#29 |
Drives: 86
Yes it came with shims and seals. But the seals will not fit. I ordered new seals.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
| The Following 2 Users Say Thank You to 8686 For This Useful Post: | jcw99 (03-06-2016), RehabJeff86 (12-05-2013) |
#30 |
Drives: 2013 FR-S, 2016 Miata Club
#31 |
Drives: Firestorm 86
#32 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
#33 |
Track Junkie
Drives: Argento Scion FR-S
Do our car's speedometer have to be recalibrated after the FD install? Has anyone confirmed it with a GPS? Thanks!
#34 |
Drives: GT86
#35 | ||||
degrees
Drives: 6MT BRZ
The MFactory gears aren't made as well as OEM but they're solid. My set didn't lay down a perfect paint mark but were shimmed properly, set at 0.008" tolerance, and make no noise as a result. Quote:
I daily the 4.67, find it on the mild side, and am glad I went 4.67 over 4.56. My last car had shorter gears and spoiled me. I'd go even shorter if I could find a taller 6th gear to drop RPMs on the highway. Quote:
60 MPH: 2950 RPM 70 MPH: 3500 RPM 75 MPH: 3750 RPM 80 MPH: 4000 RPM Quote:
Changes to your tire's rolling diameter is the only way to change it and it's underrated anyway. 60 MPH indicated is actually around 58-59. Slightly taller tires would make it more accurate. Last edited by 37; 08-26-2013 at 12:45 PM. |
| The Following 4 Users Say Thank You to 37 For This Useful Post: |
#36 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
This makes me happy. I'm going to start looking into the Supra's 4.88 mentioned in the other final drive thread going on right now.
#37 |
degrees
Drives: 6MT BRZ
Keep in mind that a 4.88 would be about 4.5% over the 4.67. Take the speed/RPM numbers I posted above and multiply by 1.045 to find your approximate highway cruising RPMs. Without a taller 6th gear, 4.88 might be a bit much. That's the only way I'd recommend going taller.
| The Following User Says Thank You to 37 For This Useful Post: | jcw99 (03-06-2016) |
#38 |
Weight Nazi
I don't care too much about 80 mph, I'm more interested in 1st and 6th's top speeds. This isn't my daily driver.
#39 |
degrees
Drives: 6MT BRZ
In that case I can't say anything negative about going shorter. The 4.67 is fun as hell. I doubt another 4.5% would be night-and-day noticeable but every little bit helps.
Go for it |
| The Following User Says Thank You to 37 For This Useful Post: | Anthony (08-26-2013) |
#40 |
Vtec Jesus
Interesting
#41 |
Weight Nazi
You know of a source to figure out the top speeds of gears at that ratio? I know there are bunch out there, but the one I'm looking at now wants too much information that I don't know.
EDIT: I probably wouldn't want too go much shorter, I wouldn't think. I plan on getting on getting some really stick tires next time around, but still, I'm not trying to do 6th gear burnouts.
#42 | |
degrees
Drives: 6MT BRZ
http://www.teammfactory.com/gearcalc...ission+1+%26+2 |
| CUSCO 4.55 FINAL DRIVE installed. | Racecomp Engineering | Engine, Exhaust, Transmission | 489 | 06-17-2018 12:14 AM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
| Anyone w/ 3.727/3.909 Final Drive Post Boost? | Staf00 | Engine, Exhaust, Transmission | 12 | 05-02-2013 08:38 PM |
