go_a_way1
Old 08-15-2013, 03:04 PM   #1695
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Excellent replies, Slick. :happy0180:
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Slick (08-16-2013)
Old 08-15-2013, 04:51 PM   #1696
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Their must be a conspiracy against this fine thread, why in the hell its not sticky anymore ?!!
adprokid is offline   Reply With Quote
The Following User Says Thank You to adprokid For This Useful Post:
ill86 (08-17-2013)
Old 08-15-2013, 05:25 PM   #1697
Stephens
Stephens's Avatar
Drives: 2013 Scion FR-S - MT - Asphalt
I just got my tires in and don't have them mounted on my new wheels yes.
I have a 18x8.75 +20, and the tires are 225/45/18. I'm lowered 1 1/2 inch give or take.
Do you guys think I'll have any rubbing issues. I'm not really worried about the wheels as I've test fit them. My concern is the 45 series tire being too tall.
To succeed in life, one must go through it with a tenacious fiery spirit of twerk.
Stephens is offline   Reply With Quote
Old 08-15-2013, 05:39 PM   #1698
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
That's a tall tire. Is there any specific reason you would have ordered a 45 instead of a 40 aspect ratio?
+20 offset on that width of rim will poke out quite a bit, but you said you test-fitted and they are okay so I assume you're going for stance? You will camber to ensure you don't rub on the fenders.
Slick is offline   Reply With Quote
Old 08-15-2013, 07:26 PM   #1699
Stephens
Stephens's Avatar
It's what I'm used to ordering and didn't really realize until they got here. I can send them back if needed, but I don't really want to.
My one and only concern is the tire being too tall. I have found a few photos with a 45/18 and it looks like I'll be fine, but Idk.
Old 08-15-2013, 11:24 PM   #1700
ill86
ill86's Avatar
Drives: iG FR-S
225/45-18 is def too tall. If you can exchange you may want to reconsider.
Old 08-16-2013, 08:22 AM   #1701
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by Slick View Post
That tire is way too tall for this car. 2" taller diameter than stock. If you want a taller sidewall, I would consider going to 16" wheels.
Ultimately, you need to maintain as slose as possible to the OEM tire diameter which is 24.7" (or 844 revs per mile).
will 17x8 25 offset with 225/50/17 fit and not rub? i want the tire diameter to be a bit bigger than stock
NYCsubaruBRZ is offline   Reply With Quote
Old 08-16-2013, 10:18 AM   #1702
Slick
Slick's Avatar
Can I ask why you would want a larger diameter?
To each their own, I'm all for letting people do what they want to their cars. Some people do stuff for looks, some for function, or for whatever other reason. So not judging, but trying to understand your "plan".
Old 08-16-2013, 10:25 AM   #1703
NYCsubaruBRZ
ny roads suck. a bigger diameter tire will give me
pros...
1. a smoother ride (less shock from bumps and potholes, more absorbed by the tire) (not by much)
2. more ground clearance. (wont have to worry about the dips in the road as much. wont plow the snow (as much) with my front bumper in the winter).(not by much)
3. technically a higher top speed. (not by much)
4. technically less wheel spin on take off and shifting to second or third. (not by much)
cons...
1. decreased handling and areo dynamics (not by much)
2. slower acceleration / 0-60 time (not by much)
3. offroadish look if u wanna count that (i dont)
looks like the pros outweigh the cons in my situation.
17x8 +25 with 235/50/17 or 17x8.25 +30 235/50/17 will this fill all around with out rubbing?
Old 08-16-2013, 10:29 AM   #1704
NYCsubaruBRZ
i also want a low offset to make the rim poke as much as possible with out rubbing
i would like this for my brz.... can you guide me to a good fitment!????? thanks bro
Old 08-16-2013, 11:02 AM   #1705
Slick
Slick's Avatar
pros...
cons...
My roads suck too, I feel your pain...
Sounds like you've done your homework and have made up your mind.
235/50R17 is just over an inch taller than stock, so keep in mind that you will always be travelling faster than your indicated speed by about 6.6%. With this tire, you will gain ground clearance of 13mm, about 1/2".
Wheel & tire combo should be okay, but you may be the first guinea pig for this setup. Perhaps do a search on here re; taller tire or such to confirm.
The Following User Says Thank You to Slick For This Useful Post:
NYCsubaruBRZ (08-17-2013)
Old 08-16-2013, 02:55 PM   #1706
ill86
ill86's Avatar
Drives: iG FR-S
Pennsylvania roads are probably the worst in the country.
I ran 225/45-17 last winter and the slightly increased diameter helped with pot holes and no winter maintenance roads. :-)
Having said that... I personally would not run 235/50-17. But, its your machine.
8" +25 is going to be nearly 1/2" to 3/4" past the fender up front... Add camber (~ -2°) for some recovery. Rear will be flush.
Old 08-17-2013, 06:08 AM   #1707
NYCsubaruBRZ
i feel you on that. i took the car to tannersville a few times skiing it sucks in snow.
do i have to add camber? or will it rub if i dont? id like to not have to mess with the camber
Old 08-17-2013, 06:32 AM   #1708
NYCsubaruBRZ
should be okay? uh oh.... idk about that lol.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
