Old 08-26-2013, 05:48 PM   #1037
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Originally Posted by SliverBrz View Post
can you guys make a GS bracket for that hose? Id be down to buy one even though the zip tie solution works lol
Currently we do not have plans to do that, because on non-usdm cars there is a harness that runs on the back of the intake manifold, and there is a bracket bolted in that location for that harness. If you look at the back on the intake manifold you'll see several plastic empty slotted holes doing nothing, there is where that harness runs. Not having access to a non-usdm car makes it difficult to make a bracket that will play nice with the factory bracket that is in place here. There is also the worry that this threaded hole will not appear in future model years, which is ultimately why we decided on a different solution. BUT, you never know
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 08-26-2013, 06:28 PM   #1038
Chee-Hu
Chee-Hu's Avatar
What if you don't have a torque wrench ?
If you have a Harbor Freight around your neck of the woods, I suggest looking for one of their ads that contains $9.99 for a torque wrench in either 1/4, 3/8, or 1/2". Not the best torque wrench, but it does its job. I picked up one of each this weekend as there is a 9 limit per coupon.
Chee-Hu is offline   Reply With Quote
Old 08-26-2013, 09:42 PM   #1039
dawnst3ar
Drives: 2013 MT FR-S Asphalt
So, after I finished installing the bar on the FR-S, I looked at my wife and said "once again, I have more parts from GrimmSpeed than any other manufacturer".
Her response:
"Really? Huh. Well, except for Subaru, but I guess that is certainly true of Toyota!"
dawnst3ar is offline   Reply With Quote
Old 08-26-2013, 09:42 PM   #1040
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You could borrow my car if you're willing to pay for postage.
Old 08-26-2013, 10:07 PM   #1041
PNW FRS
PNW FRS's Avatar
One of the 86-faithfull has a nice bracket that he developed...
http://www.ft86club.com/forums/showt...=33233&page=47
(scroll down about 1/2 down the page...)
He has a prototype installed... (and I'm going install one in a few days). Looks very nice... and for those that are true DYI... he has a parts list on the post.
Man I love this forum....
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 08-26-2013, 10:16 PM   #1042
SliverBrz
Drives: Silver 2013 BRZ limited
personally, i don't like it lol.
too much going on
i want one simple bracket instead of like nuts washers etc...
SliverBrz is offline   Reply With Quote
Old 08-26-2013, 11:37 PM   #1043
sierra
Drives: Skoda Yeti DSG diesel 4x4
Chase
Engineering
Does this help?
Name:  Strut Brace 003 (Custom).JPG
sierra is offline   Reply With Quote
Old 08-27-2013, 05:50 AM   #1044
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
too much going on
I do agree that there is too much going on. I would like to simplify the design with less parts, just haven't found the right size L bracket to do so. I would like to re-emphasize why I used a rubber isolator though. It allows the hose to flex naturally when the engine moves. A fixed bracket would not allow this. I would like to get my hands on that bracket for the non-USDM cars and see if I could use it instead. It looks as though one could mount the isolator to that and then clamp the hose. Anybody on the other side of the pond or down under have access to a part number? I think the bracket could be used to hold the AC line and still mount the existing wiring harness. This would be a universal solution for all 86's...
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 08-27-2013, 09:05 AM   #1045
Optimus Prime
Optimus Prime's Avatar
Drives: Whiteout 2013 FR-S
I did the same. I bought it specifically for this install. While HF quality tends to be lacking, for as often as I'll use this, it was already worth the $10 spent.
Optimus Prime is offline   Reply With Quote
The Following User Says Thank You to Optimus Prime For This Useful Post:
Chee-Hu (08-27-2013)
Old 08-27-2013, 09:51 AM   #1046
sierra
My thoughts are that the bracket we have in the pic is compatible with a bracket for RHD. The LHD bracket angles back out of the way and another small attachment can easily be fitted on top of it using the same bolt. So that bracket would suit either application and the odds of the threaded hole being deleted are low.
I feel that a restraint for the A/C hose is essential and should come with the strut brace so that it's correctly managed. Cable ties let the modification down.
Old 08-27-2013, 10:00 AM   #1047
sierra
Check out my solution for the AC line chaffing. Some may say it's overkill, but "overkill" is my middle name...
Just noticed this shot shows off the GS MCB as well...
I really appreciate your detailed posts on the parts but for me the rubber lined clamp and an extended bracket would be enough. The bracket is loaded in extension so can be very light and still effectively restrain the hose.
Old 08-27-2013, 11:56 AM   #1048
PNW FRS
PNW FRS's Avatar
Bar installed - 1st impressions
Install took all of about 10 minutes.
REALLY liking the difference the bar makes...
Overall, a "tighter" feel in the steering wheel... the minor "back and forth" I felt via the steering wheel -- even on pretty level roads -- is gone.
I'm feeling quite a bit of difference (IMHO) when driving over washboard roads or small bumps.
Thanks GS!
2013 Asphalt / MT
Olympia, Washington
Old 08-27-2013, 02:47 PM   #1049
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I agree! The install was very easy and the car drives and feels better! This was one of the best upgrades I have done to the BRZ and the red bar looks awesome!
tripjammer is offline   Reply With Quote
Old 08-27-2013, 03:09 PM   #1050
Opposed
Drives: 2013 Asphalt FR-S
Stopped by and picked mine up today at the shop. Slapped it on in the parking lot and was on my way in 10 minutes. I can feel the difference everyone is talking about. Its a more planted feel, especially going over bumps in the middle of a turn. $100 for something you can feel? No brainer in my book.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
chanomatik (08-27-2013)
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
