Old 09-12-2013, 10:58 PM   #29
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by ric342 View Post
my max speed is 75 damn 85 dangerous be careful.
Interstates around here have a 75mph speed limit, and some of the ones in Utah are up to 80 now. If you're only driving 75, you're going to be passed by most traffic (once you're out away from cities).
chrisl is offline   Reply With Quote
Old 09-12-2013, 11:57 PM   #30
GIMMICK
I sometimes get up to 80 mph, however in LA I can never sustain for more than a few seconds before you have to slow down for traffic.
When my wife got her first benz and she was driving on the freeway passing everybody, I asked her to slow down. She told me "See I'm going less than 50 mph." I had to point out that she was looking at the tachometer and the 50 she was looking at meant fifty hundred rpm (or 5000 rpm). She was actually going over 90 mph!!!
GIMMICK is offline   Reply With Quote
The Following User Says Thank You to GIMMICK For This Useful Post:
Anthony (09-13-2013)
Old 09-12-2013, 11:59 PM   #31
Nassty
Drives: 13 FR-S, 08 ZX-10R
My tc ran about 4k at 90 but at that point and up it would eat gas like a v8
i used to have to drive from nyc to buffalo a lot so i would cruise at 100-105 with my trusty radar - right now im cruising around 85-90 in my frs since its still semi new to me
Nassty is offline   Reply With Quote
Old 09-13-2013, 12:26 AM   #32
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
depends on my mood. If im pissed ill drive fast. If im bored ill drive fast, if im sad ill drive fast to make me happy. I guess i just drive fast..
bkblitzed is offline   Reply With Quote
The Following 5 Users Say Thank You to bkblitzed For This Useful Post:
Anthony (09-13-2013), Enraged21 (09-13-2013), Evil Jesus (09-13-2013), Luis_GT (09-15-2013), Yamajee (09-13-2013)
Old 09-13-2013, 12:35 AM   #33
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
to add to the above... When I start to feel shakey (sleepy), I drive fast-er. It gets the rush going. Then after the rush, I'm like, "dammit, gotta stop now before I doze off."
Old 09-13-2013, 12:42 AM   #34
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
depends on the music I'm listening too. Reggae I tend to chill. House music I tend to go into race car mode.
Enraged21 is offline   Reply With Quote
Old 09-13-2013, 12:45 AM   #35
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Same here. Rock I tend to drive fast. Metal I tend to drive fast.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-13-2013, 08:20 AM   #36
regal
Drives: Scion FR-S/Toyota Yaris
I log less issues and knock cruising at 85 mph than I do driving rural twisty roads, you could probably drive this car at 90 mph stopping only for gas and oil changes for a million miles. Its the lowest wear driving you can get.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-13-2013, 09:22 AM   #37
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Our highways are really dead, nearly 8 lanes, and they're linked on the border of each city so maybe that's why the speed over here is 88 miles being the maximum.
now I'm 100% relieved.
Yamajee is offline   Reply With Quote
Old 09-13-2013, 10:18 AM   #38
TomWalton
Drives: 2013 FRS
Sonic anxiety relief at cruising speeds
I got relief from the sense of imminent destruction at high revs - and at highway cruising speeds - by blocking that silly tube that brings induction noise into the passenger compartment. The sound it made was always incongruous to me; didn't sound like an engine running, sounded like a vacuum cleaner. I found it embarrassing, at least; sort of a toy car "feature".
I know this doesn't directly address the OPs question, but I find the car much more pleasant to drive with just the honest engine and exhaust noise. It might lower OP's anxiety level at his cruising speeds if the extra - and silly - sucking sound wasn't being piped in.
TomWalton is offline   Reply With Quote
The Following User Says Thank You to TomWalton For This Useful Post:
Old 09-13-2013, 10:22 AM   #39
Anthony
Weight Nazi
Anthony's Avatar
...and save weight.
Old 09-13-2013, 03:32 PM   #40
Originally Posted by Yamajee View Post
I know the transmission has close-ratios and all that but the question is, is 3.5-3.7k rpm okay for constant 30 minutes let's say or should I go lower on speeds?
It should not be an issue. Subaru boxer engines are used, with reduction gears, in experimental aircraft all over the world. In that application they are run constantly at or near full RPM for thousands of hours.
I have personally flown with one in an RAF2000 gyrocopter and a Zenith 601HD fixed wing. I would not hesitate to do it again.
At the revs you are talking the engine is not even at a good fast walk never mind running hard, compared to these uses of them.
Anthony (09-14-2013)
Old 09-13-2013, 03:50 PM   #41
Steve201brz
is there a reason is 88? why not round it to 90 or down to 85? first assumed it was the conversion from kmh, but thats 141... kinda curious
Steve201brz is offline   Reply With Quote
Old 09-13-2013, 03:58 PM   #42
bestwheelbase
Drives: 1985 P-Type
Have you exported these logs anywhere? Sounds like interesting data.
5th Gear Grind at Freeway Speeds? l0aded Issues | Warranty | Recalls / TSB 124 03-21-2018 08:04 PM
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 07:40 PM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 11:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 03:41 PM
Post you speeds for fun... seven Off-Topic Lounge [WARNING: NO POLITICS] 48 01-27-2013 08:37 PM
