix Quote:
Evap system description and test procedure begin on page 1135 of the FRS manual posted on this site. LOTS of good info. In short P0441 is associated with evap stuck, open, evap stuck closed, or a gross leak. My guess is the latter
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Sportsguy83 (09-16-2013) |
#11 |
That Guy
Drives: 2013 asphalt FRS MT
Did you ever get this figured out?
#12 |
NASA SpecE30 Racer
My guess is something is wrong with one of the vacuum lines for the fuel vent system. I would make sure that all the lines are connected properly from where the metal fuel vent line ends near the quick disconnects for the fuel lines to where the valve gets vacuum from the bottom of the intake manifold. The vent line was probably disconnected during the install of the fuel injectors.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#13 |
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
I got the same code. Well I had the same code.
#14 |
Drives: Limited BRZ
Had? How did you fix it?
| Will headers cause me to not pass smog? | 67corvette | Engine, Exhaust, Transmission | 39 | 11-13-2018 12:12 PM |
| emission standards? | rainmonkey | Northern California | 10 | 04-23-2013 08:50 PM |
| Will the borla headers pass emmision test? | Frsexxxy | Engine, Exhaust, Transmission | 3 | 03-24-2013 10:39 AM |
| Does the US BRZ meet emission standards of all 50 states? | slowbrz | BRZ First-Gen (2012+) — General Topics | 11 | 11-15-2012 02:31 AM |
| Emission and noise restriction in DMV | guy | Mid-Atlantic | 6 | 11-14-2012 01:30 PM |
