Old 08-16-2013, 02:21 AM   #1
Fast_Freddy
Drives: Passat
Wheel advice
Hey guys, I could use some help picking a set of wheels for my firestorm FRS. I know I want to stay with 17's and I'm leaning toward 17x8 with 225-45-17 UHP summer tires.
What I need your help with is choosing the best offset to balance handling and aesthetics. I'm not lowered and probably won't be. I don't care about being flush but would like to improve on the oem look without compromising the suspension geometry.
I also need some wheel suggestions. I know black looks great on red cars but I'm really partial to hyper black, black chrome, or whatever other name they use. I like the hyper black Rota Grids but what else should I look at?TIA.
Fast_Freddy is offline   Reply With Quote
Old 08-21-2013, 02:45 PM   #2
Fast_Freddy
Drives: Passat
Okay, how about opinions on Rota Grid 2 in 17x8 +38 hyper black on my firestorm FRS? Can anyone suggest other wheel manufacturers that offer this color under whatever name? TIA.
Old 08-21-2013, 05:13 PM   #3
Shadow Blue
Drives: Blue
You need 9 inches on the pavement for maximum grip.
Shadow Blue is offline   Reply With Quote
Old 08-21-2013, 05:17 PM   #4
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
For street driving, choose the offset that you think looks best. I'm running et35 on 17x8's and don't feel any difference in scrub radius. If you drive a lot on a 300 foot skid pad you will notice the wider track.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-21-2013, 05:50 PM   #5
SortaFlushed
SortaFlushed's Avatar
Drives: Raven Black
Imho I think 18's is the bare minimum.
SortaFlushed is offline   Reply With Quote
Old 08-21-2013, 05:55 PM   #6
Fast_Freddy
Drives: Passat
It's all about compromise. 17x9 with 245-40-17's might look and grip great but 17x8 with 225-45-17 will be lighter, ride better and get better mpg. I also don't want to lose the fun factor with too much grip.
Thanks. My new problem seems to be finding the size, style, offset and finish I want all together.
For me at least, it's function over form. 18's look good but make a slow car even slower.
Old 08-21-2013, 06:17 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Enkei RPF1: 17x8 = 15.6 lb., 17x9 = 15.9 lb.
Michelin Pilot SuperSport: 225/45-17 = 22 lb., 245/40-17 = 23 lb.
1.3 lb. per corner
Ever so *slightly* better gearing and lower ride height with 24.7" 245/40s vs. the possibly/theoretically better mpg and ride with the 25" 225/45s!
Old 08-21-2013, 06:33 PM   #8
Shadow Blue
Drives: Blue
You don't always have to compromise...at least not where you weren't going to already. In your OP you stated that you probably won't be lowering it. So what a great opportunity to go wider without worrying! Besides, 9's aren't really that wide anyway. As far as weight, do as ZDan said and get some Enkei's. They are the best bang for your buck on a purpose build.
Old 08-21-2013, 08:04 PM   #9
clintavo
I am at the same crossroads. The lightest affordable rim/tire combination I have found is the Kosei K4R 17x7 (14 lbs) and 215/45 Dunlop DZ101 (21 lbs). This would be over 5 lbs per corner weight reduction over stock, which in my experience is quite noticeable in acceleration and bumpy road handling.
17x8 RPF1 (15.6 lbs) with 225/45 is roughly 2 lbs heavier than the 17x7 combo above. Is the marginal increase in contact patch worth it?
17x8 or 9 with a 245 tire isn't an option for me: +45 disallows the use of camber bolts (rubs the spring perch), +35 pokes.
Am I missing another option?
clintavo is offline   Reply With Quote
Old 08-21-2013, 08:27 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by clintavo View Post
215/45 Dunlop DZ101
Tire size is fine, but I wouldn't go with the DZ101. Much worse wet grip vs. other UHP or Max perf tires.
I would investigate alternatives:
http://www.tirerack.com/tires/TireSe...45&diameter=17
clintavo (08-21-2013)
Old 08-21-2013, 08:40 PM   #11
clintavo
Good to know, thanks.
Old 08-21-2013, 08:42 PM   #12
BrokenNocturne
Drives: Scion FR-S Argento
Question
Can I have some thoughts on these rims? I like the way they look, but I imagine there are folks here that know way more about choosing good rims for you vehicle than I do...
http://www.tirerack.com/wheels/Wheel...nt&showRear=no
BrokenNocturne is offline   Reply With Quote
Old 08-21-2013, 09:03 PM   #13
clintavo
At 20.6 lbs, slightly heavier than stock. Then again, most wheels in that price range are about 19 lbs.
Looks are... subjective. Personally, I believe god kills a kitten every time these are purchased.
I can't help but think the lighter ones look better, the same way I prefer the look of a $100 bill over a 1$ bill. It's about the capability.
Old 08-22-2013, 02:36 AM   #14
Fast_Freddy
Drives: Passat
1.3 lb. per corner
Good job of finding that needle in a haystack! That example is far from the more typical 2-3lbs per corner. So much for the accuracy of Tire Rack's wheel weights. There is no avoiding some increase in rolling resistance and aerodynamic drag with wider tires. Thanks for your help but I have zero interest in RPF1s unless they're hyper black.
I forgot to mention that I'm compromising some function for form too. Finish has to be hyper black. Current choices are Rota G-Force 17x8 +48, Torque +48 and Grid 2 +38. I have yet to find a 17x9 in HB that won't poke too much for my taste.
In your example the extra contact patch is definitely not worth the extra weight, IMO.
attention whore, what an ass
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
Thoughts/advice on on wheel setup jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-23-2013 02:26 AM
Wheel/Tire Advice mrjester Tracking / Autocross / HPDE / Drifting 1 05-19-2013 12:48 AM
Starting out wheel/tire advice? rainmonkey Tracking / Autocross / HPDE / Drifting 19 05-02-2013 02:44 PM
Wheel Guys Chime In! Need advice on tire sizing Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-17-2013 02:21 AM
