Old 08-31-2013, 03:30 AM   #183
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
The part numbers for the door panel knee pads, those are the padded type with red stitching yes?
Fizz is offline   Reply With Quote
Old 08-31-2013, 05:42 PM   #184
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thank you for the DIY, and a special thank you to JPM Coachworks for the parking brake boot and the Kneepads.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
chanomatik (09-01-2013)
Old 08-31-2013, 05:49 PM   #185
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Looks nice
Kelbyat07 is offline   Reply With Quote
Old 09-02-2013, 09:50 PM   #186
that_guy
Dances with Cones
that_guy's Avatar
The part numbers I posted above are for the synthetic leather with red stitch...aka, the "JDM" ones that everyone wants. These come standard on the 2014's, so they can be ordered from your local dealer using the numbers above.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 09-02-2013, 11:33 PM   #187
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
For Center Console Knee-pad & Armrest Installation - Simultaneously - Remove the Console, then Drill for Armrest Installation.
You actually get to the point where the console is nearly loose anyway to install the knee-pads, so just 4 more screws around the base of the gear shifter + 2 more larger screws at the bottom of the console below the arm rest cavity and the console comes out free and clear.
Once the console is out as one large piece of plastic, adjusting the template fit conveniently, drilling the console perimeter accurately, cleaning the drilled holes thoroughly, then setting and re-installing the armrest is a much easier process than doing it when the console is still wedged between seats in the car.
You save considerable time and effort on installing the Armrest, once you pull the console out as part of installation process for the knee-pads.
Sorry, I did not take photos, but it was a very clean and smooth installation that way.
Zagmeister is offline   Reply With Quote
Old 09-04-2013, 02:04 PM   #188
BRZ-OwnzJo0
BRZ-OwnzJo0's Avatar
Drives: 2016 WRX Limited
Does anyone know how to access the bottom screws of the center console in a limited with the dual climate control? I can't figure out if the whole piece pops out or not but I'm not about to pry on it to find out..
BRZ-OwnzJo0 is offline   Reply With Quote
Old 09-04-2013, 02:56 PM   #189
forzajuve
Drives: Ultramarine 86 - 6MT
Do people get bloody knees while driving this car or something? :0
forzajuve is offline   Reply With Quote
Old 09-04-2013, 03:09 PM   #190
tonystewart
Yes
Old 09-04-2013, 05:03 PM   #191
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
They rub your knees sore enough to make you feel like a hooker that just had someone run off without paying for your services.
The Following 2 Users Say Thank You to chanomatik For This Useful Post:
forzajuve (09-04-2013), tonystewart (09-04-2013)
Old 09-04-2013, 09:31 PM   #192
leon78
leon78's Avatar
Drives: 13 Whiteout
Need more lateral G's in your life...than you will know.
Sent from my yotaru
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 09-04-2013, 11:59 PM   #193
forzajuve
Damn I should start test "crash" driving my car from now on. Apparently I am missing out on a number of thrills and hooker encounters... :[
The Following User Says Thank You to forzajuve For This Useful Post:
chanomatik (09-05-2013)
Old 09-07-2013, 01:53 AM   #194
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
so you need to buy this in order for the knee pads to work ?
http://www.ebay.com/itm/TOYOTA-JAPAN...37c6f0&vxp=mtr
ucsmfu is offline   Reply With Quote
Old 09-07-2013, 02:34 AM   #195
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If you want to install the padded door kneepads....then yes.
The Following User Says Thank You to Fizz For This Useful Post:
chanomatik (10-01-2013)
Old 10-01-2013, 01:07 PM   #196
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by that_guy View Post
Well I work for corporate, so I just ordered them from work. But they are now in the system here in Canada and can be ordered. In the USA I think they already had them input. Numbers below.
Door Panel Knee Pads:
(LH) SU003-04437
(RH) SU003-04436
Centre Console Knee Pads:
(LH) SU003-01920
(RH) SU003-01919
Speaker Grilles:
(LH) SU003-04433
(RH) SU003-04432
Speaker Grille Trim Rings:
(LH) SU003-03287
(RH) SU003-03286
Speaker Grille Screws (Required for Installation of Pads):
SU003-02917 (x6)
You need all of the above to complete installation...well, that is if you want both the console and the door pads for both sides...
I just left a Scion dealership in the states and not one of these part numbers was in their system.
So who has the best prices online?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 05:00 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 02:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-28-2012 12:13 AM
FS: console knee foam pads 86_ZN6 Interior Parts (Incl. Lighting) 9 07-21-2012 10:46 AM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 11:43 AM
