Old 08-19-2013, 11:50 AM   #169
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by moto-mike View Post
Ooh...what do we have here
Yup, it's awesome. E85 like performance on pump gas. Holds to redline, no issues despite no IC. You DO want a 3 bar MAP for this.
On E85? Holy hell it rips. Spent the better part of the last two days working on the pump gas tune and it looks good so far, should get it out to rest of our innovate people in the next week or so. Just waiting on confirmation from some of the folks to make sure the new tune is doing its job.
ETA on the pulleys is pending, we want to make sure these hold up good over time. 0 issues so far on the stock Innovate belt.
so jus heard u got some new parts put on and higher numbers....hows that tune coming? and cant wait to hear how the new parts are (ill let you post up what u installed)
lbroskee is offline
The Following User Says Thank You to lbroskee For This Useful Post:
Subzero (08-19-2013)
Old 08-19-2013, 02:50 PM   #170
sw20kosh
Drives: 2013 Black FR-S
I have his recent tune on pump gas with stock pulley and holy hell it feels GOOD.
to Mike
sw20kosh is offline
Old 08-19-2013, 03:06 PM   #171
xjohnx
Grip>Slip
xjohnx's Avatar
to Mike
Definitely feeling better than the previous! Time to get @moto-mike those logs i've been promising. hopefully we can finish up the 93 stuff before i have to refill so i can go to e85 next.
I might try to get some dyno time friday afternoon.
xjohnx is offline
Old 08-19-2013, 08:55 PM   #172
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Mike,
Let me know about the pulley's when they are available. I know Innovate is working on some but of course I have a few customers interested in getting a little more power soon from the 70mm pulley.
From what we tested the 70mm pulley should work with the belt in the 75mm kit. Just an FYI.
Also any reason why you need the bigger MAP sensor? We have a lot of customers out there with no problems on the OEM map sensor and the MAF sensor has plenty of room for tuning. But if there is a reason why would be interested in hearing. I do apologize if this was already stated, but I can not keep up with the thread, along with every other car we work on.
Cheers,
William Knose
DeliciousTuning is offline
Old 08-19-2013, 09:03 PM   #173
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
In for 70mm and 66mm pulleys! Definitely buying
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
Old 08-26-2013, 02:58 PM   #174
Sonolin
Any updates?
Sonolin is offline
Old 08-27-2013, 09:14 AM   #175
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Sonolin View Post
Any updates?
.......soon
Xero-Limit is offline
Old 08-27-2013, 11:12 AM   #176
Raven604
You update me right mrow!
Sent from my SGH-I337M using Tapatalk 4
Raven604 is offline
Old 08-27-2013, 11:54 AM   #177
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
@moto-mike @Dezoris do you happen to have the part number for the injector o-rings?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline
The Following User Says Thank You to ecko04 For This Useful Post:
448hpsti (08-27-2013)
Old 08-27-2013, 02:24 PM   #178
Dezoris
Dezoris's Avatar
This is for port injectors
SU00300335 (O Ring)
SU00300324 (IM Seal)
SU00300317 (Grommit)
Dezoris is offline
The Following User Says Thank You to Dezoris For This Useful Post:
ecko04 (08-27-2013)
Old 08-28-2013, 07:52 AM   #179
regal
Drives: Scion FR-S/Toyota Yaris
This right here is what we've need for this kit. http://www.ft86club.com/forums/showp...postcount=1261
This makes the kit complete no more un-tuneable kit comments from @Dezoris, no more guess work.
@moto-mike, since you are a lot closer to me than Florida will you be able to supply and base your tune around this important intake sensor?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline
Old 08-28-2013, 08:36 AM   #180
Xero-Limit
Xero-Limit's Avatar
The above is not necessary on this setup currently. We've thought about making it, but put it on the back burner because: there's no IC, and it is a supercharger. The temperature increase will always be the same delta for any given RPM/boost. That means we can just scale the timing maps appropriately with RPM/boost using solely the 3 bar MAP sensor (or stock MAP sensor for stock pulley with some loss of resolution in the 5-9 psi transition areas). Other temperature increases (i.e. heat soak, hot weather) will be directly proportional to coolant and air temp, so there is absolutely 0 practical need for this at present. Once the IC comes out it will be a different story. So until we see a real need for it, you're better spending your cash on something with more tangible results.
Old 08-28-2013, 08:47 AM   #181
regal
Thanks you are correct that using thermo-dynamics the temperature post supercharger should be predictable, didn't know you guys were that sophisticated most tuners aren't.
What about a guy who only wants a 50-60 hp boost is the intercooler something you would wait for? I am all about avoiding complexity when it comes to mods.
Mods:
regal is offline
Old 08-28-2013, 10:03 AM   #182
troek
troek's Avatar
Drives: 2012 Toyota 86
i was under the impression the intercooler could be added on later?
troek is offline
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 11:25 PM
Innovate questions Fast_Freddy Forced Induction 12 07-02-2013 03:27 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
innovate SC for sale kioton32 Forced Induction 4 04-08-2013 12:42 PM
