#85 |
Drives: SSM LT MT BRZ
now that you guys have drug this thread miles from the subject, for no reason whatsoever...thanks btw
I would like to know who was monkeying with the lines underhood and why? The "mechanical pump" is electron beam welded EVERYWHERE, it does not and cannot leak externally except at the connections to the fuel lines...surely even JV could determine that. I'm all for calling out tuners for bad practice/lack of knowledge/general inept-ness... but I can't draw a line between a flex fuel kit and a car fire...unless some real serious stupid happened... FF senders are usually installed in the return line of a fuel system so that you can be assured that what is in the fuel rail is the same as what you are measuring with as little data delay as possible, we have a "returnless" system meaning the Fuel Pressure Regulator is in the tank, therefor not a good place to represent the fuel rail's fuel load. is JV relocating the Pressure regulator to the engine bay? that would seem to be a requirement for both proper functionality, and a great potential source of under hood fuel leak...if that conversion took place and was shaudy by design or installed by someone who lacked the basic knowledge to get the job done I could see it starting a fire...but I like to have a decent rock in my hand when I throw stones...pebbles just wont do.... any body got any input on this? |
#86 | |
Drives: BRZ(sold), STI
Insurance 'covering' aftermarket parts thing is about you getting reimbursed for the value of aftermarket rims/audio equipment/radars and whatever else you might have bolted on to a car, that didn't cause it to catch fire. It will not cover the damage to your car if it makes it go up in flames. Now, insurance companies will likely still cover you if you bag your car and then spin out going over a speedbump and hit an old lady, but if the car catches fire due to non-OEM fueling system the chances are that your insurance won't pay for your car. |
#87 | |
Read the DIY and be amazed http://www.ft86club.com/forums/showthread.php?t=40404 |
| The Following User Says Thank You to Luis_GT For This Useful Post: | SkullWorks (08-12-2013) |
#88 | |
Crazy... I really hope nobody gets seriously hurt or killed from this mod.. The vendor still does not even offer an installation guide! Nuts!!! |
| The Following User Says Thank You to thill For This Useful Post: | Luis_GT (08-12-2013) |
#89 |
#90 |
interesting way to handle that I guess... pay someone else to do your write up then stiff your customers so you aren't to blame for the leaks allowed by the lack of engineering.
I haven't sen a factory install yet that had the sensor in a pressurized fuel line, not saying it won't work, just not the conclusion any OEMs (to my knowledge) have come to... |
#91 | |
Dismember
Drives: 2013 Red Scion FR-S
So gracious of you. Coverage of aftermarket parts depends on your plan and carrier. As I understand it, you would have to contact them and ask for coverage, which you would probably pay for through a rider. As for coverage of problems caused by aftermarket parts, I'm not so sure. It probably depends on state laws. If you install a FRAM oil filter and it catches on fire, I don't think there will be problems getting coverage. Unless the policies specifically state there's no coverage, there's no reason to think you'd be screwed.
#92 |
Drives: Ultramarine toyobaru
Just so you know guys, for having participated in this thread, you can never own a Ferrari.
| The Following User Says Thank You to headlikeahole For This Useful Post: | Bullnettles (08-14-2013) |
#93 |
Since I can see that most of you are in the US, let me say this:
You can get practically anything insured here. It just depends on how much you're willing to pay for it. You have to make it worth their while! |
#94 |
Drives: 4 wheels
#95 |
Toyota Master Tech
Drives: Whiteout MT
![]() NEVER use a blade to cut a fuel hose off a line. Use the proper tools and get a hose hook. I can see clearly in this picture the scoring left on the hard line. In essence they have created a canyon in this sealing surface. I have personally seen fuel lines leak from this very scenario. |
#96 | |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
What's ironic is the car in this photo (either post_break or cobrabyte) didnt have (much) of a leak whereas even though I used a stanley blade to make small incisions before using a fish hook to tear the remaining rubber, I still ended up with a full on leak. As a Toyota Master Tech @LavosTRD, how important is it to have a correctly sized hose (esp fuel injection) with the proper EFI clamp when changing out to an aftermarket set up? |
#97 |
Toyota Master Tech
Drives: Whiteout MT
Get the proper sized hose, and use brand new factory clamps. There is a reason you don't see shitty screw down hose clamps from manufacturers anymore
#98 |
Kk! Now what?
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| Burning Oil? | RandomHero | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 10-04-2019 05:56 PM |
| Anyone smell burning outside the car? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 115 | 01-13-2015 02:31 AM |
| Sitting on the side of the road. coolant all over engine bay | ML | Engine, Exhaust, Transmission | 29 | 08-09-2013 02:41 PM |
| Burning oil? N/A | Synack | Issues | Warranty | Recalls / TSB | 11 | 11-08-2012 07:14 PM |
| Official: The new Ferrari V12 Ferrari Berlinetta | Levi | Other Vehicles & General Automotive Discussions | 27 | 03-08-2012 12:31 AM |
