Old 09-11-2013, 04:10 PM   #281
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Young_makaveli View Post
I accidentally removed a bit a sealant from the outside while checking.. Hope it wont start leaking now
If what you removed causes it to leak it was only a matter of time. The sealant doing all the work is relatively far from your fingers until you pull the plate off, don't worry unless you manage to set your engine bay on fire or you need to pull that plate off for some reason (which I have no idea why you would unless converting to an Auto?).
ineedyourdiddly
Young_makaveli (09-11-2013)
Old 09-11-2013, 04:14 PM   #282
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Maybe it was just excess sealant cause it came of really easily and also I noticed on the transmission housing that there was orange sealant on it too that can be removed fairly easily from the outside as there was already some missing.
Young_makaveli is offline   Reply With Quote
The Following User Says Thank You to Young_makaveli For This Useful Post:
SuperDave (05-27-2016)
Old 09-11-2013, 04:19 PM   #283
Raceseng
Raceseng's Avatar
The Raceseng Cam Plate is ready to be purchased. Instead of doing a group buy which takes days and weeks to fulfill... We decided to offer a discounted price to the first 30 buyers. We only made 30 cam plates, so it is first come first serve! All orders ship same day as long as they are placed before 4PM (EST).
Check out the Cam Plate on our webstore - http://www.raceseng.com/cam-plate-20...r-s-subaru-brz
Any questions, please feel free to email me directly - jarrett (@) raceseng.com
Thanks much!
Raceseng is offline   Reply With Quote
The Following User Says Thank You to Raceseng For This Useful Post:
Marrk (09-11-2013)
Old 09-11-2013, 04:29 PM   #284
Young_makaveli
Drives: 2013 frs
My friend has a 2012 frs and is not leaking and hes asking if pulling the plate by hand cause it to leak?
:s
Old 09-11-2013, 04:53 PM   #285
Raceseng
Raceseng's Avatar
I highly doubt he was able to put enough force on the plate to break its seal.
:s
Old 09-11-2013, 04:54 PM   #286
Young_makaveli
Drives: 2013 frs
Thanks much!
You think manufactured 2013 frs will need this?
Im bone dry there
Old 09-11-2013, 05:00 PM   #287
Raceseng
Raceseng's Avatar
Our 2012 FRS is bone dry too... It is not happening on every car. For instance, our autoX racer, Eric Simmon's plate leaked all over. His interior smelled of burned oil something awful.
If you don't have an issue, don't make one by touching it!
Im bone dry there
The Following 3 Users Say Thank You to Raceseng For This Useful Post:
Marrk (09-11-2013), Nik33615 (12-22-2013), Young_makaveli (09-11-2013)
Old 09-11-2013, 05:35 PM   #288
Marrk
Drives: Honda Fit
Thanks much!
That looks like a nice piece of work, my friend. I am bookmarking your site.
Note: I'm a perfect Size M if you want to thank me by sending me a free t-shirt.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
Raceseng (09-11-2013)
Old 09-11-2013, 06:44 PM   #289
Raceseng
Raceseng's Avatar
Shirts are 50% off right now... It's your chance to get a medium! Thanks Marrk
Marrk (09-11-2013)
Old 10-14-2013, 09:13 PM   #290
Young_makaveli
Drives: 2013 frs
Any new updates on this issue?
I have a little over 2000km and still good
Old 10-17-2013, 12:32 PM   #291
Raceseng
Raceseng's Avatar
The cam plates are back in stock and over half the production run is gone already. There are about 25 Cam Plates left in stock!
Raceseng Cam Plate - http://www.raceseng.com/cam-plate-20...r-s-subaru-brz
Old 11-14-2013, 02:00 PM   #292
SasaGT86
Drives: Toyota GT86 Lightning Red MT
Hello I'm new here. I was driving on the freeway last week and it started to smell pretty bad (oil smell). It started to smell when the car was stationary. I haven't checked the plate yet but I'm pretty sure that's the problem.
The car is GT86
The car has around 5000km on it or 3500 miles
SasaGT86 is offline   Reply With Quote
Old 11-18-2013, 10:20 PM   #293
Raceseng
Raceseng's Avatar
The car is GT86
The oil changes viscosity due to heat so it is physically possible for the oil keep leaking from the cam plate even though the car is sitting still. Most likely your cam plate is leaking.
Old 11-18-2013, 11:05 PM   #294
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I had some leakage a week after i changed my oil. Try to re-tighten your oil drain plug. I learned that if the bolt doesn't sit right just a tiny bit, it'll leak. good luck!
Jolaessss is offline   Reply With Quote
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 04:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 05:43 PM
