| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: Toyota 86 GTS
#16 |
NW Region Moderator
Drives: FR-S No More
Sounds like good logic to me.
#17 |
Hypnotic FRS Member
Drives: FR-S [Raven]
EV5 Enkei on stock tires --
I didnt want to spend too much , and i found out you cant order the StarSpec2 tires till 2013 (according to DiscountTire) - so i just decided to keep stock tires (17x7) but change the wheels only -
Im having some second thoughts about this - I did notice that the spoke design and the machined-lip makes the wheel seem smaller than stock but thats some optical illusion or maybe its just me. just wanted to share this with you all. Still managed to save about 2.5lbs/wheel and i can tell a bit of difference in how much lighter it feels. |
#18 |
FRS Adept
Drives: Firestorm FRS
those rims work surprisingly well. initially i wrote them off but i see they have some pop. you are the second person to sport these rims, and both times they look sweet.
can you step back and take some wide angle side shots ? |
#20 |
Hypnotic FRS Member
Yea, they arent RFP1's.. but maybe should of got them in 18's -- but i was trying to do this as cheap as possible. -- with 18's id have to ditch these and get 4 new tires $$.
but i feel better now i think - here are a few more pics as u asked for.on a side note, i am not sure what the big issue are with these tires, i know they arent StarSpecs' but they handle preetty good - if i did 18's i may consider the same Primacys... idk ?? anyway... here ya go .. for those of you on the 'fence' ... Last edited by rikdrt1; 11-29-2012 at 03:13 AM. |
| The Following User Says Thank You to rikdrt1 For This Useful Post: | ngabdala (11-29-2012) |
#21 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Beautiful
#22 |
Pugilist
Drives: GT 86 - Hot Lava (AUS Spec)
Mind if I ask which offsets these are? +38 or +45
"BOO FOR THE GOO" - Everyone
#23 |
SLO NO MO
These look fantastic. Are these 17x7's? The fit with the stock tire is perfect, in my opinion. I'm not a fan of too much stretch, and it's nice if the tire's rim protector actually has a chance to do its job.
They do look smaller than the stock wheel, but that's because the spokes don't extend to the rim, and the rim is pretty thick, so there is definitely an illusion of sorts going on since your mind wants to focus on the spokes. For these types of wheels, an 18 inch would probably feel a bit better, but then you're going to think it's smaller than other 18's and the cycle continues. Looks great as is, as far as I'm concerned. Real classic look and the colors complement your vehicle nicely. Thanks for sharing! Edit: as far as the Primacy HP's are concerned, they aren't *bad* tires. They're damned expensive for what you get though. |
| The Following User Says Thank You to Foobar For This Useful Post: | rikdrt1 (12-08-2012) |
#24 |
NW Region Moderator
New topic merged -- same wheel with same specs.
#25 |
jAmoMz!
Drives: 2013 DGM Limited BRZ
bump.
Did you ever replace the tires on these wheels? I'm about two days from getting these wheels myself and so far am going your original route as far as utilizing same tires.
"...And if they got a problem with it, tell them I said it!" http://www.ft86club.com/forums/showthread.php?t=35563 |
#26 | |
Drives: GTS 86
. Form to achieve function and you run 19' ?
#27 |
Drives: Toyota 86 GTS Velocity Orange
awesome wheel choice mate
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 11:30 AM |
| Enkei Performance EV5 | bazi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 06-29-2014 09:38 PM |
| Enkei Tenjin | raz0rbladez909 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 04-20-2013 11:22 PM |
| F/S Enkei NT-03 | SemperFi | Wheels and Tires | 6 | 10-21-2012 04:02 PM |
| Enkei | Symbiont | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-26-2012 08:36 PM |
