Old 05-27-2013, 06:37 AM   #1
derka-derka
Drives: Silver GT86
reverse camera wiring
considering getting a cheapo revrse camera on ebay. I got a aftermarket pioneer HU which has a "reverse" wire. where should i wire that to? I believe its a signal wire that tells the HU to switch to Video In when in reverse gear.
thnx
derka-derka is offline   Reply With Quote
Old 05-27-2013, 01:00 PM   #2
spgrizz22
Drives: Scion FR-S
thnx
Hey I'm not really good with cars but you could always go on crutchfield.com and be like "I'm buying your aftermarket camera could you tell me where it goes in my headunit." And they will probably will help you faster!
spgrizz22 is offline   Reply With Quote
The Following User Says Thank You to spgrizz22 For This Useful Post:
NYCsubaruBRZ (09-09-2013)
Old 05-27-2013, 01:30 PM   #3
cruzinbill
Drives: Argento 6spd FR-S
Reverse wire is wired to the reverse wire of the car. It senses when you are in reverse to switch to the rear view cam.
You should be fine with most of the ebay reverse cams, most are pretty good quality.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
Old 05-27-2013, 10:10 PM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Tap into the pink reverse light wire running down driver side wire bundle. It is a tiny wire so be careful. You can use this as power for your camera or tie it directly to the back of your Pioneer HU. If you tie it directly, you will need to figure out another way to get your camera power.
mit_peid is offline   Reply With Quote
The Following 2 Users Say Thank You to mit_peid For This Useful Post:
Bykov (09-17-2017), NYCsubaruBRZ (09-09-2013)
Old 05-28-2013, 08:15 AM   #5
derka-derka
Drives: Silver GT86
thnx mit. is the pink wire a signal wire or is it actual 12v +ve wire for reverse lights?
The Following User Says Thank You to derka-derka For This Useful Post:
Old 09-09-2013, 10:48 PM   #6
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
is there a connection for a reverse camera on the stock BRZ headunit?
NYCsubaruBRZ is offline   Reply With Quote
Old 09-11-2013, 03:09 AM   #7
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
thnx
Tap this pink wire which provides 12V signal ONLY when in reverse. http://simplicity.elitecaraudio.org/bfrs49.JPG
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
Trap63 (09-11-2013)
Old 09-11-2013, 03:33 AM   #8
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
get the reverse camera kit from beat-sonic, check on the groupbuy.
its pretty much plug and play, splicing one wire.
Zardoman is offline   Reply With Quote
Old 12-06-2013, 12:30 AM   #9
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
I would suggest that you pick up the orange-white wire coming out of the front end - closest to the engine - from connector HD1. That's the other side of the connector in the photograph. The wire is orange with a white stripe and silver bands.
It's a little larger in gauge, you have more room to tap into it, and it's a bit more stealthy. TEST FIRST!
I installed a JVC audio/GPS system, the backup camera is working like a champ now.
Refer to the Subaru BRZ (same as the FR-S) wiring diagram, P. 162. http://www.ft86club.com/forums/showt...wiring+diagram
Here's what I did:
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
The Following 2 Users Say Thank You to ChiefG For This Useful Post:
SVXdc (06-13-2015), willypongtb (05-18-2015)
Old 12-06-2013, 11:20 PM   #10
JBV88
Orange Wire
What does the orange wire feed? Is it reverse related or an accessory wire?
JBV88 is offline   Reply With Quote
Old 05-18-2015, 02:28 PM   #11
willypongtb
P MAI86
Drives: subaru brz limited
@ChiefG thanks for your diagram really make my install Apex-i Smart Accel Controller much ez and faster.
willypongtb is offline   Reply With Quote
Old 05-19-2015, 04:55 AM   #12
P3tras
Drives: Subaru BRZ '13 WRB
No need to tap into these wires! Stock BRZ headunit connectors already have reverse wire. It is second pin on largest 28pin connector (first pin is unused - empty). As I recall that wire had orange stripe, but I am afraid to be mistaken. It does give 12V out when in reverse
P3tras is offline   Reply With Quote
Old 05-25-2015, 12:45 AM   #13
tanvtang
Drives: 2015 Base Scion Frs
Hi, I recently purchased a Scion Frs, and I am going to install a backup camera soon. Does any have suggestions? What brand should I go with? Thanks in advance.
tanvtang is offline   Reply With Quote
Old 05-25-2015, 01:08 AM   #14
DESTINY-BRZ
Drives: RED LIMITED BRZ
FIT CAMERA
http://www.ebay.com/itm/PLUGandGO-In...a352d2&vxp=mtr
SUBARU MAKES A CLEARER ONE BUT WOULD MESS WITH YOUR WARRANTY
DESTINY-BRZ is offline   Reply With Quote
Valenti Japen LED Reverse Tailight USDM Wiring Furtive DIY (Do-It-Yourself) Guides 12 08-21-2015 10:31 AM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 11:03 PM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 01:25 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 09:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 11:21 AM
