Old 08-05-2013, 09:40 PM   #295
aqua8701
jAmoMz!
aqua8701's Avatar
Drives: 2013 DGM Limited BRZ
from black out that was peeling off:
"...And if they got a problem with it, tell them I said it!"
http://www.ft86club.com/forums/showthread.php?t=35563
aqua8701 is offline   Reply With Quote
Old 08-05-2013, 09:45 PM   #296
aqua8701
jAmoMz!
aqua8701's Avatar
To sexy smoked out
Old 08-12-2013, 10:57 AM   #297
Bonks86
Drives: Gt-86
4 coats of VHT red and 4 clear coats
Bonks86 is offline   Reply With Quote
Old 08-12-2013, 01:04 PM   #298
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
Edit: Finally did this! Happy with results, but still need to wet sand and polish when it is fully cured these were the products that I used:
Result:
[/QUOTE]
These came out great man!
This picture is before or after the wetsand & polish?
What did you use for the polish? I got some headlight plastic polish.. should do the trick.
Also - did you prep sand the tail light before you sprayed?
Thanks..
AM I THE MEANEST?
AM I THE PRETTIEST?
AM I THE BADDEST LOW DOWN MOFO AROUND TOWN?
SHO-NUFF!
ShoNUFF is offline   Reply With Quote
Old 08-12-2013, 01:06 PM   #299
Liquidsnake
Drives: "I drives like a Porsche"
I saw a black FRS this morning, with Red tail lights, and It looked amazing, Car looked exotic.
I have a whiteout, and the clears kind of vibe with that color, so i did not change it.
Liquidsnake is offline   Reply With Quote
Old 08-12-2013, 01:15 PM   #300
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by styl3z View Post
How long do i have to wait to paint the tail lights again, after using lacquer thinner to remove the paint (I f'ed up)? @DarrenDriven
You should be able to do it again right after just make sure the laquer thinner is gone
Old 08-12-2013, 01:17 PM   #301
Scoobidude
Drives: DGM BRZ
Attachment 47719
Attachment 47720
What clear did u use and did u do any sanding or anything before
Scoobidude is offline   Reply With Quote
Old 08-12-2013, 04:40 PM   #302
Bonks86
Drives: Gt-86
I wet sanded first and I used Krylon for plastics clear coat.
The Following User Says Thank You to Bonks86 For This Useful Post:
Scoobidude (09-06-2013)
Old 08-14-2013, 08:53 PM   #303
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Originally Posted by stefmiesterb View Post
Are any more people experiencing the VHT cracking the lenses?
idk if your post was covered or not, but it did crack mine sadly, couple of days later i noticed it had cracking on my right taillight
Kosmos is offline   Reply With Quote
The Following User Says Thank You to Kosmos For This Useful Post:
stefmiesterb (08-15-2013)
Old 08-19-2013, 05:00 PM   #304
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Result:
Damn this looks good...
Old 08-20-2013, 02:27 PM   #305
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
So i'm 3 coats of Metalcast deep and it's not glossy at all? It's a Matte finish.
Should I buff / polish the paint before clear or will the clear make it glossy?!!!
Help!!
EDIT: Nevermind! I sprayed the clear and it looks awesome! Pics to follow.
AM I THE MEANEST?
AM I THE PRETTIEST?
SHO-NUFF!
Old 08-20-2013, 03:23 PM   #306
Richard Cranium
Ted
Drives: Raven FR-S
Apply the clear, then buff/polish
2013 Scion FR-S - Sideways and Smiling
Bone-yard: 2010 Toyota Tacoma, 2008 Honda Civic SI, 2002 Audi A4 1.8T Stage 3 K04, 1999 Honda Civic SI
Richard Cranium is offline   Reply With Quote
The Following User Says Thank You to Richard Cranium For This Useful Post:
ShoNUFF (08-20-2013)
Old 08-21-2013, 01:59 AM   #307
Prooks
Prooks's Avatar
Drives: Whiteout FR-S
Update:
I used 2000 grit wetsand, glass cleaner (windex), then sprayed 2 coats of red with 15-20 minutes in bewteen. Then cleaned the new red coats and applied 2 clear coats with the Krylon Fusion clear coat for plastics. I also masked off the signal lights with masking tape.
I'm very happy with the results! I still like the valenti leds but this will do until I can afford those (unless someone wants to buy these of me)
Here's a quick cell phone shot:
Follow me on Instagram: @FRSUCKS
http://instagram.com/frsucks
Oceanside Car Meet: http://www.facebook.com/ovrdue
Prooks is offline   Reply With Quote
Old 08-21-2013, 11:37 AM   #308
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
So I finished up my tail lights this morning.
I feel like I should have put a few more coats of red but I didn't want to lay it on too thick and have it start to peel. In direct sunlight they're not as deep red as I would like. They still look 1000x better though so IDC.
Paint Used
  • Duplicolor Metalcast
  • Krylon Crystal Clear Gloss
  • Meguirs Plastic Polish
Method
  • Mask surrounding area
  • Mineral spirits wipe down (with gloves)
  • I did NOT pre-sand the plastic
  • 5 red coats total (3 light & 2 heavy)These went on matte and I got scared. The clear will bring back the clarity.
  • 10-15mins in between light coats with blow dryer
  • 20-30 mins in b/w heavy coats
  • 4 coats of Clear (the last heavy coat started to run a bit but you can't really see it until get really close at the right angle)
  • The last heavy coat of clear I let sit over night.
  • 2000 grit wet sand to get out the fish eyes
  • Meguirs Quick Detailer
Also put on my purple Lamin-X fog covers:
AM I THE MEANEST?
AM I THE PRETTIEST?
SHO-NUFF!
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
