Old 08-03-2013, 05:01 PM   #15
choi
choi's Avatar
Drives: 2013 BRZ Limited Silver
Originally Posted by whaap View Post
I'm not sure of this but I think you have to have a certain minimum numbers of posts before you will have that option. It's not many, something like 5 or so. When you have it you sill see it in the lower right portion of the persons posting.
ahh ok thanks again
choi is offline   Reply With Quote
Old 08-03-2013, 08:52 PM   #16
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The counting of the numbers shall be 10.
Five is right out.
Old 08-03-2013, 09:16 PM   #17
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
No problem letting loose sometimes. I generally keep the car under 4k but all depends on the mood. I will push the car a little when I find a nice curvy road. Otherwise I drive normally. No need to be Fast and the Furious in our cars. Let the Civics rice on by trying to get you to race them.
Old 08-03-2013, 10:39 PM   #18
Be-Are-Zee
Originally Posted by MY13FRS View Post
Can't believe the stupid posts here lately. Is this the 1st car for 16 yr olds now?
So many people hide behind the Internet mask.
Trolling is becoming a hobby.
Be-Are-Zee is offline   Reply With Quote
Old 08-03-2013, 11:17 PM   #19
v1ru5
Drives: BRZ D4S 6MT L Vortech
It's an odd day when I don't hit 8200 rpms
v1ru5 is offline   Reply With Quote
Old 08-03-2013, 11:20 PM   #20
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
I normally keep my RPM's at 4-4,500 unless I want better gas mileage or to keep it quiet. I also change my oil early as hell too depending on how abusive I've been. Haven't had any negative effects yet but we'll see. With proper maintenance I don't think there will be an issue driving it either way.
Sent from my SGH-M919 using Tapatalk 2
ProTekk is offline   Reply With Quote
Old 08-04-2013, 12:17 PM   #21
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
Thanks for the info. I've been wondering because there are certain engines (diesel, certain Porsche engines) which get seal problems if you don't run it hard. It's not that I don't want to gun it. It's just that this is my daily driver, and I go long periods commuting without high revving. I just wanted to make sure this was ok. To be safe, I'd probably better intentionally wring it out in the weekends
lionbacker54 is offline   Reply With Quote
Old 08-04-2013, 07:43 PM   #22
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
http://www.ehow.com/info_12155614_us...achometer.html
Originally Posted by lionbacker54 View Post
i just realized this afternoon that i hardly ever really wring out the engine. is that ok? i know there are some cars which are meant to be driven hard, and its actually bad to just drive under 3K all the time. anyone know if this is true with the BRZ?
BRZfan is offline   Reply With Quote
Old 08-04-2013, 10:12 PM   #23
lionbacker54
Originally Posted by BRZfan View Post
Um, no. The question is not how to rev. The question is whether this engine needs it time to time
Old 08-05-2013, 12:15 AM   #24
tracerit
Drives: '13 SSM BRZ Limited 6MT
generally how long after a start do you guys ring it out? i usually shift at max 4k for the first five minutes after start then start shifting at 5k.
tracerit is offline   Reply With Quote
Old 08-05-2013, 12:49 AM   #25
marky
marky's Avatar
Drives: 2020 BRZ tS #54
got tot let her breath sometimes
me shifting at 3k this is a car you can drive 100% most the time on the streets thats what i also love about it and still good on gas
Old 08-05-2013, 07:32 AM   #26
BRZfan
BRZfan's Avatar
Um, OK...
Based upon the level of knowledge one seems to have (which is OK-everybody has to learn) I believe one will benefit from the additional knowledge. It may not answer the specific question but knowledge never hurts provided one uses it intelligently. Just trying to help dude. Just keep it up to and/or under the redline as indicated on the tachometer.
Old 08-05-2013, 11:50 AM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Short answer: yes.
Long answer: yes.
-alex
Old 08-05-2013, 12:01 PM   #28
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Honestly, sometimes I worry that if I don't redline the car once in awhile, I feel that the performance will degrade over time. Semi true since the ECU adjusts itself based on driving style. Probably no evidence to it though.
mikeTee is offline   Reply With Quote
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
GT86 with aero kit and high wing spoiler from Australian drive event Nafe FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 08-26-2013 11:15 AM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
