#2661 |
I'll have to dig through my notes - the main addition to the weight is the FMIC. The exhaust manifold/turbo/turbo discharge pipe only adds about 5-10 pounds over the the weight of the OEM exhaust manifold/cat it replaces.
| The Following User Says Thank You to AVOturboworld For This Useful Post: | DAMotorsports (07-18-2013) |
#2662 |
Living the dream
Drives: Fensport AVO Turbo GT86
I have my GT 86 booked into Fensport, the UK AVO agents, to have an AVO kit fitted end of next week. I believe that mine will be the first customer car in the UK fitted with the kit
| The Following 3 Users Say Thank You to Pitman For This Useful Post: |
#2664 |
Drives: dark grey metallic Toyota 86 MT
I just placed a deposit for the base kit + BOV + breather tank and Ecuteck. Hope to get it in a month or so.
#2665 |
Living the dream
#2666 |
Drives: AVO BRZ
The BRZ has been getting some more tuning this week and made 215 rwkw at 8 psi, on e80. Stock baseline 109 rwkw.
That's around 330 whp using dynojet numbers from drift office's charts on page 1.
| The Following 3 Users Say Thank You to nix For This Useful Post: |
#2667 |
Living the dream
My car will be tuned on 99 octane (RON). I will post up a dyno chart once it is done.
| The Following 2 Users Say Thank You to Pitman For This Useful Post: | Drift-Office (07-19-2013), nix (07-19-2013) |
#2668 |
Drives: AVO BRZ
Right from page 1 of this thread I was commenting how much I like the oem type design of this kit! Here's a picture with no AVO lettering:
| The Following 2 Users Say Thank You to nix For This Useful Post: | AVOturboworld (07-24-2013), ill86 (07-25-2013) |
#2669 |
I've been seeing here and there comments about how "tiny" the turbocharger that we use is, and I have to admit, it irks me. Because it is, if anything, on the large size for somebody doing a daily driver build on a 2.0-liter motor. OEM turbochargers are much smaller and run out of breath much sooner, while we've been pushing past 300whp (wheel, not crank) at 10~11psi on 92 octane fuel. That's still 4~6psi before the turbo starts running out of breath.
A tiny turbo would be like the ones that Subaru uses on the 2.0-liter motors in Japan (I've owned 5 of them!), which run out of steam completely at 250-270whp. On the flip side, they did spool a bit better than our setup - by a couple hundred rpm at most, though. |
| The Following 8 Users Say Thank You to AVOturboworld For This Useful Post: | cmss2000 (07-30-2013), frsvr4 (07-29-2013), ill86 (07-29-2013), JD86 (07-30-2013), mrk1 (07-29-2013), Pitman (07-29-2013), Shadeslayer (04-23-2015), Sportsguy83 (07-29-2013) |
#2670 |
Drives: Attitude
Pay no mind, those are the guys that like to compare their peewee sizes. In short, they know nothing.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Pitman (07-29-2013) |
#2671 | |
Drives: Very very slowly
![]() On the other hand, the TD04 on my 02 WRX (gone, but not forgotten) hit peak torque at 3000rpm on 93octane on an unloaded dyno. So quite a bit sooner than a couple of hundred RPMs. Only made 240whp or so, on all fours. And torque drops like crazy after 6200rpm or sooner. -budi |
| The Following 2 Users Say Thank You to buditjoenawan For This Useful Post: | Drift-Office (07-30-2013), frsvr4 (07-29-2013) |
#2672 |
Drives: vrooom...
| The Following 3 Users Say Thank You to M1K3 For This Useful Post: |
#2673 | |
Drives: Slowly
FWIW, I agree with you. The turbo you've used is slightly on the large side for a street driven (not street raced) car. I've had your kit on the dyno, along with others available and think anyone looking to go bigger needs to ask themselves why. If you need that hp, fine ... but don't kid yourself that you're not giving anything up and shifting the car closer to pig than Porsche. Most people confuse boost threshold with lag and they are NOT the same thing. Some pretty ordinary cars can have great looking power curves when loaded on the dyno. There are no free lunches nor magical turbos that make 500hp from 2 litres, while still being nice when on and off throttle in a daily driven situation. If you're choosing a turbo for street use based on a dyno sheet alone, you're doing it wrong. |
#2674 | |
Living the dream
![]() I decided to get the AVO kit for my GT 86 when Paul first started this thread exactly a year ago today :happy0180: As posted already, my kit is currently in the process of being fitted ![]() Perhaps for those who complain about the size of the turbo in the AVO kit, may I suggest these ![]()
| The Following User Says Thank You to Pitman For This Useful Post: | Sportsguy83 (07-30-2013) |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 03:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 02:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 08:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
