Old 08-11-2013, 06:53 PM   #99
tomkozski
Drives: 2017 WRB BRZ w/ PP
Hi all,
This past Monday I had the TRD exhaust installed on my BRZ, have put on about 200 miles or so on it. I also have the TRD cold air intake.
How loud is this exhaust supposed to be? The exhaust is loud enough where I don't hear the engine until it gets past 4k rpm, and interior get loud and boomy - definitely too loud for someone in the back (short friends) to chat with driver/front passenger. Drones/gets boomy during highway cruising. So far my experience doesn't seem to match the reviews (quiet when cruising, no droning, etc), then again maybe my expectations were different.
I guess the better question to ask - for those with the TRD CAI or deleted intake sound tube, at what point in the rev range are you able to hear the engine over the exhaust in the interior with the windows up?
tomkozski is offline   Reply With Quote
The Following User Says Thank You to tomkozski For This Useful Post:
Lav (02-04-2019)
Old 08-11-2013, 08:11 PM   #100
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
I got the trd combo and mine is not as loud as you makes yours sound to be. Below 4k rpm the sound is nice and rich but it won't interfere with a conversation. Between 4-5k rpm it really sounds good but again not loud enough for passengers to want out. Wonder if the install is incorrect somewhere or the exhaust is leaking.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
Old 08-11-2013, 11:34 PM   #101
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by tomkozski View Post
Hi all,
I have the TRD CAI and love the sound it makes. My exhaust is pretty loud but I can hear the intake when my foot goes to the floor and when on the highway in 6th gear cruising above 75mph.
Old 08-12-2013, 12:53 AM   #102
FR-Sizzle
Drives: brz
Originally Posted by kALMIGHTY View Post
Anyone else notice that their TRD exhaust got quieter over time? I've had my car for just under two weeks now, and the exhaust is noticeably quieter?
When I first got my car, I didn't understand what people meant by "this exhaust is too quiet" because mine was super loud and sounded amazing. Now, the only time it sounds that good is during cold starts but once the car is warmed up, it gets REALLY quiet. There's basically no sound while cruising when it was loud enough to give me a headache the first day even during cruising.
I understand the exhaust is breaking in and the ECU has adjusted itself to the TRD exhaust and intake combo, but is there a way to get that loudness back or is it gone for good?
All exhausts get quieter over time if you bought it brand new. Build up smoke n stuff will help quiet down a lot of exhausts and change the tone over time.
FR-Sizzle is offline   Reply With Quote
Old 08-18-2013, 04:29 PM   #103
tomkozski
Hi all,
Turns out my exhaust was installed correctly.
Maybe because it's still in break-in phase, but the exhaust drones very loudly for me when cruising at 70-75mph. Not that bad when cruising around 55-60mph though. Did a drive from Chicago to DC, and it gave me a headache, especially on the PA turnpike with all the uphill/downhill sections. Drowned out the music I was trying to listen to. I'll give it a couple more months to see if the droning dies down a bit (driven about 1k miles with exhaust, most of it Chicago-DC), but if it doesn't the stock exhaust will go back on. I probably had wrong expectations for the exhaust, given that this is the first car I've tried to modify in such a way.
Old 08-19-2013, 12:35 AM   #104
Deathreaper
Drives: 2013 Scion FRS
This is my experience with the TRD exhaust
TRD exhaust alone with no mods: Was a bit too loud with the sound tube.
TRD exhaust + TRD CAI: Much better, cabin noise has been reduced significantly.
TRD exhaust + TRD CAI + Unichip tune: Same as before but slightly louder, better sound.
Deathreaper is offline   Reply With Quote
Old 08-19-2013, 12:51 PM   #105
Chase86
Drives: Ultramarine FRS
Check out my thread:
http://www.ft86club.com/forums/showthread.php?t=36720
Turns out the dealer didn't tighten the bolts and they fell out. Now that its fixed its much better.
Chase86 is offline   Reply With Quote
Old 08-20-2013, 11:33 AM   #106
tomkozski
I had a someone diagnose my exhaust, and it was installed correctly - no loose bolts, no leaks. The droning apparently is normal, though it might go away with further use. As the temps dropped here in the DC area this past weekend (fall-like weather, in the 60s), the exhaust became noticeably quieter and the droning basically disappeared, but I didn't have the chance to drive at 70-75mph where the droning was horrible.
Old 08-28-2013, 09:14 PM   #107
evox2frs
evox2frs's Avatar
Drives: Asphalt MT FR-S
Just had the TRD exhaust installed this morning, liking it so far. Definitely a good bit louder than I expected, but it should quiet up a bit soon. Anyways, I noticed this hole where the tip is welded. Is everyone else's like this? Need some confirmation from another owner. Here's the pic:
evox2frs is offline   Reply With Quote
Old 08-28-2013, 10:13 PM   #108
roddy
roddy's Avatar
Drives: '13 Ultramarine
I don't see a hole, but I notice the tab that is sticking up where the pipe and tip meet. This is just a tool to help align the pipe and tip when they are assembled. Is that what you mean?
Old 08-28-2013, 10:52 PM   #109
evox2frs
evox2frs's Avatar
I'm not sure, if you or someone else could take a pic that would be perfect. I can't find anything on the web yet. Is your tab exactly where my hole is? My hole is at 6 o'clock, right where you'd unbolt the stock tips. But these TRD tips are welded on.
Is your tab removable? Also, it is problem with me running like this? It doesn't look that pretty when you see it, and I paid a pretty penny for it, so would like for it to be right.
Old 08-28-2013, 11:20 PM   #110
evox2frs
evox2frs's Avatar
I found this install guide for the exhaust:
http://cdn.shopify.com/s/files/1/017...-18131.pdf?248
Doesn't say anything about tabs that I can see. But surely a hole going straight through the pipe right before the tips is not good, right? Trying to figure out if I should leave it as-is, or take it back to the dealer and see what they say .
I would think it would effect sound somehow too, but want some more input before I get the dealer involved.
The Following User Says Thank You to evox2frs For This Useful Post:
speedy racer (08-29-2013)
Old 08-28-2013, 11:38 PM   #111
roddy
roddy's Avatar
Sorry...not a tab for installation of the exhaust, but for lining up the tip to the pipe before the welding process. It speeds up production and makes sure the tip is properly aligned. I don't have a TRD cat back, but I'm pretty confident that's what it is. Hopefully someone with a TRD system will confirm theirs is the same. If it bothers you, I would nip it off with a die grinder or dremel.
Old 08-28-2013, 11:40 PM   #112
frs10
Drives: tezla
WOW
just got a quote from my dealer
TRD exhaust: $1889
TRD air filter: $769
right...
any suggestions?
frs10 is offline   Reply With Quote
To all Perrin exhaust owners Tylub Engine, Exhaust, Transmission 52 08-12-2013 12:06 PM
Any BRZ or FR-S owners in OH looking for an exhaust? TRev Engine, Exhaust, Transmission 10 09-21-2012 01:19 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 10:48 PM
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 11:35 PM
