#212 |
i checked for mine the day i picked up the car (thanks forum!). luckily they were installed. if i discovered the weren't after a while of driving, and i lived up north, i'd be asking the dealer to inspect it for any rust and fix/replace it. thankfully we don't have rust in florida anyway
#213 |
Drives: Scion FR-S 10 #853
So I ordered the underside plugs and they went in fine, I didn't even get down on the ground just felt underneath and mashed them in. However the plugs that go over the struts didn't fit, they seem far too big in terms of diameter. I ordered the part number from earlier in the thread, so FYI I guess.
PLUG D40 SU003-03038 |
| The Following User Says Thank You to oldpueblo For This Useful Post: | Marrk (08-05-2013) |
#214 | |
Drives: Honda Fit
Pics, by chance . . . ? |
#216 |
Shorter of breath
Drives: a soft bargain
Those look like the plugs the BRZ Limiteds use for the spoiler bolt access holes (trunk lid underside).
EDIT - I looked at my car, the spoiler plugs are a lot smaller than the holes for the shock mounting. Having said that, I don't see any way to get water into the trunk from those holes. The top shock flange appears to be watertight (shining a 100W shop light by the top of the spring resulted in no visible light when viewed through the hole), and even if not - the shock is not in the path of tire spray, AND you'd have to fill the channel in the bodywork before any spilled into the trunk. Looking at all the part numbers referenced in this thread...I'm 99.9%, nope, 100% sure there are no plugs intended for installation above the rear shocks. The plugs in the diagrams referenced are below the foam inserts for the jack assembly. Last edited by Admiral Ballsy; 08-05-2013 at 06:07 PM. |
#217 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
They still might fit. Try some silicone spray.
#218 |
If it looks like they're unnecessary then I won't worry about it. I was more concerned about the underside plugs anyway.
#219 |
Shorter of breath
These are what you have:
#220 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
So now that we're almost into 2014, has anyone actually gotten a vehicle WITH the strut tower cover?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | Marrk (12-20-2013) |
#221 |
Drives: Scion FR-S 2013 Raven
Potential design flaw with factory rear suspension? (WATER in boot area)
Bump for new owners!
o= FR-S =o Last edited by Mikepage; 05-04-2014 at 05:39 PM. |
#222 |
Drives:
Let's assume someone may have popped a plug into the frame all the way and can't feel where exactly it went. How would that someone go about retrieving the plug?
Sent from my SM-P600 using Tapatalk |
#223 | |
Lol! Don't worry, Just get a new plug
o= FR-S =o |
#224 |
Drives:
Kinda what I figured. I can't here a rattle, and a flexible rubber plug won't damage anything. Ah well.
| The Following User Says Thank You to Jarent For This Useful Post: | Mikepage (06-15-2014) |
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 03:57 AM |
| Impressive boot space! | BD | AUSTRALIA | 14 | 08-24-2012 05:30 AM |
| Fatal FRS Flaw!! | Skin | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-12-2012 05:21 PM |
| Pics of rear passenger area with plastic removed | JRitt | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 06-12-2012 09:17 AM |
