Old 05-30-2013, 06:23 PM   #85
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Interested in a rear diffuser more than a wing. Plans on that? Another thread perhaps?
When we get around to it, we'll update that in our Aero Parts thread.
Hancha Group is offline   Reply With Quote
Old 07-03-2013, 06:16 PM   #86
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
hmm seems like you guys are coming up with allot of great idea thanks for putting in the time to design good performing products! I enjoy the look of a good sized GT style spoiler and like the rocket bunny option but find it quite pricey at 2200+. In your opinion is there other GT style wings that will be functional and more reasonably priced?
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 07-03-2013, 07:43 PM   #87
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by eddieEndo View Post
I would totally buy this
I would buy this also
Spartan65 is offline   Reply With Quote
Old 08-16-2013, 04:12 AM   #88
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Reviving the swan neck idea back from the dead...
http://www.speedhunters.com/2013/08/...k-in-super-gt/
We may start to see swan necks cropping up on everyday street/import cars if the next NSX manages to garner uber-fanboyism.
The Following User Says Thank You to switchlanez For This Useful Post:
Murseman27 (08-16-2013)
Old 08-16-2013, 03:56 PM   #89
RYU
RYU's Avatar
Drives: really slow...
btw... the license plate trunk mount idea i proposed earlier is now been incorporated by APR in one of their offerings. I guess it can support the downforce?
RYU is offline   Reply With Quote
Old 08-20-2013, 09:09 PM   #90
plucas
plucas's Avatar
Drives: Subaru
That is assuming APR's wing makes downforce. If the wing makes little downforce, it might handle it. It will not handle the downforce of our wing. It is also not a good place for the load to be applied
plucas is offline   Reply With Quote
Old 08-20-2013, 10:43 PM   #91
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Man I really want to pick up a second trunk so I can mount one of these puppies to it for track days!
FRSfan111 is offline   Reply With Quote
Old 08-04-2014, 11:28 PM   #92
Model Citizen
Lacking brains
Drives: frz
bump?
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
glamcem (08-05-2014)
Old 08-05-2014, 03:59 AM   #93
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I would love to see that type 2 design a wing will probably be my next mod
glamcem is offline   Reply With Quote
Old 08-05-2014, 09:23 AM   #94
plucas
plucas's Avatar
Drives: Subaru
Problem is tooling is very expensive (+$20k). We are looking at other manufacturing options however.
Old 08-05-2014, 10:15 AM   #95
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by Hancha Group View Post
So I had some time to look into this option. In my opinion, I don't think it would be a very good solutions. With the license plate off, there's a lot of flat surface area to mount the base
However, on the other side of the trunk, that is not the case
The sheet metal is very thin and when you are making a lot of downforce, it will be prone to bending and/or shearing completely. However, we may make a tow hook that will mount here in the factory windows cut out in the diffuser:
The tow hook will also double as a mount for the wing that way you can leave the wing or remove it, leave the tow hook or remove it. It will be a heavier solution than we'd ideally like, but it gives you the option to revert everything back to factory with no visible holes or cuts. While it won't be nearly as large or as extreme as the Exotic Air car, to get an idea of what a wing looks like when it's mounted that low:
Earl
This is cool.
Old 03-28-2016, 01:56 PM   #96
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Depends on the wing and placement. Theoretically, the DEW V1 generates excess of 500 lbs so I wouldn't trust the sheet metal alone. Our SEWs makes less and will likely make less in the real world and I'd bet most wings will make significantly less than ours. Paul's still working on the CFD and I'll make sure he posts the data once it's complete. It takes a lot of processing (~4 hours on our workstation, ~24 hours on Paul's PC). However, we will offer a tow hook mount and this is a rendering of what it will roughly look like (the final upright shape will change to place the wing where it needs to be):
While this solution is not ideal, there are some real benefits.
Pros:
The wing is mounted to a structural part of the chassis to better transmit the load
The load is transmitted at the rear most point of the car for better leverage
You get a multi-purpose tow hook (we plan on making a few additional options in the future)
NOTHING is drilled or cut, EVERYTHING can fully be put back to stock
Cons:
The tow hook is loaded in bending and in shear
You need to buy two tow hooks and larger uprights so,
It is heavier
It is more expensive.
If you can deal with the additional cost and additional weight this may be the perfect compromise for having a fully functioning wing at the track and removing it for daily driving.
Wanted to bump this old post to see if anyone's seen a solution like this come to fruition? Really interested in mounting my GTC200 at some point in the future in this fashion (tow hook mount position)
1Cor10:23 is offline   Reply With Quote
Old 03-28-2016, 02:22 PM   #97
Cole
Not a troll
Cole's Avatar
Seems as though they merged/became Velox.
Cole is offline   Reply With Quote
Old 03-28-2016, 04:56 PM   #98
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Cole View Post
Yeah I saw that. @VeloxEric any plans for future? Would love to see something that could be modular to fit popular wings on the market (e.g. GTC 200 / 250 Type 1 / Type 2). I think there'd be a big market for this
An introduction to Hancha Group Hancha Group Announcements, Contests, Giveaways 23 05-26-2013 12:56 PM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 09:18 PM
Hancha Rear Toe Link GROUP BUY Hancha Group Groupbuys 3 03-30-2013 11:21 PM
PTUNING FR-S/BRZ DS-325 3" Single and Dual Cat-Back Exhaust System. Group Buy!! Mrc@ptuning Engine, Exhaust, Bolt-Ons 35 12-10-2012 12:55 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
