Old 08-26-2013, 04:26 AM   #29
8686
8686's Avatar
Drives: 86
Originally Posted by 07jazzrs5gt86 View Post
did it come with shims?
Yes it came with shims and seals. But the seals will not fit. I ordered new seals.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8686 For This Useful Post:
jcw99 (03-06-2016), RehabJeff86 (12-05-2013)
Old 08-26-2013, 04:44 AM   #30
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Looking forward to your install! Keep us posting on anything you come across.
JimmyMac is offline   Reply With Quote
Old 08-26-2013, 07:44 AM   #31
07jazzrs5gt86
Drives: Firestorm 86
What new seals part number you need for the install?
How many shims did it come with?
I've read on 1 of the cusco tread that each car have different shims size.
07jazzrs5gt86 is offline   Reply With Quote
Old 08-26-2013, 11:08 AM   #32
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
I got this from our local Toyota dealer for 450 $.
http://www.ft86club.com/forums/showp...1&postcount=34
Will be in my car by Thursday.
pics? before and after dyno? thx!
448hpsti is offline   Reply With Quote
Old 08-26-2013, 12:23 PM   #33
The Slow One
Track Junkie
Drives: Argento Scion FR-S
Do our car's speedometer have to be recalibrated after the FD install? Has anyone confirmed it with a GPS? Thanks!
The Slow One is offline   Reply With Quote
Old 08-26-2013, 01:10 PM   #34
ft_sjo
Drives: GT86
No, but the gear selected indicator on the dash may be out. This can be corrected with a decent remap.
Old 08-26-2013, 01:20 PM   #35
37
degrees
37's Avatar
Drives: 6MT BRZ
Originally Posted by JimmyMac View Post
Also, I notice a group buy for the MFactory set for cheap. But not many willing to jump in. I'd jump in on it now if I could get it at that price.
At $600 it's a good deal. FDs aren't something most are willing to tackle so that kills popularity. Too many people here are into bolt-ons/cosmetics and won't dig into slightly more difficult parts. The 4.67 wakes this car up and makes it feel like it should have from the factory.
The MFactory gears aren't made as well as OEM but they're solid. My set didn't lay down a perfect paint mark but were shimmed properly, set at 0.008" tolerance, and make no noise as a result.
Originally Posted by Dustin View Post
The kit I'm getting is priced very well and doesn't require a group buy. I just don't want to jump the gun and tell people to buy it without testing it first.
Dramatic introduction aside, what's the ratio? Manufacturer?
Originally Posted by FT-86 SpeedFactory View Post
A 4.67 is pretty hefty for a daily driven car.
I daily the 4.67, find it on the mild side, and am glad I went 4.67 over 4.56. My last car had shorter gears and spoiled me. I'd go even shorter if I could find a taller 6th gear to drop RPMs on the highway.
Originally Posted by mtsui View Post
how high is the rpm when its going 80 mph in 6 gear? the car is my daily drive, but I do track alot with this car as well!
With the MF 4.67 on factory tire diameter, here's what you'll see indicated on the speedo:
60 MPH: 2950 RPM
70 MPH: 3500 RPM
75 MPH: 3750 RPM
80 MPH: 4000 RPM
No. I checked the speedo against a GPS before/after installing the 4.67 and nothing changed. The sensor measures wheel speed and isn't affected by the FD ratio.
Changes to your tire's rolling diameter is the only way to change it and it's underrated anyway. 60 MPH indicated is actually around 58-59. Slightly taller tires would make it more accurate.
37 is offline   Reply With Quote
The Following 4 Users Say Thank You to 37 For This Useful Post:
Anthony (08-26-2013), jcw99 (03-06-2016), RehabJeff86 (12-05-2013), The Slow One (08-26-2013)
Old 08-26-2013, 01:30 PM   #36
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
This makes me happy. I'm going to start looking into the Supra's 4.88 mentioned in the other final drive thread going on right now.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-26-2013, 01:38 PM   #37
37
degrees
37's Avatar
Drives: 6MT BRZ
Keep in mind that a 4.88 would be about 4.5% over the 4.67. Take the speed/RPM numbers I posted above and multiply by 1.045 to find your approximate highway cruising RPMs. Without a taller 6th gear, 4.88 might be a bit much. That's the only way I'd recommend going taller.
The Following User Says Thank You to 37 For This Useful Post:
jcw99 (03-06-2016)
Old 08-26-2013, 01:39 PM   #38
Anthony
Weight Nazi
Anthony's Avatar
I don't care too much about 80 mph, I'm more interested in 1st and 6th's top speeds. This isn't my daily driver.
Old 08-26-2013, 01:44 PM   #39
37
degrees
37's Avatar
Drives: 6MT BRZ
In that case I can't say anything negative about going shorter. The 4.67 is fun as hell. I doubt another 4.5% would be night-and-day noticeable but every little bit helps.
Go for it
Old 08-26-2013, 01:52 PM   #40
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Interesting
TouchMyHonda is offline   Reply With Quote
Old 08-26-2013, 01:54 PM   #41
Anthony
Weight Nazi
Anthony's Avatar
You know of a source to figure out the top speeds of gears at that ratio? I know there are bunch out there, but the one I'm looking at now wants too much information that I don't know.
EDIT: I probably wouldn't want too go much shorter, I wouldn't think. I plan on getting on getting some really stick tires next time around, but still, I'm not trying to do 6th gear burnouts.
Old 08-26-2013, 02:01 PM   #42
37
degrees
37's Avatar
Drives: 6MT BRZ
MFactory has one on their site but I had to cheat the rolling diameter to match my real-world results. Use this link and change the FD numbers as needed. The rest is populated with 6MT BRZ ratios with 4.1 on the left and 4.67 on the right. Change the 4.1 and/or 4.67 and click "Calculate Transmission 1 & 2".
http://www.teammfactory.com/gearcalc...ission+1+%26+2
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 01:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 05:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 09:38 PM
