Old 08-07-2013, 06:22 PM   #15
Demotic
Drives: 2013 FR-S, IS-300, 2004 VW R3
Originally Posted by JPFr-s View Post
Easy to get rid of. Either non-ethanol 93oct or use the Lucas octane booster. I've been of that damn sound for about 4 months. When I can't find ethanol free I put in a half bottle of the Lucas juice. Works every time.
So drop an extra $10 every time I fill up? Doesn't sound practical at all.
Demotic is offline   Reply With Quote
Old 08-07-2013, 06:32 PM   #16
FRS1010
Drives: 2013 FRS
Tried this last night and used half the bottle. While it does work as a "bandaid" for now not planning to use it all the time. Just wanted to see if it actually helped.
I agree. I will silence the crickets on special occasions.
FRS1010 is offline   Reply With Quote
Old 08-07-2013, 06:44 PM   #17
Shagaliscious
Drives: Firestorm FR-S (MT)
Well, I got home from work today, and couldn't hear any crickets. I revved the engine a little bit and heard the crickets, but they went away fairly quickly. I'm going to continue to listen for them, but before today they had become intermittent, I just didn't want to say anything and jinx myself. I'm nearly at 12,000 miles, all stock, pretty much just use Sunoco 93 (their pumps do state up to 10% ethanol too).
Old 08-07-2013, 08:08 PM   #18
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by AR35 View Post
im going to home depot today and getting insect killer. Going to put half a can in my gas and see what happens.
You have to get the granules. The liquid concentrates are useless. On the plus side, everyone behind you has a clean windshield.
On some hot days after stop-and-go or spirited driving down the twisty roads I use to avoid I-5 traffic, I sometimes lose the crickets. But they always come back.
FWIW Costco 92 Octane. Their gas is pretty high quality, I actually noticed a significant MPG bump between ARCO and them in my Outback, and now I avoid ARCO when Costco's available.
DoomsdayJesus is offline   Reply With Quote
Old 08-09-2013, 12:28 AM   #19
reesmicm
Drives: Scion FR-S
crickets
I have around 1700 miles in the two weeks I have had the car, I have always put Conoco 93 octane non-enthanol gas it it, I hear the crickets at start up until it gets warmed up. No clue, sounds more like it's coming from the pulley area, but havent dug into to deep, to much fun to drive than sit with the hood open.
reesmicm is offline   Reply With Quote
Old 08-11-2013, 01:02 PM   #20
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
So, the last couple of days I have been driving my car hard to get home. One day the cricket are there, the next there not!?? WTH
skye67 is offline   Reply With Quote
Old 08-11-2013, 01:24 PM   #21
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Burned the last amount of fuel with ethanol in? That would explain it.
Mad1723 is offline   Reply With Quote
Old 08-11-2013, 03:19 PM   #22
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Ya'll just aren't mechanically-minded enough. The solution is simple. I installed this sticker on my car last week, and the little bastards haven't even tried to come back.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-12-2013, 02:21 PM   #23
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I've had no crickets since May...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-13-2013, 12:33 AM   #24
skye67
skye67's Avatar
Ok, wiping the .... out my BRZ with mostly Chevron gas seem to help. Contacted Subaru of America today. To see what they will do about it. Just being a jerk and leaving a paper trail.
Old 08-14-2013, 04:58 PM   #25
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
same thing happen to me... that cricket sounds is annoying...
anyone can tell me if that is normal or not??
Old 08-14-2013, 05:58 PM   #26
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Most people have the noise, it does not cause problems.
It's up to you if you want to consider them "normal". You can go to your (or any) dealer and complain and they may replace the fuel pump as part of a warranty service but odds are the noise will return and your likely outside the range of vehicles the service applies to so the dealer may say it's normal and they're not going to do anything.
ineedyourdiddly
Lverasky (08-14-2013)
Old 09-27-2013, 11:52 AM   #27
JPFr-s
I wasn't suggesting you do that, since 10 bucks seems like a big deal to you... Not for everyone. Guess it depends on how much the noise really bothers you. And like I said, I put a half a bottle in, so that's $5 dollars.. Half the price of a full bottle. This is when there is no ethanol free gas around. Ethanol free gas will cost about $4 more per fill up anyway if you can find it in GA. Either way, never said it was economical but it gets rid of the noises I don't like in my car. See ya.
JPFr-s is offline   Reply With Quote
Old 09-27-2013, 01:50 PM   #28
Tromatic
in·ter·mit·tent adjective: intermittent 1. occurring at irregular intervals; not continuous or steady. "intermittent rain" Ethanol-free gas seems to reliably squash the crickets. Some of the fuel-additives seem to shut them up as well. A "new" pump under warranty has been the same old pump with crickets. There does seem to be a re-designed pump either out there now or coming soon. I'll wait a while to see what problems the "new" pump has before I get one. An "extra" ten bucks a tank is worth it.
Did I Just Lose $90? larryt1026 Cosmetic Modification (Interior/Exterior/Lighting) 30 08-10-2013 09:54 AM
Does Perrin catback exhaust LOSE torque? wbsrazzle Engine, Exhaust, Transmission 23 04-30-2013 09:32 PM
Motoring 2013's COTY: the twins lose Sport-Tech CANADA 11 02-01-2013 05:54 PM
BRZ/FRS - when they lose their charm... Marloon Other Vehicles & General Automotive Discussions 51 05-03-2012 10:05 AM
Don't lose hope! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 88 05-18-2011 01:20 AM
