#85 |
Drives: 2013 FRS Asphalt
Maybe I missed it. But have you guys noticed the automatic transmission disengaging at all past the stock rev limiter?
2013 Scion FR-S AT Picked up 5/30/2012
#86 | ||
Reverse Burnouts
Drives: 2013 Argento FRS
if there was any slippage, the best way to determine that would be to go down to the strip and run 1 run down the track then calculate gear ratio tire diameter rpm when crossing the finish line speed at trap and where the rpm's are supposed to be without slip at that specific trap speed find the difference then calculate for the slip % Quote:
best example right here on the forum FBM 9.5 PSI 307 whp GT28 PTuning 6.2 PSI 298 whp GT30 it "looks" like PTuning did a better job, but in reality... they are moving about the same amount of air because of the different turbo sizes, so they make relatively the same power... EDIT: looking back at it the 521 whp FBM was running a GT35 and the base kit on this automatic is running a GT28.... I think i found out where the 90 whp discrepancy is coming from ![]() If im wrong just let me know @FullBlown im just going off the title "base kit" so i assume its the stage 1 kit which comes with the gt28 EDIT EDIT Flow rates GTX2867 51 lb/min GTX35R 71.5 lb/min
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 03-19-2013 at 06:50 AM. |
#87 | |
Drives: 2013 Black FR-S
#88 | |
Drives: Scion FRS
I hate to get into dyno debates, but we own both a Dyno dynamics and a Dynojet here. On our Dyno dynamics,I can load the car at 3000rpm and let the boost build and then make my sweep. The boost curve would look totally different from what I could do on our dynojet. Our dynamics can also adjust how much load you can throw at the rollers as well. The turbo's we are using are ball bearing, gt28's aren't available in JB Last edited by FullBlown; 03-19-2013 at 11:47 AM. |
#89 | ||
Reverse Burnouts
GT3071R 50lb/min GT3076R 54lb/min GTX3071R 56lb/min GTX3076R 65lb/min my guess it that they are using this GT30 series the X represents the new impeller design
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#90 |
Drives: Scion FRS
The X means its a Billet wheel.
#91 |
Reverse Burnouts
i thought there were design changes with the blades to improve flow?
the X series does flow MUCH better than the GT and T models in all areas of the rpm band, has higher rpm capabilities as well. so FBM yall should just strap a T-100 (180 lb/min) and call it a day
#92 |
Drives: 370Z
How long has this build been on the road, mileage, and any issues?
#93 |
Drives: Scion FRS
#94 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
#95 |
Drives: VW MK6 GTI | 13 Mustang GT
I'd go to SSP and get all their stage 2 auto transmission goodies.
#96 |
Off their site prices, I could easily buy a manual swap.. It's like 3350$, with out shipping.. Once the prices go down that might be an option, but I know where there is a complete 6spm with drive shaft, CM clutch and flywheel for 1000$ now shipped to my door..
#97 |
Drives: 86
GTX3071
#98 |
Drives: 2020 Subaru BRZ Limited
| Yet another...base dyno | Opposed | Engine, Exhaust, Transmission | 40 | 05-16-2013 02:43 PM |
| FS: 2011 TC base stereo | abutterman | Miscellaneous | 5 | 02-14-2013 10:29 PM |
| FS 06 rsx base AT | kodo | Cars for Sale/Trade | 1 | 12-11-2012 06:27 PM |
| FR-S Base Radio ASL and ASR? | DjDATZ | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-26-2012 11:45 AM |
