View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-15-2013, 10:02 AM   #2577
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
I had my pump replaced yesterday. There is a Tech bulletin out on it. The crickets are gone now. same tank of gas and all.
Maverick22 is offline   Reply With Quote
Old 08-15-2013, 10:12 AM   #2578
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
A lot of people report no crickets for a few hundred miles on the new pump and then they return. You should let us know again within the next 500 miles if they stay away.
DylanFRS is offline   Reply With Quote
Old 08-15-2013, 11:37 AM   #2579
absolut-b
Drives: 2013 FR-S Standard Blue
The sound does come from the fuel pump. All you have to go is go back to the dealer and they will replace the pump and some seals which is covered under warranty.
absolut-b is offline   Reply With Quote
Old 08-15-2013, 01:09 PM   #2580
MST Engineer
Drives: '11 Subaru STI
I work for Toyota and have access to the tech bulletins so I have been keeping my eye out for updates on this one. They just released an updated one a few weeks ago that found the root cause of the chirping. It has to do with bad seal alignment on the inside of the DI pump that causes the noise. To fix it you have to have the dealer replace the pump but it has to be after a certain manufacture date. I think the date was 4/2013 but I will have to check when I'm at work.
MST Engineer is offline   Reply With Quote
The Following 5 Users Say Thank You to MST Engineer For This Useful Post:
Blackbeltmma (08-17-2013), FRS1010 (08-15-2013), JDM FRS (08-15-2013), scary alien (08-15-2013), shiro (08-16-2013)
Old 08-15-2013, 01:15 PM   #2581
FRS1010
Drives: 2013 FRS
Thats great to hear! When I go in next week for my free oil change I plan on having them do it.
FRS1010 is offline   Reply With Quote
Old 08-15-2013, 01:25 PM   #2582
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
I cant wait to see what you're talkin about!
JDM FRS is offline   Reply With Quote
Old 08-15-2013, 01:41 PM   #2583
kahox
Drives: 2013 FRS, 2010 Evo X GSR
Started to happen after my first oil change 2 days ago. Used oem filter and motul 0w20 ecolite oil @7000 km
kahox is offline   Reply With Quote
Old 08-15-2013, 02:24 PM   #2584
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
At 7500 miles, I had the fuel pump swapped out under warranty, and the crickets went away. Within the first 500 miles on the new one, the sound was back. I'm hoping they come up with a solution soon
omegared19 is offline   Reply With Quote
Old 08-15-2013, 02:36 PM   #2585
HunterGreene
Hail Magnet
HunterGreene's Avatar
Not to rain on the parade, but this information came out back in April, and people who have been getting the pumps replaced as early as last month are still getting the chirps after a little while.
It has priests in it?
Old 08-15-2013, 02:49 PM   #2586
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Definitely. And it has been shown to pretty much a 100% success rate that getting your HPFP replaced will make the crickets go away... at least for 100 miles or so...
Old 08-15-2013, 08:30 PM   #2587
Demotic
Drives: 2013 FR-S, IS-300, 2004 VW R3
Originally Posted by thill View Post
I have been down the lemon law path before in Virginia with VW (car was in the shop more than 30 days within one year of ownership). It is not nearly as you are making out to seem and, again, you would have to prove that the crickets (at least in Minnesota, but most states are similar) were "substantially impairing" your ability to drive the vehicle, or the crickets would have to have "caused the complete failure of the steering or braking system and which is likely to cause death or serious bodily injury".
You can certainly try to go to arbitration for this, but good luck. I would not even waste my time.
I will definitely complain to both my dealer and Subaru America, but expecting to get Toyoya or Subaru to replace your car for something this minor is not being very realistic. Every car I have ever owned has had quirks. If the worst thing this car has is some intermittent crickets I will be happy.
A new car would be useless. All of the cars have this issue in the US (or the potential to have the issue). They all use the same HPFP.
That is Incorrect. I Lemon law'd my 2013 SS (more than 30 days in shop) and most of time it was in the shop it was due to random rattlings from the engine. Chevy started to give me a bot of headache and that's when I had my lawyer send them a letter. They then procceded to honor the lemon law within a week!
Demotic is offline   Reply With Quote
The Following User Says Thank You to Demotic For This Useful Post:
strat61caster (08-16-2013)
Old 08-15-2013, 08:31 PM   #2588
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I had the crickets after filling up with 91 octane 10% ethanol in Iowa on my way back home to Omaha. Noticed the crickets when I stopped to use the bathroom and get some water. Ran the tank until it was close to E, no low gas light. Filled up with my usual 91 non Ethanol gas, crickets gone. Now I have not driven 4+ hours at 80-85MPH continuously since then so granted my crickets could not appear until I do that again, but I am sticking by this ethanol in gas issue until I see otherwise personally. I am no mechanic, no engineer, but it worked. Did not have them before I left on my road trip, did not have them when I got to my Dad's in Michigan on 91 non Ethanol gas, and only the last leg when I HAD to fill up with 10% it showed up.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 08-15-2013, 08:54 PM   #2589
SurfAndSand
8SiX
Drives: FRS 10series
I did half a tank of 92, no-ethanol gas and then the other half 92 10% ethanol. I got crickets.
I'm going to try and run her empty, and then try non-ethanol fuel.
SurfAndSand is offline   Reply With Quote
Old 08-16-2013, 12:59 PM   #2590
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I haven't had a chance to read through 100+ pages of form but this is just what I heard from Toyota: The chirping is normal and part of the noise the boxer engine gives off.
I would assess it is because of the design and high compression, if the said comment was true. It's a little annoying but that's what a loud stereo is for :P
shiro is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
